AppleHDA Patcher v1.9
Locked
bearloverpr
CPU: I9-7980XE
Motherboard: Asus PRIME X299 Deluxe
GPU: NVIDIA 1080 TI
Post by bearloverpr »
Not working for me in high Sierra. Any Idea?
Dell Inspiron 13
Mirone
Developer
Developer
CPU: Intel Core i7-8700k
GPU: Radeon RX 560 - 4GB
Post by Mirone »
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests]Any Idea?
delete FIXHDA in your config.plist
you need to apply the patches for IRQ's in your DSDT.
bearloverpr
CPU: I9-7980XE
GPU: NVIDIA 1080 TI
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests]FIXHDA
I did a full fresh vanilla install and created a new dsdt patch with IRQ's  and deleted the FIXHDA
But still don’t see any audio hardware
Mirone
Developer
Developer
Post by Mirone »
At the clover screen press F4, and you are booting into the system, run RunMe.app and send me the files.
bearloverpr
CPU: I9-7980XE
GPU: NVIDIA 1080 TI
here they are.
Mirone
Developer
Developer
Post by Mirone »
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests]here they are.
try this:
Arquivo Comprimido.zip
After instal repair Permissions and rebuild caches.
bearloverpr
CPU: I9-7980XE
GPU: NVIDIA 1080 TI
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests] try this:
(1.75 MiB) Downloaded 1 time
Sadly it did not work. :(
Mirone
Developer
Developer
Post by Mirone »
did you fix the permissions using what?
bearloverpr
CPU: I9-7980XE
GPU: NVIDIA 1080 TI
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests] did you fix the permissions using what?
i used "Repair.command"
Mirone
Developer
Developer
Post by Mirone »
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests] i used "Repair.command"
Send me the terminal output.
bearloverpr
CPU: I9-7980XE
GPU: NVIDIA 1080 TI
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests] Send me the terminal output.
Here
Mirone
Developer
Developer
Post by Mirone »
delete aDummyHDA.kext repair permissions and rebuild caches.
bearloverpr
CPU: I9-7980XE
GPU: NVIDIA 1080 TI
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests] delete aDummyHDA.kext repair permissions and rebuild caches.
I deleted the aDummyHDA.kext
No luck, is not working. :(
Do I have to take out something else like the codec patch from the config script or something else?
Mirone
Developer
Developer
Post by Mirone »
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests] No luck, is not working.
Follow the steps below:
1-Replace your current Clover folder with the attached one.
2-Delete any kext like: AppleALC.voodooHDA or similar.
3-Copy and paste ALC225.kext + AppleHDA.kext into: System / Library / Extensions.
4-Copy the RepairPermissions folder to your Desktop and Run RepairPermissions.command (only two clicks on the file).
[External Link Removed for Guests] .
if it does not work reply me with a copy of your IOREG.
bearloverpr
CPU: I9-7980XE
GPU: NVIDIA 1080 TI
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests] if it does not work reply me with a copy of your IOREG.
Double check that I didn't had any AppleALC or voodooHDA
it didn't work
later,
I had to copy FakePCIID_Broadcom_WiFi.kext back in to the clover folder (others) to get wifi back working.
here is the ioreg file
Mirone
Developer
Developer
Post by Mirone »
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests]it didn't work
I need your codec_dump.
bearloverpr
CPU: I9-7980XE
GPU: NVIDIA 1080 TI
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests]I need your codec_dump.
I have to do that in Linux or is there a way on Mac?
Mirone
Developer
Developer
Post by Mirone »
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests] I have to do that in Linux
No Only Linux use a LiveCD of Linux Mint.
bearloverpr
CPU: I9-7980XE
GPU: NVIDIA 1080 TI
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests] No Only Linux use a LiveCD of Linux Mint.
OKIDOKI, here it is.
did it in terminal with cat /proc/asound/card0/codec#0
slipttees
CPU: Intel Core i5
Motherboard: Dell Optiplex 790
GPU: Zotac 8400GS
Post by slipttees »
tenho um Dell Optiplex 790 com ALC269. Tentando com Lilu + AppleALC.
Dell Optiplex 790 - iMac12,1 - High Sierra 10.13.6 - Ok
Intel(R) Core(TM) i5-2400 CPU @ 3.10GHZ - Ok
Intel HD Graphics 2000 - Vesa Driver / Replace Zotac 8400GS 256MB - Clover + NvidiaInject - OK
DDR3 4.0GB 1333Mhz - Ok
Realtek ALC269 - AppleALC.kext - Ok
Broadcom BCM43224 - AirportBrcmFixup.kext - Ok
Intel 82579LM Gigabit Ethernet - IntelMausiEthernet.kext - Ok
HDD Hitachi 500GB - Ok
Locked
Return to “Apps”
