problems on Mojave 10.14.6 installing on Lenovo Ideapad 110
onemanosx
Post by onemanosx » 29 Jul 2019, 22:03
29 Jul 2019, 18:03
i found those patchs in Acpi -> DSDT and disabled others. what about kernel and kernel patches?
just the renames. Leave the rest as is.
MSI B360 Gaming Arctic
pi2in3
CPU: core i7 8700k
Motherboard: MSI B360 Gaming Plus
GPU: GTX 1070
Post by pi2in3 » 30 Jul 2019, 04:10
29 Jul 2019, 22:03
i did, here is new SendME files. thanks
onemanosx
Post by onemanosx » 30 Jul 2019, 11:14
30 Jul 2019, 04:10
Looks good!
You might also want to implement custom USB kext/SSDT for a better USB connection and eliminate use of USB limit patch. Use Hackintool to generate.
Enjoy!
pi2in3
CPU: core i7 8700k
GPU: GTX 1070
Post by pi2in3 » 30 Jul 2019, 21:24
30 Jul 2019, 11:14
i dont understand about images above, also how to work with hackintool,i think it works nice except sleep/awake. BTW i appreciate all your helps and guides. thank you.
onemanosx
Post by onemanosx » 31 Jul 2019, 12:39
30 Jul 2019, 21:24
Check if sleep/wake is solved. Appreciate a new sendme files too.
Archive.zip
pi2in3
CPU: core i7 8700k
GPU: GTX 1070
Post by pi2in3 » 10 Aug 2019, 17:45
31 Jul 2019, 12:39
Archive.zip
thanks a'll check, would you help fixing some problems in Catalania on Asus F550? if so, i would create new post for it.
onemanosx
Post by onemanosx » 11 Aug 2019, 10:46
10 Aug 2019, 17:45
What problem? Catalina still in beta stage and has many unknown bugs. Wait for its final release ;)
pi2in3
CPU: core i7 8700k
GPU: GTX 1070
Post by pi2in3 » 17 Aug 2019, 19:35
31 Jul 2019, 12:39
i checked sleep/wake and doesn't work still but i don't need it. forget about it.
Added in 1 minute 47 seconds:
11 Aug 2019, 10:46
OK, i'm gonna install Mojave (then i'll tell you problems i would face) until final release of Catalania.
pi2in3
CPU: core i7 8700k
GPU: GTX 1070
Post by pi2in3 » 28 Aug 2019, 13:20
31 Jul 2019, 12:39
Archive.zip
sleep/wake is working now and don't have any idea why didn't work before. tnx man
also could you plz help me fix display and battery issues on Asus F550?
battery shows 0% and HD 4400 accelerator is not detected. here is the send me files.
onemanosx
Post by onemanosx » 28 Aug 2019, 15:33
pi2in3, Use files, reboot and extract new sendme
Archive.zip
pi2in3
CPU: core i7 8700k
GPU: GTX 1070
Post by pi2in3 » 06 Sep 2019, 18:38
28 Aug 2019, 15:33
the screen resolution is correct now.
new SenMe:
onemanosx
Post by onemanosx » 07 Sep 2019, 05:12
pi2in3, Looks like battery is working, too.
For graphics, please read on the link on how to achieve full acceleration.
pi2in3
CPU: core i7 8700k
GPU: GTX 1070
Post by pi2in3 » 07 Sep 2019, 19:22
tnx, i'll follow that.
battery indicator always shows 0%, no doubt.
onemanosx
Post by onemanosx » 07 Sep 2019, 23:02
07 Sep 2019, 19:22
There are things I am unsure and before I go further, see if battery works.
pi2in3
CPU: core i7 8700k
GPU: GTX 1070
Post by pi2in3 » 11 Sep 2019, 12:34
28 Aug 2019, 15:33
Archive.zip
doesn't work still, also i found out there is an weird issue with all USB ports:
USB Accessory Needs Power
connect, "USB_Device" to a usb port on this mac
onemanosx
Post by onemanosx » 13 Sep 2019, 23:24
pi2in3, Use my DSDT and config.plist.
Archive.zip
Return to “Mojave (10.14)”
