Post by MaLd0n » 22 May 2019, 17:39
Rogi, try with config2.plist
-Donated? Send me one PM-
Rogi
CPU: i7 7820x
Motherboard: MSI x299 RAIDER
GPU: 1070 Ti FE
Post by Rogi » 22 May 2019, 17:41
I tryied and get same result :/
Canela
Donator
Donator
CPU: i7-8700
GPU: RX 590 8GB
Post by Canela » 22 May 2019, 17:58
22 May 2019, 13:16
Canela, before install windows, disconnect all hdd/ssd, connect again after install
Perfect, it works! Thanks again! :superman
Rogi
CPU: i7 7820x
GPU: 1070 Ti FE
Post by Rogi » 22 May 2019, 18:05
22 May 2019, 17:39
Tryied not work, any tips?
Canela
Donator
Donator
CPU: i7-8700
GPU: RX 590 8GB
Post by Canela » 22 May 2019, 19:09
22 May 2019, 13:16
it worked but i have the same error again... :help
Post by MaLd0n » 22 May 2019, 19:22
Canela, try with other uefi driver like OsxAptioFix2Drv-free2000.efi
Canela
Donator
Donator
CPU: i7-8700
GPU: RX 590 8GB
Post by Canela » 22 May 2019, 19:57
MaLd0n, it works! :guitar
Canela
Donator
Donator
CPU: i7-8700
GPU: RX 590 8GB
Post by Canela » 23 May 2019, 12:43
MaLd0n, same error again. i've tried with OsxAptioFix2Drv-free2000.efi, OsxAptioFix3Drv-64.efi, OsxAptioFix2Drv.efi and OsxAptioFixDrv.efi. With OsxAptioFix2Drv-free2000.efi and emuvariableuefi-64.efi too... when I install a new one works once, then the same error returns :wallbash
Post by MaLd0n » 23 May 2019, 13:04
Canela, use without IGPU enable with aptiomemoryfix
Canela
Donator
Donator
CPU: i7-8700
GPU: RX 590 8GB
Post by Canela » 23 May 2019, 13:49
MaLd0n, it seems to work but so I do not have VDA decoder...
Post by MaLd0n » 23 May 2019, 15:48
Canela, run one brucex and check if hack freeze or not
Canela
Donator
Donator
CPU: i7-8700
GPU: RX 590 8GB
Post by Canela » 23 May 2019, 18:00
MaLd0n, it works, exported in 14s. Thanks :guitar
Post by MaLd0n » 23 May 2019, 22:09
Canela, ;) :cap
diegofreire
CPU: i5-8250u
Motherboard: dell
GPU: nvidea
Post by diegofreire » 24 May 2019, 19:11
É compatível com um Dell Inspiron 15 7572, Core i5-8250u e Nvidea Mx150?
Post by MaLd0n » 24 May 2019, 19:20
diegofreire, sim, essa nvidia não funciona, seu notebook é optimus
thanhtung98
CPU: Intel Core i5 2520M
Motherboard: Mobile Intel QM67 Express
GPU: Intel HD 3000
Post by thanhtung98 » 24 May 2019, 23:08
I'm having problem with screen on Sierra, Can i upgrade it to mojave ? (i5 2520M, HD 3000) :) :) :)
Post by MaLd0n » 25 May 2019, 00:53
thanhtung98, u can, but u need some extra patches, kext from high sierra
imablackhat
CPU: I7 6700k
Motherboard: Z170mx gaming 5
GPU: 980ti
Post by imablackhat » 25 May 2019, 03:40
Followed this guide - everything works great thank you so much.
Only thing I did not do was "9- Fine Tune, DSDT"
But I have a i7 6700k, z170mx gaming 5 gigabyte motherboard, 980Ti, and sleeps, and powers off without any issues and no noticeable problems at the moment, is this a required step I should revisit?
thanhtung98
GPU: Intel HD 3000
Post by thanhtung98 » 25 May 2019, 04:08
I got the message : Start Reading Kernel Cache when booting to installer. And it stuck here
I'm now following this solution : [External Link Removed for Guests]
verdinand
CPU: i5 7500
Motherboard: Asrock H110M-HDV
GPU: GTX 1050
Post by verdinand » 25 May 2019, 11:22
Hi MaLd0n, where I can get the common patches for DSDT? Or you have source file to patch DSDT for asrock h110m-hdv? I know it's more easier if I request DSDT.aml to you. But I wanna learn to patch DSDT by my self.
Thank you
