How to Stay within 15 ports limit using UsbInjectall and Clover boot argument
--Like - Comment - Subscribe - Share--
tthdm
CPU: Intel Core i7-9700k
Motherboard: Gigabyte Z390 Aorus Master
GPU: UHD 630
Post by tthdm »
I can't use the RunME app, becuse it fails at the IORegistry section and can't continue the progress. Only the USB's freeze, the build is running (e.g. i watched a youtube wideo, the usb just freezed and the video continued, so..). All usb ports not working. I tried to unplug the mouse, and keyboard, then plug in again, but it didn't work. I'm just using the build as usual, and random all of the usb ports stop working and the only thing i can do is restart my computer. Then this happens again.
onemanosx
Post by onemanosx »
tthdm, I cant tell off hand what is going on without dump files. Not sure if you have any 3rd party kexts in SLE or LE which might be the culprit. Or how you got your build installed. I say, do a fresh vanilla install and see if the problem arises again.
It is strange that your modern build is acting this way, tho.
MSI B360 Gaming Arctic
erroruser
CPU: AMD Ryzen 7 3700X
GPU: Sapphire rx 5700 XT
Post by erroruser »
tthdm, make sure to open your system pref then go to security an privacy select privacy look for accessability an add run me app to that an try the run me app again
:superman :superman
tthdm
GPU: UHD 630
Post by tthdm »
I added every permission that i could but still stucks at this:
Saving IOReg...
IOREG dump failed. Retrying
Increased delay x2 for IOREG dump. This will take a while...(33 sec)
I'm using your 10.4.4 distro, I installed that, and used the EFI that I copied there previously.
erroruser
Post by erroruser »
reinstall as a distro will cause issues reinstall with the Olarila image
:superman :superman
onemanosx
Post by onemanosx »
tthdm, you also mentioned you are using efi from a github repo. So I dont know which is true. And definitely you dont need battery kext for a desktop?
erroruser
Post by erroruser »
tthdm, open a new thread as your post is not related to port limits
:superman :superman
tthdm
GPU: UHD 630
Post by tthdm »
I'm using this image: [Local Link Removed for Guests]
Yes, I'm using EFI from a github repo, and the second repo is my efi. I didn't know that i don't need battery kext, I just put everything to my efi folder, because I thought this will work, because the repo's owner has a working build with same parts with this EFI. I can't run any RunME app, because any version I use, it will give me the same error, because IORegistryTool freezes and I don't know what i shloud do with this problem.
erroruser
Post by erroruser »
the proper clover folder you need is here for your coffeelake cpu [Local Link Removed for Guests]
:superman :superman
kollegha
CPU: 2,16ghz intel
Motherboard: asus
GPU: 2,1ghz
Post by kollegha »
02 Nov 2018, 12:50
onemanosx
MacintoshHealer
Motherboard: Gigabyte Z390 Designare
GPU: Radeon Vega 64
Post by MacintoshHealer »
On a 8 Series mobos under Sierra it was enough to edit the DSDT to exclude the unused HS+SS ports to have the total number of 15 ports and rename the device to XHC. This way no kexts or patches were needed.
Could you clear me up how it is under Mojave 10.14.4?
Why do you need kexts? What is the new UIAC device for? Isn't it enough to just delete the unused ports anymore in the XHC.RHUB?
Thank you!
onemanosx
Post by onemanosx »
02 May 2019, 11:19
Thank you!
1. Kext is just like device driver in Windows.
2. Yes, you can edit your DSDT to remove unused ports instead of using UIAC-SSDT.aml
3. Yes, you can also omit using kext if you are able to call the needed device-id via DSDT.
MacintoshHealer
GPU: Radeon Vega 64
Ok, thanks - so the theory did not change from Sierra to Mojave and from 8x to 3xx series...
In the past we had to rename XHC1 device to XHC in order to omit the Apple's own USB injector and to force macOS to inject USB ports from ACPI. Than all the ports from ACPI within the 15 ports limit were automatically injected by macOS.
I suppose that the _DSM with the right device-id is still needed than, so the right USB kext can attach to this device...
Can you confirm that by doing this 3 steps in the DSDT USB2/3 will work without any kexts or patches:
device is named to XHC,
ports number is reduced to the total of 15 in the XHC.RHUB,
_DSM with the right device-id is injected to XHC
onemanosx
Post by onemanosx »
02 May 2019, 11:55
The method works as how I did with my MSI build (read in guide section). Though I used ssdt with DSM method.
Pablo_picasso
CPU: 8700k
Motherboard: Asus Z370 TUF
GPU: Rx 580
Post by Pablo_picasso »
Hi everybody,
After add my ¨uia_exclude/include¨ in Clover Boot/Arguments, should I have USBInjectAll and USB patches into Kernel and Kext Patches?
Brigado! :roll:
onemanosx
Post by onemanosx »
Pablo_picasso, you can remove the USB patches but not USBInjectAll kext
MayoMan
CPU: i5-8600k
Motherboard: Gigabytes Z370 Gaming 5
GPU: Gtx1080
Post by MayoMan »
Hi i need some advice, I created my own ssdt custom for usb. My device id is a12f, i use the template provided by Rehabman and edit for my needs. My ports are HS02(Bluetooth), HS03(SS03),HS04(SS04),HS05(SS05),HS06(SS06),HS07,HS08,HS13,HS14 and i drop the SSDT-UIAC.aml in patched folder. Boot log shows that it is successfully loaded but when i see IOREG all HSxx and SSxx still loaded. Please help
SSDT-UIAC.aml.zip
onemanosx
Post by onemanosx »
MayoMan, Did you remove usbinjectall kext? Did you also compare results using hackintool? Hackintool can also generate custom ssdt or kext.
MayoMan
CPU: i5-8600k
GPU: Gtx1080
Post by MayoMan »
Nope i did not remove usbinjectall, but i did try removing the xhciunsupport kext to see if that makes a different. But sadly nope :(
Is there any different between custom ssdt and just using the boot flag (uia exclude)?
I havent try hackintool yet, i will give it a short now
onemanosx
Post by onemanosx »
MayoMan, your device id dont require xhci-unsupported kext. I say, generate with hackintool and see how it goes.
Using uia exclude is more simplistic and the only downside, the method will specify every port as external.
PS: Did you disable port limit patch?
Return to “Youtube Hackintosh Guides”
