chungkls
CPU: i5 6600
Motherboard: Dell OptiPlex 3046
GPU: intel hd530
Post by chungkls » 19 May 2019, 12:00
i don't see usb option on boot menu.
p.s i created installation on windows
Added in 14 seconds:
Added in 1 minute 8 seconds:
sohailidrees
CPU: intel i5 5200u
Motherboard: hp
GPU: intel hd 5500
Post by sohailidrees » 19 May 2019, 12:28
Hi, i have hp laptop 15-r229ne can i install olarila mojave on my laptop
Post by MaLd0n » 19 May 2019, 14:57
sohailidrees, u can try
follow here
:guitar[External Link Removed for Guests]:guitar
:guitar[Local Link Removed for Guests]:guitar
-Donated? Go to "User Control Panel/Usergroups" and request "Donator" for change group permission-
marghe_bs
CPU: Intel® Core™ i7 6500U
Motherboard: ASUSTek K501UX Skylake
GPU: NVIDIA® GeForce® GTX 950M with
Post by marghe_bs » 19 May 2019, 22:35
Hi everyone!
I installed Mojave with Olarila image on an external hard drive, bought a wifi adapter and managed to get the audio working.
I then installed Clover on the efi partition, but then nothing worked again. This is the last message i got from booting in -v:
kext stall [0] (60s) X86PlatformPlugin IGPU PPMC HDEF BAT0 IOResources
I used the clover folder for Skylake and tried to set everything correctly; but I clearly did something wrong.
Any advice?
Post by MaLd0n » 19 May 2019, 22:36
marghe_bs, install in internal hard driver
marghe_bs
Post by marghe_bs » 19 May 2019, 22:43
19 May 2019, 22:36
Is it impossible to install it on an external drive? Is this error related or the error is about something else?
Post by MaLd0n » 19 May 2019, 22:48
marghe_bs, is not common error with simple install, try in internal
Alin01
CPU: I7-5500U
Motherboard: Asus
GPU: nVidia 940M
Post by Alin01 » 20 May 2019, 09:42
Hi Maldon,
I configured the BIOS as follows:
Vt-d - disable;
Secure boot - disable;
Fastboot- 1 time enable with CSM disable/ fastboot disable with CSM enable.
These are the only settings I've made at BIOS.
To the bootable USB stick I deleted the first time in cmd "DISKPART ..... clean", and then formatted it from Disk Management with NTFS format.
I wrote the USB with:
-Etcher;
-Win32DiskImager;
-TransMac.
I've used the following flags extra with config2:
-x -s -no-zp.
What am I doing wrong because I can not go through "++++++++++++++++++++++++++++"?
Post by MaLd0n » 20 May 2019, 14:34
Alin01, try with other uefi driver like OsxAptioFix3Drv-64.efi
heliodm
CPU: I7 7400
Motherboard: Gigabyte b250m gaming 5
GPU: GTX 1050 Ti
Post by heliodm » 20 May 2019, 19:23
Boa tarde, sou novo em hackintosh. Tenho um notebook da positivo (sei que não é bom, kkk) mas tem uma configuração i7-2620M, board N14HV, hd graphics 3000. Gostaria de saber se é possível instalar a versão high sierra ou mojave nele.
Canela
CPU: i7-8700
GPU: RX 590 8GB
Post by Canela » 20 May 2019, 19:28
19 May 2019, 00:10
Canela, replace full efi, reboot
Thank u!! :crazy:
19 May 2019, 00:10
for 4k u need a dp or need some patches
I've tried with a displayport cable, it works perfect! :frantics
With this EFI folder... do I need some SSDTs?
If I add or remove HDDs, or add more RAM, is it necessary to modify the DSDT?
Post by MaLd0n » 20 May 2019, 19:40
Canela, don't need add ssdt, just enjoy
Canela
CPU: i7-8700
GPU: RX 590 8GB
Post by Canela » 20 May 2019, 20:14
MaLd0n, :guitar
and If I add or remove HDDs, or add more RAM, is it necessary to modify the DSDT?
Post by MaLd0n » 20 May 2019, 20:18
Canela, no
Canela
CPU: i7-8700
GPU: RX 590 8GB
Post by Canela » 20 May 2019, 20:20
MaLd0n, Perfect thanks!!
joaosilvasocial
CPU: i7 7700K
Motherboard: Z270M-DH3-CF
GPU: GTX 1080
Post by joaosilvasocial » 22 May 2019, 02:19
Fiz a instalação do High Sierra por causa da placa de vídeo que possuo, uma GTX 1080, tudo ok até o momento. Porém só consigo dar boot no sistema pelo Pen drive, pelo Clover direto do SSD não vai, o mesmo aparece a logo da Apple e reinicia, e fica assim nesse looping. Fiz a instalação em AFPS, já tentei reinstalar o Clover e sempre utilizo a pasta disponibilizada da versão do Firmware, a minha é série 200. O que poderia ser? Desde já agradeço.
Post by MaLd0n » 22 May 2019, 02:33
joaosilvasocial, instala o clover uefi mode e substitui a efi completa
joaosilvasocial
CPU: i7 7700K
GPU: GTX 1080
Post by joaosilvasocial » 22 May 2019, 02:43
MaLd0n, realizei a reinstalação do Clover no modo para Placa Mãe UEFI e substitui as pastas BOOT e CLOVER da partição UEFI pelas que você me mandou, era dessa forma que estava fazendo, porém o erro ainda persiste, não tenho mínima idéia do que seja, revi as configurações da placa mãe, todas elas setadas como recomendado pelos guias aqui do Fórum. Tentei também substituir a versão do Clover, pra uma mais atualizada e a que vem nos App's já na imagem do sistema, também não tive resultado. Será que pode ser algo relacionado à drivers? Ou seria realmente à questão do Bootloader, pois apenas pelo Pen Drive que consigo iniciar o sistema :cry:
Post by MaLd0n » 22 May 2019, 02:57
joaosilvasocial, substitui a pasta EFI dentro da partição EFI
joaosilvasocial
CPU: i7 7700K
GPU: GTX 1080
Post by joaosilvasocial » 22 May 2019, 03:08
MaLd0n, amigo, agora foi, entendi o porque, com você explicando. Pois dentro da EFI tem mais que 2 pastas :lol: . Obrigado MaLd0n pela ajuda rápida! :D
