[Guide] Hackintool - Video Patch - Fast and Easy Solution
adivajra
Geek
Geek
CPU: i5 9600K
Motherboard: ASUS TUF Z390M Gaming
GPU: UHD 630
Post by adivajra » 24 Mar 2019, 16:08
thank you very much Mald0n :geek:
I'll come back here after testing .
adivajra
Geek
Geek
CPU: i5 9600K
GPU: UHD 630
Post by adivajra » 24 Mar 2019, 18:23
ok the hack can not boot normally after i installed the dsdt.aml in clover/acpi/patched, it stops there:
:cry:
Post by MaLd0n » 24 Mar 2019, 19:36
adivajra, use opur clover folder for ur chipset
adivajra
Geek
Geek
CPU: i5 9600K
GPU: UHD 630
Post by adivajra » 25 Mar 2019, 06:33
so it means I need to re install mojave since I can't boot,
I would have no problem with a complete re-install BUT when I installed windows I used bootcamp to create the usb windows bootable and I have noticed that the windows bootloader has been installed on the Nvme drive where is mojave and not on the SSD where I was thinking it will be (since I choose it during windows installation)
So I guess that if I have to do a complete re-installation I will loose access to windows 10... any idea?
I know this is me who totally forgot to put the correct clover folder for my chipset after I updated Mojave and then clover, but I must say that I could boot into the hack without problem after just re-doing the hibernate and master disable command (well except the UHD 630 not being recognized :roll: )
Post by MaLd0n » 25 Mar 2019, 13:51
adivajra, u need check procedure about dual boot
adivajra
Geek
Geek
CPU: i5 9600K
GPU: UHD 630
Post by adivajra » 25 Mar 2019, 13:57
ok i will but for now is there a way to force the boot to my hack, I think if it is possible to let clover boot without reading the acpi/patched ?
So I could then boot and change to the proper clover folder within mojave... :help
Pablo_picasso
CPU: 8700k
Motherboard: Asus Z370 TUF
GPU: Rx 580
Post by Pablo_picasso » 27 Mar 2019, 21:55
Hi guys,
How to merge the Config.plist created by Hackintool with the one created with Clover Configurator?
onemanosx
Post by onemanosx » 27 Mar 2019, 22:04
27 Mar 2019, 21:55
Mount EFI or place working config.plist on desktop and export patch.
MSI B360 Gaming Arctic
adivajra
Geek
Geek
CPU: i5 9600K
GPU: UHD 630
Post by adivajra » 28 Mar 2019, 09:38
Finally, I decided to re-install my hack, so I downloaded 10.14.4 from olarila and made an USB bootable.
But I'm unable to install Mojave !
First I forgot to change the display port cable from my Graphik card to the onboard port = can't boot (freeze at less than 1 minute)
I add in arguments : uia_exclude=HS...., I changed to the mobo port still can not boot, same freeze.
So I took away the graphic card from the pcie but there is still the same problem!!!
I do not understand, because now it is the same conf. that was working before ?!?
Did I forgot something?
Post by MaLd0n » 28 Mar 2019, 11:47
adivajra, check if problem is nvram, use emuvariable driver
adivajra
Geek
Geek
CPU: i5 9600K
GPU: UHD 630
Post by adivajra » 28 Mar 2019, 12:13
thanks Mald0n
I just checked for nvram in the bios settings, it seems that there is still 1024Mb pre-allocated
I don't know how to use emuvariable driver, I've been looking around through the clover options I did not see any mention of it :?
Post by MaLd0n » 28 Mar 2019, 12:56
adivajra, is a clover driver
adivajra
Geek
Geek
CPU: i5 9600K
GPU: UHD 630
Post by adivajra » 28 Mar 2019, 13:17
ok thank you for your help.
Does it means I need to modify the clover installation in the efi partition of the bootable usb? ( I did not find any driver 'emuvariable' there though)
Also I was thinking can i change the config plist in the usb bootable installer to use the one you made for me? and add directly to acpi/patched the dsdt that allow the hack to recognize my iGPU?
++ I know AMD is going to release new graphic cards with navi architecture very soon, do you think those cards will be mojave compatible like the rx 580 or the RX 590 ?
Post by MaLd0n » 28 Mar 2019, 17:43
adivajra, need wait and check in 10.14.5 beta new drivers
Macosus
CPU: ntel(R) Core(TM) i7-7500U
Motherboard: Asus Zenbook UX490UA/IntelKaby
GPU: Intel(R) HD 620
Post by Macosus » 30 Mar 2019, 09:00
Please, when should I put this config file ? I have to keep it in the desktop or what? I mean what is the next step ...??
Post by MaLd0n » 30 Mar 2019, 15:08
Macosus, check if app merge files or just put patches in ur config.plist
Macosus
Post by Macosus » 30 Mar 2019, 15:21
MaLd0n, Could you please explain how can I do that?
Thank you for your help
Post by MaLd0n » 30 Mar 2019, 15:22
Macosus, just use a clover configurator or one good txt app like Textmate
adivajra
Geek
Geek
CPU: i5 9600K
GPU: UHD 630
Post by adivajra » 30 Mar 2019, 15:34
I think it means you need first to check your actual config.plist then you compare it with the one one created through hackintool,
so you will see if there is things added.
On macos I don't know but for example notepad++ has an option to put both script side to side and then color text that you can only find in one on the 2. ^^
Good luck
In my case I have stop trying... though I still don't know if I can install macos using the config.plist, dsdt patch and clover folder for my CPU directly on the USB bootable's efi partition...
Macosus
Post by Macosus » 30 Mar 2019, 15:36
MaLd0n, Thank you so much for your quick response.
This is what I've get when I've open it with TextMate:
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "[External Link Removed for Guests]">
<plist version="1.0">
<dict>
<key>Devices</key>
<dict>
<key>Properties</key>
<dict>
<dict>
<key>AAPL,GfxYTile</key>
<data>
AQAAAA==
</data>
<data>
AAAbWQ==
</data>
<key>device-id</key>
<data>
FlkAAA==
</data>
<key>disable-external-gpu</key>
<data>
AQAAAA==
</data>
<key>enable-hdmi20</key>
<data>
AQAAAA==
</data>
</dict>
</dict>
</dict>
</dict>
</plist>
Return to “Patches and tricks”
