Post by MaLd0n » 25 May 2019, 13:41
verdinand, post ur files
:guitar[External Link Removed for Guests]:guitar
:guitar[Local Link Removed for Guests]:guitar
-Donated? Go to "User Control Panel/Usergroups" and request "Donator" for change group permission-
dentpuzz
CPU: i7
Motherboard: asus
GPU: intel
Post by dentpuzz » 25 May 2019, 13:46
i'm pretty new to this so apologies if this is a stupid question. I freeze at boot. I note on another page is tells me to use a different EFI. Can you tell me how to do that?
verdinand
CPU: i5 7500
Motherboard: Asrock H110M-HDV
GPU: GTX 1050
Post by verdinand » 25 May 2019, 13:51
25 May 2019, 13:41
post ur files
here is I attached the files.
Post by MaLd0n » 25 May 2019, 13:56
dentpuzz, post one photo, error screen
Added in 2 minutes 9 seconds:
verdinand,
esata
CPU: Intel Core i7-6700 3.4GHz
Motherboard: H170-P/G20CB/DP_MB. (ASUSTeK
GPU: NVIDIA GTX 1070 8GB
Post by esata » 25 May 2019, 16:28
Como configurar o clover v2.4k r4934 EFI boot loader pro High Sierra?
Desktop: ASUS G20CB-B21 Gaming Desktop | H170-P/G20CB/DP_MB | Intel Core i7-6700 3.4GHz | NVIDIA GTX 1070 8GB | (2x8GB) 16GB DDR4 SDRAM | SSD 120GB Kingstone | HDD 1TB Toshiba |
ASUS G20CB-B21 Gaming Desktop | H170-P/G20CB/DP_MB. | Intel Core i7-6700 3.4GHz | NVIDIA GTX 1070 8GB | (2x8GB) 16GB DDR4 SDRAM | Realtek ALC887 | Realtek 8821AE | BLUETOOTH: ? | SSD: 128GB KINGSTON SHFS37A120G | HDD: 1TB TOSHIBA DT01ACA100 | ADAPTER 180W 19.5V 3P(5.5PIH) / ADAPTER 230W 19.5V 3P(7.4PHI) | G20AJ CPU FAN ASSY / G20BM THE MOD ASSY
Post by MaLd0n » 25 May 2019, 19:58
esata, veja "Useful Links" na minha assinatura, no fórum temos tudo pra uma instalação perfeita
baumman
CPU: 8700
Motherboard: H310
GPU: RX570
Post by baumman » 26 May 2019, 09:50
Hi , I am new to all of this,
I have a question after I install , what about updates ?
Can i update from mac os and need to reinstall only when major update (different os )
o Generally how do I update macos on hecintosh ?
thanks in advance
eltondecerqueira
CPU: i3-3217U 1.80GHz
Motherboard: NH4CU03
GPU: Intel Graphics HD 4000
Post by eltondecerqueira » 26 May 2019, 15:51
Olá, estou enviando o arquivo zip. Tenho um note CCE conforme meu perfil. Fiz esse hack com as informações do tonycrap/Rehabman.
Já configurei meu config pelo plistpro e nesse momento não está funcionando o gerenciamento de bateria e nem o trackpad. Peço sua ajuda para corrigir esse erro.
saifulapm
CPU: Dell N4050
Motherboard: Intel
GPU: Intel HD 3000
Post by saifulapm » 26 May 2019, 18:47
After language select, it is showing ‘macOS could not be installed in your computer’
I am using Dell n4050 Intel HD 3000
Please help me anyone.
Thank you
livefrommin
CPU: i5-7300HQ
Motherboard: Y720-15IKB
GPU: Nvidia GTX 1060
Post by livefrommin » 26 May 2019, 19:40
Hello.
I have a problem, that was mentioned earlier, about "End RandomSeed", I try to install Mojave on Lenovo ThinkPad W541, and still haven't succeeded. The problem also that I haven't any Mac to open the USB drive and change the drivers. Can someone help me with that?
esata
Post by esata » 26 May 2019, 21:53
Fiz todo o procedimento de instalação do High Sierra 10.13.6, enviei o "send me", recebi um "DSDT.aml", e agora?
Post by MaLd0n » 27 May 2019, 00:34
baumman, if u have a good install, good hackintosh, just updates
Added in 39 seconds:
eltondecerqueira, veja links úteis na minha assinatura
Added in 31 seconds:
saifulapm, old hardware, u need a correct smbios etc for install Mojave
Added in 28 seconds:
livefrommin, u try a config2.plist?
Added in 37 seconds:
esata, clover/acpi/patched
e fazer os últimos ajustes se preciso for
saifulapm
CPU: Dell N4050
Motherboard: Intel
GPU: Intel HD 3000
Post by saifulapm » 27 May 2019, 03:35
MaLd0n, I am using config2.plist. I am not expert. Can you please help where and how I will change smbois?
Added in 4 minutes 33 seconds:
Also I am using Dell n4050 with SSD and 8GB Ram. macOS 10.14.5 will cause any problem for my configuration?? If yes, I which version will perfect for my laptop ?
livefrommin
CPU: i5-7300HQ
Post by livefrommin » 27 May 2019, 06:31
MaLd0n, I've tried both of them, I've tried to fake 0x12345678, and still it stucks on end randomseed.
Blacket
CPU: Intel Core i7 6700-HQ
Motherboard: ASUS UX501VW
GPU: Nvidia GTX960M
Post by Blacket » 27 May 2019, 11:41
Hi.
When I boot up, I will go through the following page and stop at the end line.
My laptop does not have a port USB2.0
Laptop : Asus Zenbook Pro UX501VW
Notice the uploaded file
IMG_0263.zip
Post by MaLd0n » 27 May 2019, 12:43
Blacket, u use a config2.plist?
Blacket
GPU: Nvidia GTX960M
Post by Blacket » 27 May 2019, 12:59
27 May 2019, 12:43
i
Yes
osxi7
CPU: intel 4790k
Motherboard: asus z97 A
GPU: nvidia 970
Post by osxi7 » 27 May 2019, 21:39
Not sure if you can help but I lost my previous installs of High Sierra and had to re load via your image method in windows
to cut a long story. version High Sierra is on a non upgrade path build number 17g2208 and will not install Nvidia 970 drivers
is there a solution? or should I re install ? I have set the Mac version to 14.2 it was set to 12
do you have a raw image of a later build of high Sierra so I can re install ?
Post by MaLd0n » 28 May 2019, 00:06
osxi7, [Local Link Removed for Guests]
ronaldo
CPU: Intel Core i7
Motherboard: Asus
GPU: Intel UHD Graphics 620
Post by ronaldo » 28 May 2019, 03:20
Boa noite. Fiz a instalação do Monjave Olarila conforme o link "Installation/Post Installation Tutorial".
Tenho um notebook Asus Vivobook X510UR.
Após a instalação, fiz o boot pelo pendrive e carrega praticamente tudo certo, menos o mouse pad.
Após o procedimento "8- Replace Clover folder with Olarila Clover folder" agora sem o pendrive bootável, o mouse pad funciona mas não consigo efetuar o login. Há um travamento as vezes antes e depois do login também. Intermitente!
Trabalhei com essa pasta aqui: NOTEBOOKS CHIPSET SERIES SKYLAKE+ (SKYLAKE / KABYLAKE / COFFEELAKE)
Utilizei a ultima versão do clover: Clover_v2.4k_r4934
Consigo carrregar o sistema sem o pendrive utilizando as kexts VoodooPS2Controller.kext e VoodooTSCSync.kext, aqui funciona quase tudo, audio, video, bateria porém o trackpad não funciona.
Se trocar as kexts acima pelas VoodooI2C.kext, VoodooI2CHID.kext o sistema para no momento do login e as vezes depois conforme falei acima. Aqui o mouse pad funciona porém não consigo logar e não consigo utilizar o sistema.
Configurações:
Modelo: x510UR - BQ292T
CPU: i7 - 8550U
SSD: 500Gb
geforce 930mx
Placa Gráfica UHD Graphics 620
Gostaria que o mouse pad estivesse funcionando. Se alguém puder me ajudar.
Desde já agradeço o MaLd0n pela contribuição.
