No audio from board's sound card with AppleALC
noisegate
CPU: i7 4930k
Motherboard: X79 Deluxe
GPU: RX 580
Post by noisegate » 18 Sep 2019, 15:34
Right, was from Sierra but I installed Mojave over it, maybe I can find what version it was, I'll check.
onemanosx
Post by onemanosx » 18 Sep 2019, 15:36
18 Sep 2019, 15:34
You can try a clean install and/or test with the previous releases of AppleALC here [External Link Removed for Guests]
MSI B360 Gaming Arctic
noisegate
CPU: i7 4930k
GPU: RX 580
Post by noisegate » 18 Sep 2019, 15:41
A clean install of Sierra? Not sure I'm following you
Yes I'm looking already but unless I'm mistaken, no information is given regarding the corresponding version of MacOS
What bothers me is many people have ALC1150 work with Mojave and I can't replicate what seems to work elsewhere
onemanosx
Post by onemanosx » 18 Sep 2019, 15:49
18 Sep 2019, 15:41
Just pick a release and test. Kext will work from El Capitan and above
18 Sep 2019, 15:41
When it comes to major update, a good practice to fresh install Mojave by reformat of SSD rather than upgrade from Sierra by overriding.
noisegate
CPU: i7 4930k
GPU: RX 580
Post by noisegate » 18 Sep 2019, 18:31
I’ll try a few versions and see how it goes.
Ok I see, yes I always format the install volume when upgrading the system.
Thanks again for your time!
noisegate
CPU: i7 4930k
GPU: RX 580
Post by noisegate » 22 Sep 2019, 13:22
onemanosx, a quick update to say older versions don't work either. I'm giving up for now, as I'm out of options...
Thanks for your time anyway
onemanosx
Post by onemanosx » 22 Sep 2019, 16:02
noisegate, i hope you'll get it sorted out soon.
Return to “Mojave (10.14)”
