How to Stay within 15 ports limit using UsbInjectall and Clover boot argument
--Like - Comment - Subscribe - Share--
onemanosx
Post by onemanosx » 09 Dec 2018, 09:18
09 Dec 2018, 08:32
I just wonder if maybe are showed in eho1 section
This could possibly the reason if you have other usb controllers besides XHC i.e EH01 and EH02. Hot patch renames for EHC1 and EHC2 to EH01 and EH02 respectively is also a criterion as documented by Rehabman in his other guide.
Share with us your ioreg copy for curiosity sake. Thanks!
Intel i7-6700HQ, 8GB RAM (UEFI Clover High Sierra)
MSI B360 Gaming Arctic
Intel i5-8600 16GB RAM Asus Radeon RX580 8GB (UEFI Clover Mojave)
simo241
CPU: Intel 7700k
Motherboard: Msi z270 pro carbon
GPU: Amd rx 580 + gtx zotac 1080
Post by simo241 » 09 Dec 2018, 18:02
I attached my ioreg copy.
My USB are the one on motherborad z270 pro carbon , then there is an usb 3.0 hub and one usb 2 hub attached to the internal port of the motherboard that are going to the case nothing elese ,
the two 3.1 port ( one is usb C )on the back of the motherboard are not showed but when i attached an usb 3.0 is loaded on boat port
onemanosx
Post by onemanosx » 10 Dec 2018, 02:05
simo241, looking at your ioreg and it looks good so far. You do not have EH01/EH02.
But you do have an Asmedia USB chipset which is will work and not affected by port limitation.
Your on-board XHC also looks good. On my build, I also have a USB 3.1 Gen 2 USB C port which I plugged in a hub to detect both of its HSxx and SSxx.
Have you tried batch processing method? This way, it will show all ports by groups and you will never miss anything [Local Link Removed for Guests]
simo241
CPU: Intel 7700k
Post by simo241 » 10 Dec 2018, 09:16
Thank you very much for your reply , i already use the command described see attached but still only 13 port showed , i exclude all the one not used till SS10Image
onemanosx
Post by onemanosx » 10 Dec 2018, 09:36
simo241, Your USB C and type A is at RP05 (Asmedia chipset). Please check with manufacturer's documentation if this is true. USB headers are a little finicky in getting them detected properly (at least, for me it is). As for the rest, if all of your built in ports are detected, its ok to have only 13 ports shown and not necessarily to be 15 ports.
Sorry, I am not able to assist further other than this current knowledge that I have.
vpv
CPU: I7-4770
Motherboard: Asus H87m pro
GPU: Rx850
Post by vpv » 10 Dec 2018, 19:39
Thanks for the tutorial worked wonderfully!
Peter
simo241
CPU: Intel 7700k
Post by simo241 » 10 Dec 2018, 21:44
Yes it is Asmedia chipset, i sid know this chipset cause problem, well at this point is ok , only past things why in usb in system the speed of the usb is showed only 12mb/s on ly few port is 450 mb/s and not 5 g/s like every one
onemanosx
Post by onemanosx » 10 Dec 2018, 23:47
simo241, check pm
Added in 1 minute 52 seconds:
10 Dec 2018, 19:39
Glad we could help, Peter! :guitar :guitar :guitar
andrei30
CPU: 1
Motherboard: 1
GPU: 1
Post by andrei30 » 19 Dec 2018, 16:47
03 Nov 2018, 04:00
- Finally, with the ports you had discovered in steps 1, 2 and 3, you can now use the uia_include or uia_exclude boot flags for your discovered ports
3catsinky
CPU: i9 9900k
Motherboard: Aorus z390
GPU: Vega 64
Post by 3catsinky » 19 Dec 2018, 20:07
would adding a cheap USB 3 PCiE card solve the problem? I hate to do it considering this MOBO has so many ports, but if it means having working usb 3 in 10.4.2, why not?
onemanosx
Post by onemanosx » 19 Dec 2018, 23:00
19 Dec 2018, 20:07
google for compatible pcie card, if you are going that route.
Post by MaLd0n » 19 Dec 2018, 23:21
Fresco Logic FL1100, real native USB PCI card :mrgreen:
-Donated? Send me one PM-
thienquang199x
CPU: i5 8400
Motherboard: Asrock B360M Pro 4
GPU: RX 560
Post by thienquang199x » 25 Dec 2018, 15:17
03 Nov 2018, 04:00
Discovering Ports in batch and exclusion of ports used by keyboard and mouse
Other esteemed hackintoshers may want the option to discover their used USB ports in batches i.e implementing HSxx then SSxx/SSPx. This method will reveal each HSxx/ SSxx/SSPx batches in one pass.
1. Discover ports used by USB Keyboard and Mouse
- open the app ioreg and look for the ports used by Keyboard and Mouse
- in my case its HS09 and HS10
- therefore, I include the following boot arguments in clover like so uia_include=HS09;HS10
- doing this you will have control over your keyboard and mouse when you use exclude_hs identifier
2. Identifying HSxx ports only and exclude all SSxx/SSPx identifiers
- add these 2 boot flags
a. -uia_exclude_ss
b. -uia_exclude_ssp
- reboot and discover all of HSxx ports using USB 2.0 device like in the video link
- write down the discovered ports on a piece of paper
3. Identifying SSxx ports only and exclude all HSxx and SSPx identifiers
- delete the above bootflags (a) and (b)
- add these boot flags
c. -uia_exclude_hs
d. -uia_exclude_ssp
e. do not forget to include uia_include=HS09; HS10
- reboot and discover all SSxx ports using your USB 3.0 device like in the video link
4. Identifying SSPx ports only and exclude all HSxx and SSxx identifiers
- follow steps similar to above instruction set except you replace -uia_exclude_ssp with -uia_exclude_ss instead
5. Final Step
a. in my build example, I prefer to use uia_exclude. So, the final boot argument will look like like this
uia_exclude=HS05;HS08;HS11;HS12;HS13;SS05;SS06 (all of these are my unused ports)
b. if one prefers to use uia_include boot argument, the final boot flag will look like this
uia_include=HS01;HS02;HS03;HS04;HS06;HS07;HS09;HS10;HS14;SS01;SS02;SS03;SS04 (all of these are the used ports discovered)
I configured it according to your instructions but my USB 3.0 still doesn't work. Can you help me fix is ? Thank in advance.
onemanosx
Post by onemanosx » 25 Dec 2018, 15:28
thienquang199x,
Watch the video below if you have not done so.
We cannot help unless you can tell us which HS or SS ports you are using by testing the ports and looking at IOreg.
thienquang199x
CPU: i5 8400
GPU: RX 560
Post by thienquang199x » 25 Dec 2018, 15:35
25 Dec 2018, 15:28
thienquang199x,
My usb 3.0 is currently in HS10 instead of SS .
onemanosx
Post by onemanosx » 25 Dec 2018, 15:44
thienquang199x,
Looks like you are using a hub? Some hubs dont work correctly.
EDIT:
thienquang199x
CPU: i5 8400
GPU: RX 560
Post by thienquang199x » 25 Dec 2018, 15:47
25 Dec 2018, 15:44
thienquang199x, First you need to find all used HS then exclude the unused ports. Then, you find your SS using USB 3.0 device then exclude the unused ports.
Using USB 2.0 device, which HS ports are not in use?
Nope . I use usb sandisk 3.0 . It working in High Sierra but missing in Mojave .
Added in 3 minutes 4 seconds:
25 Dec 2018, 15:44
thienquang199x,
How to fix it? Thanks
Added in 3 minutes 29 seconds:
25 Dec 2018, 15:44
thienquang199x,
EDIT:
I plugged the USB in the front . In back, it working !
onemanosx
Post by onemanosx » 25 Dec 2018, 16:04
thienquang199x,
Test this clover folder
Nguyen - CLOVER.zip
Added in 2 minutes 16 seconds:
25 Dec 2018, 15:54
Yes, front port are not reliable.
thienquang199x
CPU: i5 8400
GPU: RX 560
Post by thienquang199x » 25 Dec 2018, 16:25
25 Dec 2018, 16:06
thienquang199x,
Nguyen - CLOVER.zip
Thanks. It also not working. :( :(
onemanosx
Post by onemanosx » 25 Dec 2018, 16:27
Just use back port. Front hub not reliable.
Note: if you look at my clover folder I set for you, there is no injector kext :mrgreen:
Return to “Youtube Hackintosh Guides”
