🎉 NEW Discord server!
can't install mackintosh mojave !
ali_madhoun
CPU: core i9 9900h
Motherboard: micro 360 m
GPU: rtx 2080 ti
Post by ali_madhoun »
hello everyone, double days ago i tried to install mackintosh mojave in my lenovo ideated 130 (core i3 7020u , 8gb ddr4 ram 2400, 1tb hdd)
the problem was a lot of sentances and in the bottom there is ++++++++++++++++++++++++++++
someone said that i should use OsxAptioFix3Drv-64.efi instead AptioMemoryFix-64.efi.
what does he mean?
how can i use OsxAptioFix3Drv-64.efi ?
i will be so grateful if anyone help me ..
erroruser
CPU: AMD Ryzen 7 3700X
GPU: Sapphire rx 5700 XT
Post by erroruser »
ali_madhoun, download this pack an follow guide to replace only what is needed
:superman :superman
ali_madhoun
CPU: core i9 9900h
GPU: rtx 2080 ti
12 May 2019, 17:55
can you be more specific please ?
erroruser
Post by erroruser »
down load the pack remove AptioMemoryFix-64 an replace with OsxAptioFix3Drv-64.efi in the efi of the installer
:superman :superman
ali_madhoun
CPU: core i9 9900h
GPU: rtx 2080 ti
12 May 2019, 18:26
AptioMemoryFix
bro that is the problem, i can't mount my usb drive"the installer" so i can't replace any of the efi files ..
Added in 10 minutes 28 seconds:
12 May 2019, 18:26
60080458_285852658966545_9056882354089361408_n.zip
Return to “Mojave (10.14)”
