[Guide] Hardware Encoder / Hardware Decoder / Video Processing / HEVC Support / Intel Quick Sync
juanvascas
CPU: i7-8750H
Motherboard: HM370
GPU: Gtx 1060 Max-Q
Post by juanvascas » 26 Jun 2019, 20:08
I mean what app shows you that or what to type in terminal to see that?
Post by MaLd0n » 26 Jun 2019, 21:09
juanvascas, [Local Link Removed for Guests]
-Donated? Send me one PM-
juanvascas
CPU: i7-8750H
Motherboard: HM370
GPU: Gtx 1060 Max-Q
Post by juanvascas » 26 Jun 2019, 21:18
Thanks it seems I have hardware acceleration! :crazy:
I am using SSDTs right now, any help getting a proper DSDT?
Post by MaLd0n » 26 Jun 2019, 21:41
juanvascas, ssdt for what? is a nonsense way
use a full dsdt patched
juanvascas
CPU: i7-8750H
Motherboard: HM370
GPU: Gtx 1060 Max-Q
Post by juanvascas » 26 Jun 2019, 21:59
I know is better to use a patched dsdt, as your one post I read from you of the benefits of having a patched dsdt.
I am not good at patching the dsdt, can you patch my dsdt?
Post by MaLd0n » 27 Jun 2019, 00:11
juanvascas, check if work, replace full efi, reboot and extract new send_me
EFI.zip
juanvascas
CPU: i7-8750H
Motherboard: HM370
GPU: Gtx 1060 Max-Q
Post by juanvascas » 27 Jun 2019, 02:24
It booted really slow and to a black screen.
Post by MaLd0n » 27 Jun 2019, 12:14
juanvascas, repair permission/rebuild cache
juanvascas
CPU: i7-8750H
Motherboard: HM370
GPU: Gtx 1060 Max-Q
Post by juanvascas » 27 Jun 2019, 16:53
Tried so and no luck, tried different config.plist and none worked not even my current one. May it be the dsdt?
Post by MaLd0n » 27 Jun 2019, 17:22
juanvascas, u can test
juanvascas
CPU: i7-8750H
Motherboard: HM370
GPU: Gtx 1060 Max-Q
Post by juanvascas » 27 Jun 2019, 19:42
Hmmm I am not sure then what it is, I can boot with my config.plist and Bios.aml, but I can’t with the dsdt.aml nor the Bios.aml with your config.plist
I can boot with your coffe lake mobos 300 efi folder, does it work if I get a new Send Me with it?
Post by MaLd0n » 27 Jun 2019, 21:51
juanvascas, yes
juanvascas
CPU: i7-8750H
Motherboard: HM370
GPU: Gtx 1060 Max-Q
Post by juanvascas » 27 Jun 2019, 23:42
Extracted using the notebooks skylake+ efi folder.
Post by MaLd0n » 28 Jun 2019, 01:18
juanvascas,
enable ECDV to EC patch
juanvascas
CPU: i7-8750H
Motherboard: HM370
GPU: Gtx 1060 Max-Q
Post by juanvascas » 28 Jun 2019, 01:33
Thanks man! It seems that my laptop is running really smooth now! I will get the voodooi2c patch and it it’s reaaady :crazy: :crazy: :crazy:
Post by MaLd0n » 28 Jun 2019, 12:04
juanvascas, extract new sendme
juanvascas
CPU: i7-8750H
Motherboard: HM370
GPU: Gtx 1060 Max-Q
Post by juanvascas » 28 Jun 2019, 14:26
Here you go sir!
Post by MaLd0n » 28 Jun 2019, 14:42
juanvascas, replace two files
Arquivo Comprimido.zip
juanvascas
CPU: i7-8750H
Motherboard: HM370
GPU: Gtx 1060 Max-Q
Post by juanvascas » 28 Jun 2019, 15:46
I get this according to the kernel log: VodooI2CControllerDriver::VoodooI2CDeviceNub Warning: Incompatible APIC interrupt pin (0x33 > 0x2f) and no GPIO interrupts found; if your chosen satellite implements polling then VoodooI2CDeviceNub will run in polling mode.
Post by MaLd0n » 28 Jun 2019, 16:37
juanvascas, is full load
Return to “Patches and tricks”
