Olarila app / Images and Folders
mamajack
CPU: intel
Motherboard: gigabate
GPU: nvidea
Post by mamajack »
sir thus the specifications below.
Added in 4 minutes 38 seconds:
and this is the graphic card
Added in 1 minute 7 seconds:
dell latitude e6510
Post by MaLd0n »
mamajack, USE SIERRA OR HIGH SIERRA
mamajack
CPU: intel
GPU: nvidea
Post by mamajack »
thanks a lot sir i will also remember you for this help. :frantics
Added in 5 minutes 5 seconds:
sir where will i get the clover folder
Added in 1 minute 47 seconds:
becouse i can see from your video that you coppied clover folder and paste it in the efi
Post by MaLd0n »
mamajack, Olarila image have clover folder installed, just boot
mamajack
CPU: intel
GPU: nvidea
Post by mamajack »
ok
thameros
Post by thameros »
please how convert Olarila Mojave 10.14.1.raw to iso
Post by MaLd0n »
thameros, i never try it
the image is .dmg, just rename for .raw
thameros
Post by thameros »
thank you can I work rename in windows or mac?
Post by MaLd0n »
.raw to .dmg just rename, about .iso idk if work
thameros
Post by thameros »
raw2dmg don how convert to iso ineed use to VMware
promaestro
CPU: Core i7-8700
Motherboard: Gigabyte Aorus H370 Gaming 3
GPU: Sapphire Radeon RX 580
Post by promaestro »
Hi
I'm using i7-8700 with Aorus H370 Gaming 3 Mobo. I'm stuck in deciding which folders i need to download. Please help. Thanks in advance
Post by MaLd0n »
promaestro, serie 300/30
S3R14L
CPU: I7 8700k
Motherboard: GIGABYTE Z370XP SLI
GPU: Sapphire Pulse RX580 8GB
Post by S3R14L »
dmg -> iso
macOS:
hdiutil convert /path/to/example.dmg -format UDTO -o /path/to/example.iso
Here /path/to/example.dmg and /path/to/example.iso are the paths to the files obviously.
it will take a few seconds and after completion you will find your iso file with an additional .CDR extension. Simply rename it to .ISO
Windows:
DOWNLOAD - Dmg2img
Prompt -> dmg2img example.dmg example.iso
Linux: ( Ubuntu for example )
sudo apt-get update
sudo apt-get install dmg2img
Post by MaLd0n »
S3R14L, :guitar :guitar :guitar
cesar_ecvc
CPU: i5
Motherboard: lenozo z50-70
GPU: nvidia
Post by cesar_ecvc »
hello friends I have a desktop PC with H81M-S1 Gigabyte i5 3.20 Ghz 8 Gb memory and I would like to know what image is good to install and what ketx are the couriers.
I'll be waiting for your answer, thank you.
Post by MaLd0n »
cesar_ecvc, High Sierra ou Mojave, folder chipset serie 8
tlkmx
CPU: i4790k
Motherboard: Gigabyte GA-Z97X-UD5H-BK
GPU: ASUS GTX 980 STRIX
Post by tlkmx »
Hey Mald0n is mojave 10.14.0 ? Or is it beta and does it change anything ?
I tried installing macosx with tonycrap tools two years ago or so and failed during 3 days.
Now i'm ready to start again with my old build. Just with new tools :)
Post by MaLd0n »
tlkmx, use 10.14.1 image
marcosfofinho
CPU: 4200u
Motherboard: acer EA50_HW
GPU: INTEL CORE I5 4200U
Post by marcosfofinho »
bom dia a todos aonde eu posso conseguir uma iso do mojave mas gostaria no formato raw para eu fazer o boot pelo rufus
Post by MaLd0n »
marcosfofinho, no app têm, a versão pronta Olarila e a versão da AppStore
Return to “Apps”
