dedalus69
Post by dedalus69 » 22 Jun 2019, 12:16
consegui com esta config.plist pode dar uma olhada ?
GA Z77X UD4H
i5 3570
SSD 240 10.13.3
16GB DDR3 1333
650 GTX 2GB
MSI CUBI 23
i5-7200U
HD Grafik 620
4GB DDR4 2133 MHz
SSD 1: 128GB M.2WIN10
SSD 2: 128GB SATA 10.13.3
Lenovo E560
I5 6200U
SSD 240 10.3.3
Intel HD520
AMD R7 M370
12GB DDR3L 1600 mhz
Post by MaLd0n » 22 Jun 2019, 13:50
dedalus69, veja o vídeo
--Run_Me
-Donated? Send me one PM-
Blacket
CPU: Intel Core i7 6700-HQ
Motherboard: ASUS UX501VW
GPU: Nvidia GTX960M
Post by Blacket » 22 Jun 2019, 17:52
Hi MaLd0n.
Intel HD Graphics 530 Mobile For Laptop Asus UX501VW CPU Skylake
Graphics VRAM in 31MB :wallbash
I installed the following files in the installed location
Lilu.kext & whatevergreen.kext in S/L/E on SSD in High Sierra.
Device ID : 191B
Ig platform ID on Test :
0x191E0000
0x191E0003
0x19160000
0x19160002
0x19260000
0x19260004
0x19260007
0x19270000
0x19270004
0x191B0000
0x191B0006
0x193B0000
0x193B0005
0x19120000
Thank you for helping me
alireza
CPU: Intel i3-2120
Motherboard: GA-P61-USB3P
GPU: GeForce 210
Post by alireza » 22 Jun 2019, 23:23
Hey guys,
I tried to install this version on my computer but i get this error everytime: mac os mojave not installed on your computer. Is it related to my configuration? What can i do? Can i install previous version?
This is my config:
Motherboard: [External Link Removed for Guests]
Ram: 12gb DDR3
CPU: Intel i3-2120
Thanks for your help.
Post by MaLd0n » 23 Jun 2019, 03:41
Blacket,
<key>PciRoot(0)/Pci(0x02,0)</key>
			<dict>
				<data>AAAbGQ==</data>
				<key>#hda-gfx</key>
				<string>onboard-1</string>
				<key>#AAPL00,override-no-connect</key>
				<data></data>
				<key>#AAPL00,override-no-edid</key>
				<data></data>
				<key># DVMT-prealloc</key>
				<string>32MB BIOS, 19MB framebuffer, 9MB cursor bytes (credit RehabMan)</string>
				<integer>1</integer>
				<data>AAAwAQ==</data>
				<key>framebuffer-fbmem</key>
				<data>AACQAA==</data>
				<key>## @0 LVDS-&gt;DP</key>
				<string></string>
				<key>#framebuffer-con0-enable</key>
				<key>#framebuffer-con0-type</key>
				<data>AAQAAA==</data>
				<key>## @1 HDMI</key>
				<string></string>
				<key>#framebuffer-con1-enable</key>
				<key>#framebuffer-con1-type</key>
				<data>AAgAAA==</data>
				<key>#framebuffer-con1-flags</key>
				<data>hwEAAA==</data>
				<key>#framebuffer-con1-pipe</key>
				<data>EgAAAA==</data>
				<key>## @2 HDMI</key>
				<string></string>
				<key>#framebuffer-con2-enable</key>
				<key>#framebuffer-con2-type</key>
				<key>#framebuffer-con2-flags</key>
				<key>#framebuffer-con2-pipe</key>
				<key>## @3 HDMI</key>
				<string></string>
				<key>#framebuffer-con3-enable</key>
				<key>#framebuffer-con3-type</key>
				<key>#framebuffer-con3-flags</key>
				<key>#framebuffer-con3-pipe</key>
				<key>## patch0</key>
				<string>Enable lid wake for 0x19260002 credit syscl/lighting/Yating Zhou</string>
				<key>#framebuffer-patch0-enable</key>
				<key>#framebuffer-patch0-find</key>
				<data>ChMDAAAABgAAAAAAAAAAAA==</data>
				<key>#framebuffer-patch0-replace</key>
				<data>DxMDAAAABgAAAAAAAAAAAA==</data>
				<key>## patch1</key>
				<string>Enable lid wake for 0x19260004 credit syscl/lighting/Yating Zhou</string>
				<key>#framebuffer-patch1-enable</key>
				<key>#framebuffer-patch1-find</key>
				<data>CgsDAAAHBgADAAAABAAAAA==</data>
				<key>#framebuffer-patch1-replace</key>
				<data>DwsDAAAHBgADAAAABAAAAA==</data>
			</dict>
Added in 21 seconds:
alireza, use smbios imac13,2
cobrakai
CPU: i5-7300HQ
Motherboard: zotac mi553
GPU: Intel HD630
Post by cobrakai » 23 Jun 2019, 05:56
21 Jun 2019, 18:07
cobrakai, catalina is a beta with many bugs
Nevermind, now is works !! - I can't add screen picture :(
OK, add screen picture:
Post by MaLd0n » 23 Jun 2019, 06:19
cobrakai, [External Link Removed for Guests]
XInflict
CPU: Intel Core I7 3770
Motherboard: Asus P8Z77V-LX
GPU: Nvidia GeForce 970
Post by XInflict » 23 Jun 2019, 07:21
Hey guys I'm having some problems installing Hackintosh Sierra! My Desktop is a I7 3770, a GTX 970 with a Asus P8Z77-LX. I downloaded Sierra from Olarila, and booted with etcher.
The first problem is when I'm using -v that I get this error
And the second is when I'm using nv_disable=1, that I reach apple logo, but get stuck at the last bit of load bar, and have the spinning wheel as well.
Please Help
alireza
CPU: Intel i3-2120
GPU: GeForce 210
Post by alireza » 23 Jun 2019, 09:00
23 Jun 2019, 03:41
Where can i get that? Do you can give me a link, please?
dedalus69
Post by dedalus69 » 23 Jun 2019, 09:05
Oi Mald0n não consigo fazer o dump me da sempre este erro
GA Z77X UD4H
i5 3570
SSD 240 10.13.3
16GB DDR3 1333
650 GTX 2GB
MSI CUBI 23
i5-7200U
HD Grafik 620
4GB DDR4 2133 MHz
Lenovo E560
I5 6200U
SSD 240 10.3.3
Intel HD520
AMD R7 M370
12GB DDR3L 1600 mhz
Post by MaLd0n » 23 Jun 2019, 15:11
XInflict, disable intelhdgraphics in bios/uefi setup
Added in 36 seconds:
alireza, just press O key in clover boot screen and change in smbios tab
Added in 51 seconds:
se não resolver, remova das permisões, reinicia e roda o app de novo
Blacket
GPU: Nvidia GTX960M
Post by Blacket » 23 Jun 2019, 16:15
23 Jun 2019, 03:41
Blacket,
CODE: SELECT ALL
<dict>
<key>#hda-gfx</key>
<data></data>
<data></data>
<string></string>
<string></string>
<string></string>
<string></string>
</dict>
Tanks.
Added in config.plist
What fake ID & ig-platform-id in clover boot should be on?
Post by MaLd0n » 23 Jun 2019, 17:35
Blacket, disable all, use only it
Blacket
GPU: Nvidia GTX960M
Post by Blacket » 23 Jun 2019, 19:49
23 Jun 2019, 17:35
The following error is displayed on startup
Boot With -v in black screen
AppleMUController : :smcRead Key Error : received error 0x04 when reading key ' MSLD '
XInflict
Post by XInflict » 23 Jun 2019, 20:08
23 Jun 2019, 15:12
I didn't find this specific option on my BIOS, but I've found a "Primary Display", and it have PcI-E, PCI and iGPU, I selected PCIE, and nothing changed. I've even disabled every Intel resource.
Could this be something with my Olarila Image on the USB?
cobrakai
CPU: i5-7300HQ
GPU: Intel HD630
Post by cobrakai » 24 Jun 2019, 11:17
Thank's for tip - I add screenshot via ingmur :)
johnhacker
CPU: Intel i5 3ª Geração
Motherboard: HP
GPU: Intel HD 4000
Post by johnhacker » 24 Jun 2019, 15:36
Kernel Panic e Memory lapse alguma coisa assim. vou tentar novamente e anotar.
johnhacker
Motherboard: HP
GPU: Intel HD 4000
Post by johnhacker » 25 Jun 2019, 12:53
Meu hack não quer subir, está dando estes erros:
In memory Panic Stackshot Succeeded **Bytes 13888 **
---------------------------------------------------------13856
---------------------------------------------------------13280
Attempting System restart... Mach Rebot 13200
Post by MaLd0n » 25 Jun 2019, 13:29
johnhacker, parece que o sistema está corrompido, não sei ao certo
guigro
Post by guigro » 27 Jun 2019, 01:01
28 Jan 2019, 13:03
[External Link Removed for Guests] ... Installer/
Added in 17 seconds:
28 Jan 2019, 13:03
