Hackintosh Guide - Disable Discrete Graphic Card - Notebook - Nvidia or AMD
--Like - Comment - Subscribe - Share--
Post by MaLd0n » 14 Sep 2018, 02:50
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests]there you go...
check if work
config.plist.zip
-Donated? Send me one PM-
rositaott
CPU: Intel Core i5-7400
Motherboard: ASUS H110M-V
GPU: NVIDIA GeForce GT 730
Post by rositaott » 14 Sep 2018, 03:17
Got stucked here [IGPU] Scheduler Throttle Cap = 100ms...then need to force shutdown, inject fake id 0x16268086 so I can boot, then got a dim display with properly loaded graphics. But after restarts still the same :?
NoteBook | Acer E5-473G | i5-5200U | IntelHD5500
Post by MaLd0n » 14 Sep 2018, 04:47
u add 0x16268086 in config.plist tab devices?
rositaott
Post by rositaott » 14 Sep 2018, 05:11
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests] u add 0x16268086 in config.plist tab devices?
No.. I added from boot options> graphic injector. Fake ID. By the way I boot on safe mode using the config plist you sent, with valid id 0x16260006, graphics are perfectly loaded, but also dark display
rositaott
Post by rositaott » 14 Sep 2018, 08:57
Finally!!! :guitar Got my graphics working perfectly proper brightness...thanks to you Maldon...Now if this is not so much to ask, do you have guide how to fix not working trackpad? :mrgreen:
EDIT: Got it, have working trackpad now. :whistle
Post by MaLd0n » 14 Sep 2018, 14:30
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests] Finally!!! Got my graphics working perfectly proper brightness...thanks to you Maldon...Now if this is not so much to ask, do you have guide how to fix not working trackpad?
:mrgreen: enjoy
rositaott
Post by rositaott » 14 Sep 2018, 14:44
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests]enjoy
WIP
No VGA/HDMI Output
Brightness Button - Not working
WiFi - Not working
Any suggestion?
Post by MaLd0n » 14 Sep 2018, 14:56
HDMI u need check patch in config.plist
brightness kets u need a debug kext and apply a correct dsdt patch
wifi, need check model, intel don't work
rositaott
Post by rositaott » 14 Sep 2018, 15:00
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests] HDMI u need check patch in config.plist
Thanks a lot for support, I know those are off topic question. Can I send you my send file from your runme app to help me? :whistle
Post by MaLd0n » 14 Sep 2018, 15:12
now u need a very personal files, for check what u need, one generic patch don't solve ;)
rositaott
Post by rositaott » 14 Sep 2018, 15:20
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests] now u need a very personal files, for check what u need, one generic patch don't solve
Oh, I see...well thanks anyway, I'll try to sort it out, hope I have the skills you got on doing this :mrgreen: , gladly found this site for direct response and not sending link for every questions :lol:
Post by MaLd0n » 14 Sep 2018, 15:51
for debug what patch keys u need use it
rositaott
Post by rositaott » 15 Sep 2018, 05:49
Can you make video for that :mrgreen:
Post by MaLd0n » 15 Sep 2018, 15:22
install debug.kext in l/e, reboot, press key down brightness and run in terminal, log show | grep -i acpidebug, after, press up key and run again, check what keys u need patch
rositaott
Post by rositaott » 16 Sep 2018, 12:10
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests] install debug.kext in l/e, reboot, press key down brightness and run in terminal, log show | grep -i acpidebug, after, press up key and run again, check what keys u need patch
This is the output, what should I do next? :?
Post by MaLd0n » 16 Sep 2018, 16:23
for install, run it, reboot, press key down brightness and run in terminal, log show | grep -i acpidebug, after, press up key and run again, check what keys u need patch
rositaott
Post by rositaott » 17 Sep 2018, 00:18
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests] for install, run it, reboot, press key down brightness and run in terminal, log show | grep -i acpidebug, after, press up key and run again, check what keys u need patch
Hi Maldon, is it okay to discuss here regarding mapping of brightness keys? Really appreciating your help so much, but I need more understanding about it, like how to determine what keys I need to patch and ho to execute it? I have done what you instructed but I can't figure it out :wallbash
Post by MaLd0n » 17 Sep 2018, 01:14
follow instructions above and check what key we need patch, u see in log _Q11 or _Q12 or _Q16, etc
rositaott
Post by rositaott » 17 Sep 2018, 09:11
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests] follow instructions above and check what key we need patch, u see in log _Q11 or _Q12 or _Q16, etc
attached is the output from terminal, where can I see the log files?
this is what I've done
1.Install acpi debug kext > reboot
2.Run repair permission > reboot
3. Press down brightness key (Fn+left arrow) >log show | grep -i acpidebug, then
4 Press up brightness key (Fn+right arrow) >log show | grep -i acpidebug, and the result is from the attached file.
Post by MaLd0n » 18 Sep 2018, 00:24
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests] attached is the output from terminal, where can I see the log files?
need a dsdt patches, send me dsdt
Return to “Youtube Hackintosh Guides”
