[Guide] Hackintool - Video Patch - Fast and Easy Solution
kultrun
Donator
Donator
CPU: Intel i5 8400 4.0
Motherboard: Gigabyte GA-Z370 HD3
GPU: Intel Graphics UHD 630
Post by kultrun » 19 Mar 2019, 15:52
Hi, just a more question ... when you said "remove SSDT about video, DSDT patch about video"... it means also that I must delete any clover entrys about "GFX0 to IGPU"?
also "HDAS to HDEF"? and anything else? I attach my config.plist before apply the hackintool patch for video platformid etc
thanks!
Post by MaLd0n » 19 Mar 2019, 16:34
kultrun, no, don't remove renames, only InjectIntel or other patch if u use
kultrun
Donator
Donator
Post by kultrun » 19 Mar 2019, 17:18
Ah, ok... thanks MaLd0n!
I believe there are not any other patch in my hack... just the dsdt.aml provide by you (after sending you the resulting file of Runme). There is information about Intel Graphics UHD 630 in that dsdt.aml, in PCI section... but I think that's not a problem, right?
considering my mobo GA Z370 HD3 and the CoffeeLake 8400 i5 processor (with Graphics UHD 630), it is recommendable to use the definition of SMBIOS as MacMini 8.1? (Actually, I use the Imac 18,1 SMBIOS)
many thanks!
19 Mar 2019, 16:34
Post by MaLd0n » 19 Mar 2019, 17:22
kultrun, both work good
Added in 38 seconds:
19 Mar 2019, 17:18
no problem
erroruser
CPU: AMD Ryzen 7 3700X
GPU: Sapphire rx 5700 XT
Post by erroruser » 19 Mar 2019, 17:25
kultrun, for cofeelake either imac pro 1,1 or imac 18,3
:superman :superman
kultrun
Donator
Donator
Post by kultrun » 19 Mar 2019, 18:51
Thanks a lot, MalD0n and erroruser!
I will try tonight with these tips, so... considering that I only have the iGPU video (UHD 630), without a dedicated graphic card, I can try with the current smbios(18,1) or with macmini 8,1 or what erroruser recommends: imac pro 1,1 or imac 18,3
thanks!
kultrun
Donator
Donator
Post by kultrun » 20 Mar 2019, 14:25
Hi friends! So, I believe everything is ok after apply the patch/changes!
What I did:
- follow this guide
- Set Platform ID to 0x3E9B0007
- on the first try, change smbios to MacMini 8.1 and in connectors I changed the active connector (in red) by type hdmi, which is the correct one of the mother. Result: the hack boots but the screen looks all in shades of pink.
- So I changed three things: the smbios to imac 18,3 and changed this parameters in hackintool patch:
ID: 3E9B0007, STOLEN: 57 MB, FBMEM: 0 bytes, VRAM: 1536 MB, Flags: 0x00801302
TOTAL STOLEN: 58 MB, TOTAL CURSOR: 1 MB (1572864 bytes), MAX STOLEN: 172 MB, MAX OVERALL: 173 MB (181940224 bytes)
GPU Name: Intel UHD Graphics 630
Model Name(s):
Camelia: Disabled
Mobile: 0, PipeCount: 3, PortCount: 3, FBMemoryCount: 3
[1] busId: 0x05, pipe: 9, type: 0x00000400, flags: 0x000003C7 - DP
[2] busId: 0x04, pipe: 10, type: 0x00000400, flags: 0x000003C7 - DP
[3] busId: 0x06, pipe: 8, type: 0x00000400, flags: 0x000003C7 - DP
01050900 00040000 C7030000
02040A00 00040000 C7030000
03060800 00040000 C7030000
- As you can see, I went back to all the connectors as DP
- But in the hackintool patch, I turned on the option DP → HDMI (patch /advanced)
- Result: no more pink screen but video glitches issues
- So, I changed the smbios definition again to MacMini 8,1
- Result: everything seems to be ok now!!
- Now, all connectors appears as HDMI :whistle
But, as I only have a monitor, with an HDMI port ... and my mobo has only two outputs: hdmi and dvi ... well, II do not worry too much (or should it be something to worry about it being that way?)
I send you some screenshots to confirm that everything seems fine (for now, ja!)
The only thing that seems strange to me is that (supposedly) the values ​​of "stolen, fbmem" etc ss you can see in the previous parameters, but they do not seem to reflect or are different (as can be seen in hackintool screenshot)
for now, I tried the screen off and the sleep mode, and apparently it goes back well without black screen
Well, if everything seems perfect, I continue with this configuration ... but in any case I am attentive to advice and suggestions!
Many thanks for all that help, friends!
Post by MaLd0n » 20 Mar 2019, 14:54
kultrun, to avoid glitches, use iMac18,1 smbios
good job
kultrun
Donator
Donator
Post by kultrun » 20 Mar 2019, 15:31
Thanks, MaLd0n!
I use actually the MacMini 8,1 definition and there are not glitches... but if you recommed iMac 18,1, maybe I'll try
the only thing is what I said... I change the parameters in hackintool to:
in VRAM section... but now, when I reboot (everything is ok) in hackintool shows: STOLEN 19 Mb / FBMem 9 Mb / VRAM 2048 Mb / Max Stolen 67 Mb / Total Stolen 20 Mb / Total Cursor 1 Mb / Max Overall 68 Mb
It seems like that wehn I open hackintool and select "framebuffer -- MacOs 10.14"
EDIT: In my Mobo I can set DVMT in 128 MB... So do I need to use the "DVMT pre-alloc 32 MB" option in hackintool? this option has something to do with the vram variables?
I don't have 4K monitor or screen... do I need to use the option "VRAM 2048 MB" ??
many thanks!
20 Mar 2019, 14:54
Post by MaLd0n » 20 Mar 2019, 15:56
kultrun, dvmt, use it in mobiles with bios/uefi without some options, in desktop just up in bios/uefi
VRAM 2048 MB, i think is only cosmetic, i don't see any diff
kultrun
Donator
Donator
Post by kultrun » 20 Mar 2019, 16:04
thanks MaLdon! I will do those changes for a final config.plist...
I'll tell you if everything is ok! :guitar :guitar
20 Mar 2019, 15:56
kultrun
Donator
Donator
Post by kultrun » 20 Mar 2019, 17:04
Hi, all is ok and fine in my hack!!
I attach the config.plist if anybody needs it... My mobo GA Z370 HD3 (two connectors: HDMI and DVI) and CoffeLake i5 8400 - Intel UHD 630
Just the last question: can I update Lilu kext and there are no issues with that? I suppose is better have the lastet lilu.ket... bu just in case, I ask :)
thanks a lot for all the help and dedication!
saludos desde Argentina
erroruser
Post by erroruser » 20 Mar 2019, 17:27
kultrun, yes you can update all kexts if they need to be
:superman :superman
kultrun
Donator
Donator
Post by kultrun » 20 Mar 2019, 19:26
Many thanks erroruser!
I don't know if it's necessary update some kets like Lilu, when everything seems to work great, but... many times users recommend that
something to advise: I do not know if it is related to having generated the patch for the video or with the current (newer) version of hackintool, but I had to generate the USB patch again because all the ports appeared as "internal"
saludos!
20 Mar 2019, 17:27
adivajra
Geek
Geek
CPU: i5 9600K
Motherboard: ASUS TUF Z390M Gaming
GPU: UHD 630
Post by adivajra » 22 Mar 2019, 12:36
I just update to 10.14.3, but before that I have changed the config on my PC I put another SSD 1Tb and installed win10 on it and I put my graphic card on that pc (msi rtx 2080).
Since I plug the card I have some issue with graphic on the Hackintosh part of the pc, the igpu uhd 630 is no more recognized like it was before I installed the DSDT from Mald0n
here's a screenshot [External Link Removed for Guests]
thanks for your help
also after the update I need to use a USB to boot into the hack now I have re-do the disablehibernate and master-command, and I just update clover too, I hope I will be able to boot normally now
Post by MaLd0n » 23 Mar 2019, 14:15
adivajra, POST ONE FULL DUMP
--Run_Me
we need disable nvidia in macos
gilgamet
CPU: i5-7200u
Motherboard: LNVNB161216
GPU: 110Mx
Post by gilgamet » 23 Mar 2019, 18:14
1 things to say :frantics :frantics :superman
Grrrrrr after many test hdmi makes the laptop in freeeeeeeeze mode ,,,,, :evil: :twisted:
Post by MaLd0n » 23 Mar 2019, 18:54
gilgamet, :lol: :mrgreen:
adivajra
Geek
Geek
CPU: i5 9600K
GPU: UHD 630
Post by adivajra » 24 Mar 2019, 09:18
ok thank you Mald0n
here's the runme file : [External Link Removed for Guests]
Post by MaLd0n » 24 Mar 2019, 13:14
adivajra,
Return to “Patches and tricks”
