robnav
CPU: i7-8700k
Motherboard: HP OEM
GPU: iGPU 630
Post by robnav » 28 May 2019, 11:09
MaLd0n, MaLd0n, After having trouble on mojave to get acceleration on the UHD 630, I decided to give high sierra a try because I'm reading 630 works out the box. I am having trouble with the installation getting stuck at the apple logo. This is my clover folder. Please let me know if I missed something.
Post by MaLd0n » 28 May 2019, 12:34
robnav, use Olarila image or our clover folder for ur chipset
robnav
CPU: i7-8700k
Motherboard: HP OEM
GPU: iGPU 630
Post by robnav » 28 May 2019, 15:56
MaLd0n, Ok i went and used the one for my chipset, coffee lake, and got this error.
Post by MaLd0n » 28 May 2019, 16:06
robnav, i think is a video problem
activate and done
robnav
CPU: i7-8700k
Motherboard: HP OEM
GPU: iGPU 630
Post by robnav » 28 May 2019, 16:52
MaLd0n, Im sorry I dont understand. what do you mean by activate and done?
tux_linuxer
CPU: i5
Motherboard: G41
GPU: NV
Post by tux_linuxer » 28 May 2019, 17:41
Ola boa tarde.
Fiz todo procedimento para instalar essa ultima versão 10.14.5 e ao dar o boot fica congelado numa tela preta.
Alguem teria alguma dica?
Obrigado.
Mário
Bom dia.
Instalei o 10.14.4 e atualizei... rodou de boa
luizorlandi
CPU: Samsung Ultrabook S5
Motherboard: Samsung NP530U3C-K2BR
GPU: Intel HD 3000
Post by luizorlandi » 31 May 2019, 03:59
Galera, bom dia !!
Está funcionando redondo aqui no meu Lenovo Yoga 510, ficou ótimo, porém queria tirar aquele boot em modo Verbose, tentei algumas vezes sem sucesso, a ideia é que entre direto apresentando a maçã... como eu faço isso, ele já inicia direto pelo disco, mas aparece ainda todas aquelas linhas do boot.
Abs !!
i5 6400 / Mobo Gigabyte GA-H110M-H DDR3 / 16GB DDR3 Corsair Vegeance @ 1600mhz / HD Graphics 530 / SSD 240GB / HDD 2TB
Post by MaLd0n » 31 May 2019, 11:22
luizorlandi, remova o -v
Blacket
CPU: Intel Core i7 6700-HQ
Motherboard: ASUS UX501VW
GPU: Nvidia GTX960M
Post by Blacket » 31 May 2019, 12:03
Hello
I'm installing on Mac when booting from USB the following error is displayed
**************** ioconsoleusers gioscreenlockstate 3 hs 0 bs 0 now 0 sm 0x0 ************************
Tanks for helping me.
CLOVER.zip
Post by MaLd0n » 31 May 2019, 13:37
Blacket, u use config2.plist?
Blacket
GPU: Nvidia GTX960M
Post by Blacket » 31 May 2019, 14:21
31 May 2019, 13:37
Yes
When I delete this files (Lilu.kext and WhateverGreen.kext)
The following error resolves but the black screen stays on
I think these two files have problem.
michael626
CPU: E5-4620
Motherboard: XH6G8 Dual LGA 2011
GPU: RX560
Post by michael626 » 31 May 2019, 17:54
Hi Maldon
I use your instruction for my dell R820 with 4 processors E5-4620 and I got stuck during the installation :
can you help me?
AppleBytes
CPU: c2d, i5, Athlon X4 860k
Motherboard: Inspiron 9400, Optiplex 780, A
GPU: Go 7800, 8400 GS, GT730
Post by AppleBytes » 31 May 2019, 19:11
I am attempting to use the Olarila Yosemite USB image to install Yosemite on my Insprion 9400:
Core 2 duo @2.16Ghz
4GB RAM
g70 Geforce 7800 (256Mb)
But all I ever see is:
Welcome to Clover 4559
... testing hardware ...
If I touch the O key. The options do not look like the pictures in the instructions. I don't think Clover works on my hardware. I think it thinks I have a (U)EFI BIOS? I would really like to use your USB image. How can I make this work?
EDIT: I have downloaded the CLOVER.LGA775.zip. I then performed the following:
# sudo tar xvf ./CLOVER.LGA775.zip
# sudo rm -r ./_MACOSX/
# sudo tar cvf ../LGA775.tar .
# sudo mkdir /Volumes/EFI
# sudo mount_msdos /dev/disk1s1 /Volumes/EFI/
# sudo cp ../LGA775.zip /Volumes/EFI/
# cd /Volumes/EFI/
# sudo tar xvf ./LGA775.zip && sudo rm LGA775.zip
# sudo umount /Volumes/EFI/ && sudo diskutil eject /Volumes/Olarila\ Yosemite\ image
So. As I understand it. I needed to replace those files for my chipset, for the Olarila Yosemite USB image to work. But after rebooting to the USB stick. I am still stuck at the same message as above. But the Clover version is different. Can anyone please advise?
EDIT:
OK Clover will only work on systems that have a (U)EFI BIOS. But since I have a legacy BIOS I can't use the Olarila images. Because they all appear to use Clover. :(
Thank you for all your time, and consideration.
--Chris
Inspiron 9400: Core 2 duo @2.16GHz , 4GB, G70 Geforce 7800 (10.7/Lion)
Optiplex 780: Core i5 @3.1GHz, 8GB, Geforce 8400 GS (10.9/Mavericks)
A68HM-E33 V2 (MS-7721): Athlon X4 860K, 8GB, GeForce GT 730 (10.9/Mavericks)
luizorlandi
GPU: Intel HD 3000
Post by luizorlandi » 31 May 2019, 19:17
31 May 2019, 11:22
Já fiz isso tantas vezes, devo estar esquecendo alguma coisa, pois continua no modo verbose, e ainda aparece o menu para vc dar o boot (mesmo sem o pendrive).
Added in 3 minutes 14 seconds:
31 May 2019, 19:17
Corrigindo, não, não deu certo, tem de tirar todas as vezes, como salva isso ?!?! :wallbash
Post by MaLd0n » 31 May 2019, 19:33
Blacket, if u remove weg and lilu u need try with -x for disable some drivers
luizorlandi
GPU: Intel HD 3000
Post by luizorlandi » 31 May 2019, 19:55
MaLd0n, Há algo especial que eu tenha de fazer para salvar a opção sem o -v ?? qdo entra no boot, aparecem 3 opções, e automaticamente entra pelo Boot do MacOs, até ai sem problemas (mas se der para ir direto, bem melhor) se eu tiro manualmente o -v, ok, vai de boa, senão, vem aquela lista monstro de linhas como era antigamente no meu linux (hoje eles mascaram e entra de forma muito parecida com o MacOs).
Agradeço antecipadamente pela boa vontade.
Abs !!
Post by MaLd0n » 31 May 2019, 20:27
luizorlandi, vc tem de remover no config.plist, use o clover configurator
luizorlandi
GPU: Intel HD 3000
Post by luizorlandi » 31 May 2019, 20:51
31 May 2019, 20:27
Entendi, já fiz e deu certo !! Super obrigado !! :crazy: :crazy: :crazy:
Consigo implementar os gestos para dar scroll nas telas ??
Vlw !!
Post by MaLd0n » 31 May 2019, 21:38
luizorlandi, tem de ver qual trackpad seu notebook tem
luizorlandi
GPU: Intel HD 3000
Post by luizorlandi » 01 Jun 2019, 00:28
31 May 2019, 21:38
Putz, deixa eu ver aqui !! Olhei no fabricante, e fala Elan... Mas mesmo ele funcionando não achei onde vejo agora com o MacOS instalado.
