AppleBytes
CPU: c2d, i5, Athlon X4 860k
Motherboard: Inspiron 9400, Optiplex 780, A
GPU: Go 7800, 8400 GS, GT730
Post by AppleBytes » 04 Jun 2019, 19:42
04 Jun 2019, 18:35
AppleBytes, with -v don't appears nothing?
Thank you for the reply, MaLd0n!
Yes. I use the -v switch, and much text scrolls by. The text mode stops shortly after it tries to use the Atheros WiFi card. Then I see the Apple with the meter under it, and a twirling beach ball.
I left it that way for an hour, and 10 minutes. But nothing more, so I powered it off. I guess I'll just keep trying. :)
Thanks again, MaLd0n! :)
--Chris
Inspiron 9400: Core 2 duo @2.16GHz , 4GB, G70 Geforce 7800 (10.7/Lion)
Optiplex 780: Core i5 @3.1GHz, 8GB, Geforce 8400 GS (10.9/Mavericks)
A68HM-E33 V2 (MS-7721): Athlon X4 860K, 8GB, GeForce GT 730 (10.9/Mavericks)
Blacket
CPU: Intel Core i7 6700-HQ
Motherboard: ASUS UX501VW
GPU: Nvidia GTX960M
Post by Blacket » 05 Jun 2019, 08:48
01 Jun 2019, 20:23
first u need try other GPU output, dvi, hdmi or dp
The problem below was fixed
ioconsoleusers gioscreenlockstate 3 hs 0 bs 0 now 0 sm 0x0
By replacing below with last version
Lilu.kext
NvidiaGraphicsFixup.kext
WhateverGreen.kext
But the problem that occurred was the blackness of the page
Resolution Laptop => 4k 3840x2160
Post by MaLd0n » 05 Jun 2019, 12:22
Blacket, 4k use dp
-Donated? Send me one PM-
Blacket
GPU: Nvidia GTX960M
Post by Blacket » 05 Jun 2019, 15:05
05 Jun 2019, 12:22
4k use dp
I did it, but it did not work again
pdevonie
Geek
Geek
CPU: Core 2 Quad 9400
Motherboard: MSI MS-7592
GPU: R7 360 2GB PowerColor
Post by pdevonie » 05 Jun 2019, 19:05
Estou tentando instalar o High Sierra, mas ele fica prezo nessa tela. O que devo fazer?
Minha Config:
i7-2600k
16 RAM DDR3
RX 560 4GB
Ele está dando Kernel Panic=[External Link Removed for Guests]
Post by MaLd0n » 06 Jun 2019, 00:42
pdevonie, não faço idéia, use Olarila Mojave 10.14.5
juvelez
CPU: core i5 3427U
Motherboard: Intel® NUC Board D53427RKE
GPU: Intel® HD Graphics 4000
Post by juvelez » 08 Jun 2019, 01:06
Hi,
Thanks a lot for your work, my installation were pretty well, and after reboot is stuck on this screen:
I can deduce that my CPU is not supported?
I am installing on a Intel NUC, Core i5 3427U, ivy brdige with main board: D53427RKE, 4GB DDR3 Ram, HD Graphics 4000
What could I do?
Post by MaLd0n » 08 Jun 2019, 02:29
juvelez, is supported
use intelgfx 0x12345678, boot into system and create video patch with hackintool
juvelez
CPU: core i5 3427U
Post by juvelez » 08 Jun 2019, 13:59
08 Jun 2019, 02:29
Thanks for your answer, I used for both moments, Install and First Boot, the option ¨O¨ and change to the config2.plist used for Notebooks, and now is working pretty well, now you deserve my donation ;)... without any other hack, the installation was flawless. On Post installation I've followed your steps and everything happened as you said. You can include this old Intel i5 NUCs to the Mojave compatibility list with full 3D/H264 hardware acceleration, a $200 bucks Hackintosh pretty useful for development, general office use and even some light weight gaming.
The only 2 things I am trying to solve are: audio trough HDMI, and booting using Display Port, there are some kind of frequency miss, so the monitor show interlaced and confuse images, but booting connected to HDMI and after boot connect the display port(s) the desktop is extended pretty well and after disconnecting HDMI display port become primary and crispy clean.
Post by MaLd0n » 08 Jun 2019, 14:26
juvelez, u need check in hackintool, connectors tab and put a corrrect Type, etc
fad0507
CPU: Intel® Core™ i7-7700HQ
Motherboard: asus e3 pro gaming v5
GPU: NVIDIA® GeForce® 1050 GTX 4GB
Post by fad0507 » 10 Jun 2019, 02:50
I have followed all the instructions that have been made and I stuck before loading installation or choosing storage
The installation is stuck, and I got error,
Can I Get Config for Intel HM175 Motherboard?
Post by MaLd0n » 10 Jun 2019, 03:22
fad0507, post one photo
i043
CPU: intel
Motherboard: asus
GPU: intel
Post by i043 » 12 Jun 2019, 20:43
28 Jan 2019, 13:03
Blacket
GPU: Nvidia GTX960M
Post by Blacket » 13 Jun 2019, 12:25
Hi MaLd0n 8-)
I installed High Sierra on my laptop
Asus Zenbook Pro Ux501VW
Worked
Intel HD 530 With Resolution 4k & Full-HD (But With 31MB)
USB Realtek LAN
USB3.0 And USB Type-C
Touchpad
USB2.0 HD UVC WebCam
Not Worked
Battery Managment & Charger
Intel(R) Dual Band Wireless-AC 7265
Intel(R) Wireless Bluetooth(R)
Nvidia Geforce GTX960M
Realtek AC668 HDA & Microphone
Alcor Micro PCIE Card Reader
What should I do?
Post by MaLd0n » 13 Jun 2019, 12:32
Blacket, wifi intel and nvidia in ur case don't work
Blacket
GPU: Nvidia GTX960M
Post by Blacket » 13 Jun 2019, 13:14
13 Jun 2019, 12:32
Ok.Tanks
But :
Post by MaLd0n » 13 Jun 2019, 13:30
Blacket, use only one topic, ur file posted in other tread
ceexts
CPU: I7 3687U
Motherboard: HP810G1
GPU: HD4000
Post by ceexts » 14 Jun 2019, 07:02
Thank U Very much
PatchAdams
CPU: i7-2700k
Motherboard: ASUS Z868V Pro Gen 3
GPU: Gigabyte Radeon HD6870
Post by PatchAdams » 15 Jun 2019, 07:18
i've been on Yosemite for a long time. i have a SandyBridge i7 and a 6-series chipset Asus Z868V Pro Gen3 board. it has served me well. Clover version 3320 works for me. the MoBo is UEFI w/upgraded BIOS, but it boots only with Legacy Clover, never UEFI. strange but that's been okay with me.
everything's worked for me...i use no DSDT, have an AMD Radeon HD6870 gfx card, and the board has Intel NIC and ALC892 audio. I created a SSDT using revogirl's old script. It has worked fine for me too. the only issues i've had over the years have to do with USB. if I have a bunch of hubs and drives connected (which I do), sometimes the hubs and connected drives stop working.
recently i decided I wanted to upgrade my OS, since some of the software i use now requires 10.12+. I tried your tools to grab the High Sierra image and burn to flash drive. but when I booted up off the flash drive, it never got past the "waiting for Apple Key Store" line. so I quit.
next, as a test I used tmx86's tools to install sierra on another drive, as well as a newer version of clover, but for some reason, even though the install was successful and I was able to migrate my current content over, when I try to boot off that Sierra drive with the newer version clover it won't do it. no matter what I try, even though the clover "6" digit flashes for a moment, it reverts to the current clover version 3320 off my other drive. thus, none of the configurations specific to the sierra drive are being loaded, so even though i can still use that sierra system, it's not fully working. NIC is okay but the ALC892 audio doesn't work and i get that never-ending USB overcurrent error message.
i don't mind wiping out that tmx86 Sierra install and, if you can help me, using your tools to load a (hopefully) flawless-working Mojave on that drive. if you can help me do it I'll be happy to compensate you for your time & expertise.
let me know if you can & if so, how I might proceed. thx in advance.
Post by MaLd0n » 15 Jun 2019, 13:45
PatchAdams, use our clover folder for serie 6 inside ur usb stick
