Mojave / Catalina on GA-Z370 HD3 + i7-8700K / FULL DSDT Patch
aldebaran
CPU: i5 8600k
Motherboard: Z370 gaming 3
GPU: RX560
Mojave on GA-Z370 HD3 + i7-8700K / FULL DSDT Patch
Post by aldebaran » 22 Apr 2019, 22:06
MaLd0n,
Thank you. I will try it.
Regards,
Aldebaran
Post by MaLd0n » 22 Apr 2019, 23:04
gugadj, desktop com DGPU não precisa, a IGPU é somente pra hardware accel
Added in 15 seconds:
aldebaran, ;) :smoke:
-Donated? Send me one PM-
aldebaran
CPU: i5 8600k
GPU: RX560
Post by aldebaran » 23 Apr 2019, 09:47
MaLd0n,
My LIRA system is working now perfectly.
Now I am sending you Send me Andromeda file for my second system (of cause + beer)
It is Gigabyte Z370-Gaming 3 board with i5 8600K and RX 560.
Can you please make patched DSDT file for it?
Regards,
Aldebaran
Post by MaLd0n » 23 Apr 2019, 13:22
aldebaran,
maxi_villa
CPU: i3 8100
Motherboard: Gigabyte Z370 HD3
GPU: HD 630
Post by maxi_villa » 23 Apr 2019, 17:41
Hello, I'm new at this. My configuration is similar to yours, GA Z370 HD3 i3 8100 HD630. I do not get boot. Could you help me?
Bios F12
Post by MaLd0n » 23 Apr 2019, 19:51
maxi_villa, [Local Link Removed for Guests]
aldebaran
CPU: i5 8600k
GPU: RX560
Post by aldebaran » 24 Apr 2019, 12:13
MaLd0n,
Thank you. Everything is working.
Regards,
Aldebaran
maxi_villa
CPU: i3 8100
GPU: HD 630
Post by maxi_villa » 24 Apr 2019, 17:23
23 Apr 2019, 19:51
viewtopic.php?p=81402#p81402
Mojave already works for me, thank you very much :D :D . Missing optimize I send runme?
Post by MaLd0n » 24 Apr 2019, 17:43
maxi_villa, yes, extract send_me
maxi_villa
CPU: i3 8100
GPU: HD 630
Post by maxi_villa » 25 Apr 2019, 23:54
24 Apr 2019, 17:43
ok, thank you very much I do not speak English sorry. then I invite the beer
hdmi audio does not work
Post by MaLd0n » 26 Apr 2019, 00:10
maxi_villa, HDMI AUDIO u need check with hackintool.app
maxi_villa
CPU: i3 8100
GPU: HD 630
Post by maxi_villa » 27 Apr 2019, 18:28
26 Apr 2019, 00:10
ok,that appears in Hackintool app
skav
CPU: i5 8400
Motherboard: GA Z730 HD3
GPU: MSI Radeon RX 580 8 GB
Post by skav » 04 May 2019, 10:04
Hi MaLd0n,
how are you ?
In some case, when the computer sleep and resume, or when the speaker is off when pc startup the audio don't work.
In audio device i see the headphones out correctly, I try to select and deselect but the audio don't work.
Do you have a solution ?
Post by MaLd0n » 04 May 2019, 13:44
skav, use codeccommander to avoid it
tranduchoan
CPU: Intel Core i5 3570k
Motherboard: Asrock z68 extreme3 gen3
GPU: Gigabyte GTX 660
Post by tranduchoan » 06 May 2019, 21:14
Hi MaLd0n! Can u help me for my DSDT?
Asus Rog Strix z370-i Gaming
i7 8700k
intel UHD 630
Thank u very much!
Post by MaLd0n » 07 May 2019, 00:23
tranduchoan,
skav
CPU: i5 8400
Post by skav » 12 May 2019, 17:20
04 May 2019, 13:44
Many Thanks MaLd0n,
I resolve it.
I have insert in config.plist the lines below:
<key>Default</key>
<dict>
<key>Check Infinitely</key>
<false/>
<key>Check Interval</key>
<integer>3000</integer>
<key>Custom Commands</key>
<array/>
<key>Perform Reset</key>
<true/>
<key>Perform Reset on External Wake</key>
<true/>
<key>Perform Reset on EAPD Fail</key>
<false/>
<key>Send Delay</key>
<integer>300</integer>
<key>Update Nodes</key>
<true/>
<key>Sleep Nodes</key>
<true/>
</dict>
skav
CPU: i5 8400
Post by skav » 12 May 2019, 18:02
Hi MaLd0n,
I'd like to buy the graphic card, bluetooth adapter and wifi adapter to use with
my gigabyte Z370 HD3 and Mojave, what should I buy in your opinion ?
I suppose this:
MSI Radeon RX 580 ARMOR 8G
WIFI and Bluetooth
Post by MaLd0n » 12 May 2019, 19:15
skav, goto rx590, same price
wifi looks good
skav
CPU: i5 8400
Post by skav » 17 May 2019, 12:08
04 May 2019, 13:44
Hi MaLd0n,
12 May 2019, 18:01
Many Thanks MaLd0n,
I resolve it.
<key>Default</key>
<dict>
<false/>
<array/>
<true/>
<true/>
<false/>
<true/>
<true/>
</dict>
I MaLd0n,
I thought it works but I checked better and the problem persist. Non audio, after sleep. I insert in config.plist the line above. I see in start log codecommander. I try to update AppleALC.kext , but the audio in this case don't work for nothing. I think I'm wrong sometingh. The problem came out in one of the last OSX update, it worked before.
Return to “Mojave (10.14)”
