No audio from board's sound card with AppleALC
noisegate
CPU: i7 4930k
Motherboard: X79 Deluxe
GPU: RX 580
Post by noisegate » 18 Sep 2019, 11:49
Mojave 10.14.6
AppleALC v1.4.1
Lilu v1.3.8
CodecCommander v2.7.1
Lilu and AppleALC are both installed in /EFI/CLOVER/kexts/Other
My board uses ALC1150
I tried all layouts as boot args, none of them worked
Any pointers please? :)
Thank you
Added in 3 minutes 48 seconds:
@MaLd0n
I forgot we already discussed the subject here and you said you edited codeccommander for ALC1150.
Sadly I can't find it anywhere. Is there a way you could send me a link if you can find it again?
Thank you in advance!
onemanosx
Post by onemanosx » 18 Sep 2019, 12:10
noisegate, Working ids are as in this link [External Link Removed for Guests]
You should be able to see the intended layout id is successfully injected using ioreg (whether or not audio is working). Can you confirm?
MSI B360 Gaming Arctic
noisegate
CPU: i7 4930k
GPU: RX 580
Post by noisegate » 18 Sep 2019, 12:46
Thanks for your reply, what should I be looking for, where is the injected layout supposed to show?
onemanosx
Post by onemanosx » 18 Sep 2019, 12:49
18 Sep 2019, 12:46
In this example, layout id 1 is injected. Do note in ioreg the id is shown as HEX.
noisegate
CPU: i7 4930k
GPU: RX 580
Post by noisegate » 18 Sep 2019, 12:59
Thanks! Layout id 1 is indeed injected
Here's where I'm at at the moment:
onemanosx
Post by onemanosx » 18 Sep 2019, 13:18
18 Sep 2019, 12:59
indeed you are trying to inject layout id 1. But what does ioreg show?
noisegate
CPU: i7 4930k
GPU: RX 580
Post by noisegate » 18 Sep 2019, 13:24
Sorry my post was confusing. Layout id 1 does show as injected in ioreg:
onemanosx
Post by onemanosx » 18 Sep 2019, 13:26
noisegate, change layout id. Reboot. Then look at ioreg if layout id changes. If it does, clover injection is not the issue.
noisegate
CPU: i7 4930k
GPU: RX 580
Post by noisegate » 18 Sep 2019, 13:36
I went for layout id 2, both as a boot arg and in devices > audio > inject
It shows as injected in ioreg, so like you said it's not the issue
Any idea where to look? MaLd0n did mention an edited codeccommander for ALC1150 but I can't find it here or elsewhere.
Thanks again for your time
onemanosx
Post by onemanosx » 18 Sep 2019, 13:46
noisegate, As the saying goes, use latest Lilu and AppleALC kexts. Where do you install the kexts? Clover/kexts/other or L/E?
Codec Commander: [External Link Removed for Guests]
noisegate
CPU: i7 4930k
GPU: RX 580
Post by noisegate » 18 Sep 2019, 13:49
I use latest kexts in the right places (please check original post)
I'm a bit lost... :|
onemanosx
Post by onemanosx » 18 Sep 2019, 13:56
18 Sep 2019, 13:49
Dont worry. If you are certain you are had not modified native AppleHDA, you are in the right track with Lilu and AppleALC in Clover.
Extract a sendme archive.
noisegate
CPU: i7 4930k
GPU: RX 580
Post by noisegate » 18 Sep 2019, 14:01
AppleHDA is indeed left untouched
Thanks again, onemanosx
onemanosx
Post by onemanosx » 18 Sep 2019, 14:04
noisegate, Are you just uploading the ioreg? That isnt useful.
Run this app [Local Link Removed for Guests]
And upload sendme folder on google drive.
noisegate
CPU: i7 4930k
GPU: RX 580
Post by noisegate » 18 Sep 2019, 14:08
ioreg dump keeps failing
onemanosx
Post by onemanosx » 18 Sep 2019, 14:11
18 Sep 2019, 14:08
Allow permissions in Security Pref
noisegate
CPU: i7 4930k
GPU: RX 580
Post by noisegate » 18 Sep 2019, 14:14
onemanosx
Post by onemanosx » 18 Sep 2019, 15:18
noisegate, Looks like audio is enabled with ID 2. Nothing notably wrong in config or ioreg as far as I can see here.
noisegate
CPU: i7 4930k
GPU: RX 580
Post by noisegate » 18 Sep 2019, 15:21
Thank you onemanosx, then I don't understand what's wrong.
All I hear are small clicks and pops when I play a file. Same config as what used to work on previous versions of MacOS. Weird...
onemanosx
Post by onemanosx » 18 Sep 2019, 15:30
18 Sep 2019, 15:21
Maybe go back to the version of AppleALC that works in that previous setup?
Return to “Mojave (10.14)”
