Hackintosh Guide - MacOS Install - Mojave - HighSierra - Sierra - ElCapitan
--Like - Comment - Subscribe - Share--
n0dlaM
CPU: Xeon X5670
Motherboard: Asus P6X58D-E
GPU: AMD HD5850
Post by n0dlaM » 03 Oct 2018, 23:10
Hi MaLd0n.
Nice to see you still so active in Hackintosh community, I remember coming across your stuff when doing my first crappy iBoot SL install from CD.
I'm like many others that revisit to do a Hack every 3 years or so and forget wth everything does and means each time. I have so far installed High Sierra (last i've installed was Yosemite), I had to change AppleAHCIPort Find 40600200 Replace 00000000 in cfg in order to see drives to install to.
After that I've installed fine but have trouble patching my DSDT using your pack "[Local Link Removed for Guests]". I would like to get to point where I can turn my overclock on and have Speedstep working correctly etc, long way to go. Then I might try Mojave later but seems like a lot of trouble and maybe wont work well with such old GFX/Mobo.
Anyway. Attached is my run.me app Zip, and vanilla DSDT extracted from Windows.
Cheers in advance for any help! :superman
Post by MaLd0n » 04 Oct 2018, 01:51
03 Oct 2018, 23:10
Hi MaLd0n.
Hey :cap
-Donated? Send me one PM-
n0dlaM
CPU: Xeon X5670
GPU: AMD HD5850
Post by n0dlaM » 04 Oct 2018, 04:05
04 Oct 2018, 01:51
Hey :cap
Hi Daniel. Thanks so much!
I'm having an issue (probably n00b thing), I can't get the DSDT to load. I have repaired permissions with your script after moving it into ACPI/Patched folder and have checked the Cfg to make sure DSDT.aml is under name.
When I check in Clover boot menu I cannot select or see DSDT.aml, instead the only thing listed is BIOS.aml and I cant change it there.
Any hints?
Cheers mate! :)
Post by MaLd0n » 04 Oct 2018, 04:12
Just put in clover/acpi/patched, reboot and extract new Send_Me
n0dlaM
CPU: Xeon X5670
GPU: AMD HD5850
Post by n0dlaM » 04 Oct 2018, 05:00
04 Oct 2018, 04:12
Here is the updated Zip MaLd0n. Thanks again for your gracious help and generosity.
Just got WIFI working on this new install so now no waiting 3+ minutes booting back and forth :guitar.
Hope you are doing well!
n0dlaM
CPU: Xeon X5670
GPU: AMD HD5850
Post by n0dlaM » 06 Oct 2018, 00:17
04 Oct 2018, 04:12
Hi MaLd0n, I still cant get the DSDT to load, no idea why. Should I make a new thread for it?
Maybe a dedicated thread for Send_Me requests would be a good idea and can be linked to from the YouTube Tutorial?
Post by MaLd0n » 06 Oct 2018, 00:24
is very strange problem
what clover version u use? u use DSDT.aml in config.plist?
n0dlaM
CPU: Xeon X5670
GPU: AMD HD5850
Post by n0dlaM » 06 Oct 2018, 00:30
06 Oct 2018, 00:24
Hi MaLd0n, thanks for the reply. I'm using the latest version of Clover and the config.plist from your folder.
According to Clover Configurator name column has "DSDT.aml". What should I see specifically in the config to know
if it is set to use DSDT properly? Did you receive updated Send_me file?
Post by MaLd0n » 06 Oct 2018, 01:30
use a fresh install
n0dlaM
CPU: Xeon X5670
GPU: AMD HD5850
Post by n0dlaM » 06 Oct 2018, 04:10
06 Oct 2018, 01:30
use a fresh install
Guess I'm out of luck here MaLd0n.
I've re-ran the Olarila USB High Sierra Installer, re-formatted the High Sierra drive, install High Sierra.
Then I reboot, boot from Olarila USB, tell it to boot High Sierra from Hard Disk. Then I log in, disable the security restriction, install Clover with legacy boot options, replace Clover folder with Olarila Clover folder in EFI for x58 etc. After this I place the DSDT you made me in ACPI/Patched. Then I repair permissions (it gives a warning about x-code command as x-code is not installed yet), I let the script reboot. On reboot I choose the High Sierra disk, boot into HS and no dice. DSDT still isn't loaded, no sound device etc.
When I check in Clover Configurator in the name field it says DSDT.aml but in Clover boot options there is still only BIOS.aml to choose from, no other options. Any thing else you can think of that I should try?
Thanks for all your help so far. Cheers! :bye
Post by MaLd0n » 06 Oct 2018, 04:18
extract new SEND_ME
n0dlaM
CPU: Xeon X5670
GPU: AMD HD5850
Post by n0dlaM » 06 Oct 2018, 04:39
06 Oct 2018, 04:18
extract new SEND_ME
Here you go buddy.
Thank you!
Post by MaLd0n » 06 Oct 2018, 04:48
06 Oct 2018, 04:39
Here you go buddy.
Thank you!
n0dlaM, try last clover
n0dlaM
CPU: Xeon X5670
GPU: AMD HD5850
Post by n0dlaM » 06 Oct 2018, 21:11
06 Oct 2018, 04:48
Hi MaLd0n, no luck sadly :( .
I tried deleting Clover from EFI and re-installing from the Zippyshare link you gave me (thanks). Then I reinstalled the DSDT and repaired permissions (with X-Code installed this time). Still doesn't load DSDT. I then tried a fresh re-install and installed the Clover you gave me and still no luck. I also tried with the copy of Clover from Olarila USB and same result. Last thing I've tried was to install Clover without replacing it with your custom Clover folder, paste DSDT and repair permissions, still same result (I'm checking DSDT with MACiasl to look for HPET too once booted and nada).
Guess I'll be watching the :boxing from Windows 7 today :wallbash. I'm all ears if you have any other suggestions mate but I understand if you've got nothing as I'm having no luck finding any clues either sadly. All the best, enjoy your weekend!
Post by MaLd0n » 06 Oct 2018, 21:22
n0dlaM, no idea, bro
is a very strange
n0dlaM
CPU: Xeon X5670
GPU: AMD HD5850
Post by n0dlaM » 06 Oct 2018, 23:43
06 Oct 2018, 21:22
is a very strange
Hi again MaLd0n,
Very strange indeed, and I have an update!
This morning I got persistent boot-loops after waking computer from sleep in windows. Had to reset CMOS to get it working again.
Funnily enough after having the PC out I had removed the Olarila USB and when I launched Clover from the High Sierra drive it appeared different (there were images inside the little launch bubbles rather than just apples etc). The thing is I am 100% certain that each time I had been selecting the High Sierra disk in bios and NOT the USB, but for whatever reason I guess it was still launching the USB somehow and so was using cfg etc from there.
Anyway. After re-installing again and originally having issue with Legacy Shim 2, screen scrambling and unable to boot I launched from Olarila USB again and changed the CFG in High Sierra EFI to patch AppleAHCIPort 40600200 to 00000000 again I was able to get into High Sierra from its EFI and I confirm it is loading DSDT! :guitar :guitar :guitar .
However. I still have no sound I/O device. Do I need to use AppleHDA Patcher? I have attached new Send_Me incase it is useful and also the Jarvis output of AppleHDA Patcher (which I have not run yet). Thanks so much for all of your help so far bro! Do you have any other way of receiving donation besides PayPal?
Post by MaLd0n » 07 Oct 2018, 02:04
add applealc kext
ur codec is alc889
n0dlaM
CPU: Xeon X5670
GPU: AMD HD5850
Post by n0dlaM » 07 Oct 2018, 22:08
07 Oct 2018, 02:04
add applealc kext
ur codec is alc889
Thanks a lot for all your help bro!
Just a heads up in case it may help someone in the future. I had to replace Lilu.kext with the most recent one for AppleALC to load/work.
All the best MaLd0n, you're a legend ;) :superman
n0dlaM
CPU: Xeon X5670
GPU: AMD HD5850
Post by n0dlaM » 08 Oct 2018, 00:07
07 Oct 2018, 02:04
add applealc kext
ur codec is alc889
One last thing bro,
Any hint on how to generate SSDT for my CPU. SSDT_Automator doesn't dump file and not too sure how to use SSDTPRGen.sh :whistle
Post by MaLd0n » 08 Oct 2018, 01:05
n0dlaM, don't need, use Generate P and C States in Clover
Return to “Youtube Hackintosh Guides”
