🎉 NEW Discord server!
AppleHDA Patcher v1.9
bcuraboy
CPU: i7
Motherboard: asus
GPU: intel
Post by bcuraboy »
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests] I need your codec_dump for a better analysis, in some cases the external microphone in Conexsnt codecs does not work.
Hey buddy, sorry for my late reply, didn't checked the forum for a bit. I'm attaching the codec dump from Jarvis, hope that's what you're after.
Thanks for your attention and help :)
Mirone
Developer
Developer
CPU: Intel Core i7-8700k
GPU: Radeon RX 560 - 4GB
Post by Mirone »
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests] Oi @Mirone , eu estou tentando todos os metodos possíveis pra fazer funcionar o audio no meu sistema mas até agora nada.
Copiar AppleHDA.kext+ ALC1220.kext em: System/Library/Extensions
substitua sua pasta Clover atual pela que esta em anexo, repare as permissões e reconstrua os caches usando este app: [Local Link Removed for Guests]
kevinagnes
CPU: i7 8700
Motherboard: GA H370n wifi
GPU: RX580 Pulse
Post by kevinagnes »
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests] Copiar AppleHDA.kext+ ALC1220.kext em: System/Library/Extensions
substitua sua pasta Clover atual pela que esta em anexo, repare as permissões e reconstrua os caches usando este app: viewtopic.php?f=81&t=6713
Valeu Mirone, vou testar hoje a noite! Grande abraço!
fetin
CPU: Intel core i5 7200U
Motherboard: MBL80YL
GPU: Intel HD 620 + geforce 940MX
Post by fetin »
Hello Mirone,
Can u pls help me with my audio problem? I am try everything but nothing solved me... Here is files and can u write me step by step what I have make for remove this problem? Many thanx
Mirone
Developer
Developer
Post by Mirone »
@fetin,
I need a Full Dump extracted with [Local Link Removed for Guests]
fetin
Post by fetin »
post 21.August 2018, 18:16 is my actual file [Local Link Removed for Guests]
kevinagnes
CPU: i7 8700
GPU: RX580 Pulse
Ainda sem audio! :/ mas o driver aparece no System Report, tentei a Id 5 também (DSDT) e nada! Segue o Jarvis anexado.
Mirone
Developer
Developer
Post by Mirone »
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests]Ainda sem audio!
você reparou as permissões e reconstruiu os caches?
copie a pasta RepairPermissions para sua área de trabalho, abra a pasta e dê dois cliques em: Repair.command
verifique se não tem nenhuma AppleALC instalada em Library/Extensions ou qualquer outra kext similar.
kevinagnes
CPU: i7 8700
GPU: RX580 Pulse
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests] você reparou as permissões e reconstruiu os caches?
Realmente, eu tinha usado o kext utility, com esse funcionou! Porem estou sem o audio funcionando de fato. testei com nas duas entradas e nenhum sinal de audio! No site da GB diz que o codec é ALC1220-VB. Esse VB pode ser alguma coisa? Outra, testo com diferentes Ids? não posso usar os ids 1 e 11?
Mirone
Developer
Developer
Post by Mirone »
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests] não posso usar os ids 1 e 11?
Não!
Pode usar, 5,7 e 9 testa com eles.
se não funcionar vou precisar de um codec_dump.
kevinagnes
CPU: i7 8700
GPU: RX580 Pulse
22 Aug 2018, 00:30
Não!
Testei com as 3 e nada, sinto o sistema não responsivo quando faço algo relacionado a audio no sistema.
Segue o codec dump
Mirone
Developer
Developer
Post by Mirone »
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests] Como faço o codec_dump? é no linux né?
Sim usa Linux LiveCD, [Local Link Removed for Guests]  explica como extrair.
kevinagnes
CPU: i7 8700
GPU: RX580 Pulse
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests]xplica como extrair.
Anexei ali em cima já :)
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests] Attachments
codecdump1.txt
(14.26 KiB) Not downloaded yet
anexei o codecdump com o .svg em DEC e HEX, espero que ajude! Tentei acompanhar o Guia mas ele me pareceu um pouco antigo para seguir passo a passo.
Mirone
Developer
Developer
Post by Mirone »
22 Aug 2018, 00:37
Segue o codec dump
Testa da seguinte forma:
1-ALC1220.kext + AppleHDA.kext + pasta Clover
2-Deleta ALC1220.kext e instala a AppleHDA.kext da pasta AppleHDA Full Patched.
Em ambos os casos após instalar repara as permissões e reconstrua os caches.
kevinagnes
CPU: i7 8700
GPU: RX580 Pulse
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests] 1-ALC1220.kext + AppleHDA.kext + pasta Clover
Agora rolou 100%! Usei o layout 5 pq minha Placamãe tem 3 saídas (azul, verde e rosa), o Headphone e lineOut são são trocadas automaticamente. Diferente do VoodooHDA com o AppleHDA não consigo destinar o audio X pra lineOut e o audio Y pro Headphone, consigo? Grande abraço e obrigado por tudo Mirone :) <3
Mirone
Developer
Developer
Post by Mirone »
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests] AppleHDA não consigo destinar o audio X pra lineOut e o audio Y pro Headphone, consigo?
Não entendi bem o que você quer, mas acredito que você deseja selecionar Headphones ao invés de ser trocado
automaticamente se for isso tenta com essa:
ALC1220.kext.zip
bcuraboy
CPU: i7
Motherboard: asus
GPU: intel
Post by bcuraboy »
I'm attaching the result of the RunMe.app hope it helps as well
kevinagnes
CPU: i7 8700
GPU: RX580 Pulse
22 Aug 2018, 04:28
automaticamente se for isso tenta com essa: ALC1220.kext.zip
Isso, alguns programas te permitem selecionar a saída de audio. Por exemplo: a saída do sistema saindo no Headphone(frente) e o Premiere Pro saindo no lineOut(atrás).
Testei esse ALC1220, ele continuou igual com o id 7 e com id 5 o audio desapareceu.
Mas nem esquenta com isso, já está ótimo do jeito que está! Era mais uma dúvida pq enquanto eu usava o VoodooHDA tinha essa opção :)
Valeu, grande abraço!
fetin
Post by fetin »
hi, here is required file
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests] by fetin » 21 Aug 2018, 20:25
Hello Mirone,
CLOVER.zip
(3.78 MiB) Downloaded 1 time
MironeAudio.zip
(136.78 KiB) Downloaded 1 time
bcuraboy
CPU: i7
Motherboard: asus
GPU: intel
Post by bcuraboy »
Mirone, tá aqui o Codec Dump do Linux. Obrigado
Locked
Return to “Apps”
