🎉 NEW Discord server!
Extract DSDT / Windows
Post by MaLd0n »
--Donations via PayPal--
Use RWEverything
---Go to Access, ACPI Tables
---Select DSDT, bin
---Rename .bin to .aml
kostas20
CPU: intel 4005u
Motherboard: dell
GPU: intel hd 4400
Post by kostas20 »
So , to be clear.
We can use this program in windows , save dsdt.bin , rename it to aml , and then we have a working dsdt for hackintosh ? Is this dsdt the best we can have for our systems ?
Post by MaLd0n »
is just for extract, windows don't need patches, u need rape table after extract
kostas20
CPU: intel 4005u
Motherboard: dell
GPU: intel hd 4400
Post by kostas20 »
Oh.
And what can we do with this dsdt.aml ?
Post by MaLd0n »
u need edit, if only extract is same from bios, no diff
kostas20
CPU: intel 4005u
Motherboard: dell
GPU: intel hd 4400
Post by kostas20 »
Attaching here.
Maybe you can do your magic ?
Post by MaLd0n »
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests] Attaching here.
minhthanh5555555555
CPU: i5
Motherboard: broadwell
GPU: 5200u
Post by minhthanh5555555555 »
After successfully extracting the DSDT.aml file, I just replaced the EFI with all the hackintosh problems going to be fixed, is that so?
Post by MaLd0n »
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests] After successfully extracting the DSDT.aml file, I just replaced the EFI with all the hackintosh problems going to be fixed, is that so?
if u don't edit, is a ame from ur bios, don't have any diff. U need patched.
minhthanh5555555555
CPU: i5
GPU: 5200u
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests] if u don't edit, is a ame from ur bios, don't have any diff. U need patched.
Can you help me fix it?
Post by MaLd0n »
i fix it for u some times, use same file
minhtu138
CPU: i3 8100
Motherboard: MSI B360 Plus gaming
GPU: gtx 950
Post by minhtu138 »
Dell sudio 1737 eGPU code 12
pack "PCI0"
i wanna fix PCI to PCI bridge. via code behind DWordMemory (ResourceProducer, PosDecode...
QWordMemory (ResourceProducer, PosDecode, MinFixed, MaxFixed, Cacheable, ReadWrite,
0x0000000000000000, // Granularity
0x0000000C20000000, // Range Minimum
0x0000000E0FFFFFFF, // Range Maximum
0x0000000000000000, // Translation Offset
0x00000001F0000000, // Length
,, , AddressRangeMemory, TypeStatic)
thanks you a lot Mr!
Added in 43 minutes 8 seconds:
i fix it done! :D :D :D :D
Post by MaLd0n »
maxRange - minRange + 1 = length
minhtu138
CPU: i3 8100
GPU: gtx 950
Post by minhtu138 »
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests] maxRange - minRange + 1 = length
Yes! I fix it like that! Thanks Mr. <3
slipttees
CPU: Intel Core i5
Motherboard: Dell Optiplex 790
GPU: Zotac 8400GS
Post by slipttees »
Extract DSDT / Linux
Boot pelo livecd ou pendrive.
sudo apt update
sudo apt install iasl
sudo cat /sys/firmware/acpi/tables/DSDT > dsdt.aml
sudo iasl -d dsdt.aml
Após isso é gerado outro arquivos chamado dsdt.dsl
:boxing
Dell Optiplex 790 - iMac12,1 - High Sierra 10.13.6 - Ok
Intel(R) Core(TM) i5-2400 CPU @ 3.10GHZ - Ok
Intel HD Graphics 2000 - Vesa Driver / Replace Zotac 8400GS 256MB - Clover + NvidiaInject - OK
DDR3 4.0GB 1333Mhz - Ok
Realtek ALC269 - AppleALC.kext - Ok
Broadcom BCM43224 - AirportBrcmFixup.kext - Ok
Intel 82579LM Gigabit Ethernet - IntelMausiEthernet.kext - Ok
HDD Hitachi 500GB - Ok
Post by MaLd0n »
:guitar
hady2010
CPU: Intel Core i5
Motherboard: asrock fatality profissional
GPU: nvidia gtx 1050ti
Post by hady2010 »
Thank you very much
Post by MaLd0n »
Welcome!
Enjoy!
Amorim
CPU: 6700K
Motherboard: Asus Pro Gaming Z170
GPU: GTX 1070
Post by Amorim »
Can you work your magic?
DSDT.rar
Vlw
Post by MaLd0n »
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests]Can you work your magic?
Return to “Patches and tricks”
