Extract DSDT / Windows
adrimur
CPU: i7 9700K
Motherboard: Z390 Aorus Pro
GPU: Rx570
Post by adrimur » 13 Jun 2019, 08:06
12 Jun 2019, 23:39
adrimur, replace full efi, reboot
EFI.zip
(2.55 MiB) Downloaded 1 time
My Friend, the usb is work perfect, but the bluetooth don't work, thank you for your help and time, my beer for you ;)
Post by MaLd0n » 13 Jun 2019, 11:48
adrimur, what bt u have? Broadcom?
adrimur
CPU: i7 9700K
GPU: Rx570
Post by adrimur » 13 Jun 2019, 12:27
13 Jun 2019, 11:48
Unread post by MaLd0n » 13 Jun 2019, 13:48
Yes, this is it, thank you Mald0n
Post by MaLd0n » 13 Jun 2019, 12:33
adrimur, here
michaelisaias
CPU: i7 3770
Motherboard: AsRock z68 Extreme3 Gen3
GPU: GTX 970 (2xSLI)
Post by michaelisaias » 13 Jun 2019, 23:10
Hi MaLd0n. I tried to fix the DSDT.aml but i dont know how to do it... Can you help me?
Lendo alguns posts anteriores vi que você fala português :P
Se precisar de mais alguma informação sobre o hardware que tô usando é só pedir.
Não sei se ajuda mas aqui tem umas informações:
O i7 3770 tem um overclock (4.1Ghz todos os núcleos / 4.3Ghz alternado)
Placa mãe tá com a ultima BIOS L2.31A (Beta)
Estou usando o High Sierra 10.13.6 (17G7024)
Consegui instalar o webdriver da gtx 970, áudio pela hdmi, áudio pela placa de Som ALC892, USB parecem estar funcionando normal.
Enquanto aguardo a sua resposta, vou continuar tentando aplicar os patchs. Até agora só consegui corrigir o ´Possible operator timeout is ignored´.
Post by MaLd0n » 14 Jun 2019, 00:05
michaelisaias,
change EHC1 to EH01
45484331
45483031
change EHC2 to EH02
45484332
45483032
change GFX0 to IGPU
47465830
49475055
change HECI to IMEI
48454349
494d4549
change SAT0 to SATA
53415430
53415441
michaelisaias
CPU: i7 3770
Post by michaelisaias » 14 Jun 2019, 00:21
MaLd0n, Muito obrigado. Vou testar.
adrimur
CPU: i7 9700K
GPU: Rx570
Post by adrimur » 17 Jun 2019, 10:35
13 Jun 2019, 12:33
adrimur, here
[External Link Removed for Guests] ... rc/master/
puff is imposible.. but thank you...
Edit: I can send for airdrop with my iPhone to Mac, but Mac to iPhone no.. any idea? thank you
always Discoverable :Off. how can I plug on???
Post by MaLd0n » 17 Jun 2019, 14:27
adrimur, use bluetooth kexts in library/extensions and rebuild cache
primeroasir2019
CPU: Intel Core 2 Quad Q8200
Motherboard: Intel Corporation DG35EC
GPU: ATI Radeon HD 4600 Series 512M
Post by primeroasir2019 » 19 Jun 2019, 07:47
Hi, here mi DSDT
Post by MaLd0n » 20 Jun 2019, 00:04
primeroasir2019,
karakino
CPU: 2x Xeon E5 2690 v4
Motherboard: Asus Z10PE-D16 WS
GPU: Quadro K5000 + Tesla K20c
Post by karakino » 21 Jun 2019, 22:49
Hi mister! :)
My first time here on the olarila forum! I am desperately searching for a way to make my Z10PE-D16 WS (bios 3407) with 2x Xeon E5 2690 v4, Quadro K5000, Tesla K20c to work with Mojave. But with every release i tried i never reach the installer... Now i want to try with the Olarila raw 10.14.5 one but i don't know if a patched dsdt is needed to modify the usb installer... In the meantime i'm burning the raw image with etcher. As soon as i'll finish i'll send u the file here to u to see if it is possible to make something with this beast! can u do that plz if u have some spare time?
wanted to use blender with all of that power at my disposal...
let me know mald0n!
bye and thanks! ^__^
Post by MaLd0n » 21 Jun 2019, 23:41
karakino, try and let me know
karakino
Post by karakino » 22 Jun 2019, 07:59
Here it is. I hope it is possible to build something with this...
Thanks man! :)
Post by MaLd0n » 22 Jun 2019, 11:10
karakino,
u need post one photo at kp/error screen
karakino
Post by karakino » 22 Jun 2019, 18:41
Its an error just like this:
rootdevice uuid Is '*******************'
End init bootstruct
Start loadramdisk
End loadramdisk
Start finalizebootstruct
Start randomseed
End randomseed
These are the last lines that i see in verbose...
karakino
Post by karakino » 23 Jun 2019, 10:46
that error was with another release... now that i was able to install mojave olarila raw image into a 20gb partition of an ssd hd, i got past the end randomseed and get this instead:
Post by MaLd0n » 23 Jun 2019, 16:13
karakino, is a real problem with some supermicro, asus mobo for dual xeon
karakino
Post by karakino » 23 Jun 2019, 19:04
so u think that a dsdt for my z10pe-d16 ws could not be realized without some major pain in the ***? damn... it's ok! thanks a lot anyway! :)
i hope that i can get past that error without a dsdt. i tried two releases, one olarila and another one and olarila was the only one to at least let me see some more verbose log... but i still can't get to the installer screen. do u think this ioacpifamily kernel panic could be thrown away? or maybe i must take away 1 hardware piece at a time to see what happens?
if u have any tips to spare i'm all ears like a Ferengi... :D
enjoybrands
CPU: i5 7400
Motherboard: GA H110-M Gaming 3
GPU: AMD RX 570
Post by enjoybrands » 25 Jun 2019, 14:34
Sending here.
Can u help me to make it work on mojave?
Thank you! Obrigado!
[Edit] Troquei o arquivo. No .RAR coloquei o .bin e o .aml
Se puder, me ajuda a fazer meu sistema funcionar bem no mojave.
Se n conseguir, vou ter que comprar um macbook muito inferior ao meu pc.
Depois de vc me enviar a DSDT, o que devo fazer? Carregar no Clover?
Agradeço desde já!
Return to “Patches and tricks”
