BCM94360CD Handoff/Continuity not working.
PaPaGriM
CPU: i5-9400
Motherboard: Gygabyte z390 M Gaming
GPU: Sapphire Pulse RX580 8GB
Post by PaPaGriM » 10 Sep 2019, 22:44
MaLd0n:
As previously spoken, the BCM94360CD is not working with continuity/handoff. The card is recognized natively, but not all capabilities are active. For example, on WiFi 802.11-AC is not working and on bluetooth "Handoff Supported" is set to no.
Hopefully you can take a look and figure it out.
Thanks in advance.
Post by MaLd0n » 10 Sep 2019, 23:56
PaPaGriM, use it for wifi
AirportBrcmFixup.kext.zip
BT check here
Return to “Mojave (10.14)”
