[Guide] Hackintool - Video Patch - Fast and Easy Solution
kutchachhikhen
CPU: Intel i5-3570
Motherboard: OptiPlex 7010
GPU: Intel HD2500
Post by kutchachhikhen » 14 Oct 2019, 17:14
I have a Dell Otiplex 7010 with Intel HD 2500.
I followed your guide, but it boots up to the apple logo, then the screen goes black and only the cursor is visible. Please help.
Post by MaLd0n » 14 Oct 2019, 17:19
kutchachhikhen, i think intelhd2500 don't work in any macos
alanzito3d
CPU: i5 8400
Motherboard: Gigabyte B360M AORUS GAMING 3
GPU: Gigabyte RX 580 8G
Post by alanzito3d » 17 Oct 2019, 17:11
Boa tarde amigos, tenho umas dúvidas:
Seu eu aplicar esse Patch, eu mantenho a capacidade de Quick Sync com minha RX 580. Se sim, qual a vantagem em relação a esse método [Local Link Removed for Guests]
Mudando o processador para um i9 9900k (lembrando que quero manter o Quick Sync com minha RX 580) continuo usando os passos descrito para Gen 8: Coffee Lake (Intel UHD Graphics 630) ou tenho que buscar outra solução?
Desde já agradeço ao constante suporte e ensinamentos.
Post by MaLd0n » 17 Oct 2019, 19:35
alanzito3d, se vc usar a última versão da weg, é só ativar a intelhd, a kext hj em dia já injeta as propriedades
alanzito3d
CPU: i5 8400
Post by alanzito3d » 17 Oct 2019, 21:33
MaLd0n, Então eu só preciso fazer o [Guide] Hardware Encoder / Hardware Decoder / Video Processing / HEVC Support / Intel Quick Sync? Esse patch do hackintool serve somente para quem não tem GPU dedicada?
Post by MaLd0n » 17 Oct 2019, 21:38
alanzito3d, não serve, não precisa
aryaone
CPU: Intel core i3-8100
Motherboard: gigabyte B360M
GPU: RX 570
Post by aryaone » 25 Oct 2019, 02:31
MaLd0n , i use dGPU RX570 4GB, now i want to disable DVI port of my dGPU for some reason. can you guide me to patch my radeon frame buffer to disable my DVI Port?
here is my send.me file
Post by MaLd0n » 25 Oct 2019, 02:49
aryaone, why u need disable it? use last weg kext and let this driver work
WhateverGreen.kext.zip
droktulft
CPU: i5-3470S
Motherboard: HP 8300 USDT
GPU: intel hd 2500
Post by droktulft » 25 Oct 2019, 20:38
kutchachhikhen,
Did you look at this ooooold topic? it's for *Montain Lion*
]The following method only works for OS X Mountain Lion 10.8.3 and newer
it recommends to add
<key>device-properties</key>
<string>7f0000000100000001000000730000000200000002010c00d041030a000000000101060000027fff04002c0000004100410050004c002c00690067002d0070006c006100740066006f0072006d002d00690064000000080000000b006601140000006800640061002d0067006600780000000d0000006f6e626f6172642d31</string>
to your pslist
and use multishit to go macmini6.2 in system definition
I've checked in [External Link Removed for Guests] but I can't find anything with hd 2500, good luck!
source:
rositaott
Donator
Donator
CPU: Intel(R) Core(TM) i3-8100
Motherboard: Asus Prime H310M-D R2.0
GPU: Intel HD 630 BuiltIn
Post by rositaott » 11 Nov 2019, 11:48
Hi MaLd0n, I'm still using on-board GPU, will this be able for my VGA port to work, currently I'm connected to HDMI port, and I want to use VGA for another monitor. Tried different patches, but main display got glitched or magenta sometimes (after trial & error patching), but VGA still no output.
NoteBook | Acer E5-473G | i5-5200U | IntelHD5500
Post by MaLd0n » 11 Nov 2019, 17:04
rositaott, vga same as dp, try change connectors
rositaott
Donator
Donator
Post by rositaott » 12 Nov 2019, 01:53
11 Nov 2019, 17:04
can you remote my pc :cry:
Post by MaLd0n » 12 Nov 2019, 02:32
rositaott, u need test, connect, disconnect cable from outputs and check with hackintool
rositaott
Donator
Donator
Post by rositaott » 12 Nov 2019, 02:43
12 Nov 2019, 02:32
problem is no other highlighted even I connect/disconnect 2nd monitor
rositaott
Donator
Donator
Post by rositaott » 12 Nov 2019, 08:34
the only port detects my 2nd monitor is index 0 with bus Id 0x00 LVDS (but i'm sure not for desktop), hoping and tried all different bus Id, downgraded to Mojave still no luck for having 2nd display on VGA port :help
Post by MaLd0n » 12 Nov 2019, 15:43
rositaott, is a very personal patch, u need many test for check correct
Ignis
CPU: i3 7100
Motherboard: Gigabyte H170N
GPU: Intel HD 630
Post by Ignis » 12 Nov 2019, 22:29
MaLd0n, can you please take a look at my configuration which is Mojave 10.14.6, i3 7100, Gigabyte H170N board, and NVME Samsung EVO Plus, Graphic that I use is integrated intel HD 630. I have trouble with Framebuffer. Board have two HDMI and one DVI ports. I manage to patch Framebuffer with Hackintool so that both HDMi ports are working together, but DVI port I just can't get it to work. It's showing loading bar while booting, but in half loading goes off.
Second problem is that wake after sleep is not working..but that is off topic here I think
Thank you.
Post by MaLd0n » 13 Nov 2019, 00:04
Ignis, first use a olarila folder with correct and clean config
apply ur video patch and extract send_me
rositaott
Donator
Donator
Post by rositaott » 13 Nov 2019, 13:17
12 Nov 2019, 15:43
yeah, I'm still trying as of this writing :lol: , but i can't figure out yet and find the correct patch, only if there's just better way to get this done :wallbash headache :lol:
joniguilherme
CPU: i7 8086k
Motherboard: Z370-E
GPU: 1080 ti
Post by joniguilherme » 16 Nov 2019, 03:43
reupload Hackintool 2.1.0 pls
Return to “Patches and tricks”
