artnr28
CPU: i7 7800k
Motherboard: gigibyte 370n
GPU: AMD pro 7100
Re: [Guide] Install MacOS with Olarila Image, Step by Step, Install and Post Install, Windows or Mac
Post by artnr28 » 10 Feb 2019, 04:27
10 Feb 2019, 03:20
Managed to extract EFI System Partition.img and disk image.hfsx then edit EFI System Partition.img to include OsxAptioFix2Drv-free2000.efi... but can't figure out how to get them back in a file or files in Windows 10 that will result in a working OSX USB install drive. Tried 7zip, Power ISO, transmac, Explorer++... any tips or tricks to getting the modified files in a usable form using only a Windows 10 computer?
I’m with you with this one !
I only have wind 10.
How did you extract the files ?
Can you send some files ? Or tell me how you did it?
Thanks a lot !
artnr28
CPU: i7 7800k
GPU: AMD pro 7100
Post by artnr28 » 10 Feb 2019, 04:31
I did try all of my USB ports , non of them works.
Keep having this error and get stuck
Post by MaLd0n » 10 Feb 2019, 04:34
10 Feb 2019, 04:31
use usb 2 port or usb 2 usb stick
-Donated? Send me one PM-
artnr28
CPU: i7 7800k
GPU: AMD pro 7100
Post by artnr28 » 10 Feb 2019, 10:42
I I’m on usb 2 port, also usb 2 stick
artnr28
CPU: i7 7800k
GPU: AMD pro 7100
Post by artnr28 » 10 Feb 2019, 10:47
I use exactly the some computer as before, the one you helped me with.
Maybe I have to try different OSX?
Sierra is fine, as long as it works
You think it will help?
Post by MaLd0n » 10 Feb 2019, 13:02
10 Feb 2019, 10:47
all work fine, is a strange error if u use usb 2 device and have a ahci option default in bios
artnr28
CPU: i7 7800k
GPU: AMD pro 7100
Post by artnr28 » 10 Feb 2019, 13:05
hi, im sorry, what ? so what do i need to do? install to usb3 stick ? and what do i change in bios ?
please
artnr28
CPU: i7 7800k
GPU: AMD pro 7100
Post by artnr28 » 10 Feb 2019, 13:36
I switched of ... so it’s not the problem
artnr28
CPU: i7 7800k
GPU: AMD pro 7100
Post by artnr28 » 10 Feb 2019, 13:41
I have this, all the times no matter what I do, this is all ready high Sierra.
From your website:(
I’m lost.
Can you please help?
I only have WIND10.
I fallowed your website instructions to every point.
Post by MaLd0n » 10 Feb 2019, 14:18
10 Feb 2019, 13:41
From your website:(
I’m lost.
I only have WIND10.
what ur hardware?
artnr28
CPU: i7 7800k
GPU: AMD pro 7100
Post by artnr28 » 10 Feb 2019, 15:08
I7 8700K
RADEON PRO WX 71000
Z370ON WIFI
32gb RAM
SAMSUNG 970 Evo 500gb
Post by MaLd0n » 10 Feb 2019, 15:13
10 Feb 2019, 15:08
I7 8700K
RADEON PRO WX 71000
Z370ON WIFI
32gb RAM
U use last bios/uefi version?
artnr28
CPU: i7 7800k
GPU: AMD pro 7100
Post by artnr28 » 10 Feb 2019, 15:19
I use the new bios version, 11C , I’m not sure if I understand your question:(
Where do I check uefi version?
I use disc image RAW , from your website
Post by MaLd0n » 10 Feb 2019, 15:21
10 Feb 2019, 15:19
try with previous bios version, many last versions OSX system don't boot
artnr28
CPU: i7 7800k
GPU: AMD pro 7100
Post by artnr28 » 10 Feb 2019, 16:10
I did went back to version 5, still nothing:(
Post by MaLd0n » 10 Feb 2019, 16:21
10 Feb 2019, 16:10
no idea
artnr28
CPU: i7 7800k
GPU: AMD pro 7100
Post by artnr28 » 10 Feb 2019, 17:37
Wooooooowwwww I’m on the apple velcome screen!!
Maybe it’s you ;)!
Magic ! Your power was send to the computer via cosmos
DrDoker
CPU: i3
Motherboard: hp4540s
GPU: Intel 3000
Post by DrDoker » 12 Feb 2019, 18:28
Hp 4540s
i3 2370, 8 gb RAM
Hello)
Please, help!
I'm trying to install High Sierra
EFI files: [External Link Removed for Guests]
Post by MaLd0n » 12 Feb 2019, 18:34
DrDoker, use config2.plist or -x (safe mode)
DrDoker
CPU: i3
GPU: Intel 3000
Post by DrDoker » 12 Feb 2019, 21:42
MaLd0n,
I used config2 and -x
:cry:
