Jcrouse55
CPU: xeon E5 1650
Motherboard: HP
GPU: Quadro 4000
Post by Jcrouse55 » 10 May 2019, 23:34
<blockquote class="imgur-embed-pub" lang="en" data-id="a/SS8h0Ce"><a href="//imgur.com/SS8h0Ce"></a></blockquote><script async src="//s.imgur.com/min/embed.js" charset="utf-8"></script>
Added in 2 minutes 24 seconds:
Neofox
CPU: Intel Core i5 (3rd Gen) 3317U
Motherboard: Mobile Intel HM76 Express
GPU: Intel HD Graphics 4000
Post by Neofox » 11 May 2019, 00:25
Hey there! First off, I want to say Thank you MaLd0n, for going above and Beyond to help everyone and probably also myself in this forum! I've not seen this kind of generosity in any other forum i've tried! So, I've got an Asus UX31A Notebook PC, Intel i5-3317U CPU @ 1.70GHz (see specs on profile) 4GB RAM, and 125GB SSD. I've used the Mojave 10.14.4 RAW and flashed to a USB 3.0 (32GB) and a USB 2.0(16GB) and have tested with using the -x flag, have tried using a different device identifier (originally said "MacBookAir 5,2") trying iMac 18,3, have attempted to inject intel graphics (set to intel HD4000 as per my device) tried with 0x12345678, using config2 have attempted to use several other hackintosh tools (tonycrap, hackintosh, niresh, and now this one). I've just about tapped out everything i've read so far and flipped other switches to see what would happen (changing up injection flags, tried enable/disable fake things and whatnot). I'm really lost. I just keep getting CPU not supported. This is what I'm seeing right at this moment that I'm stuck on [External Link Removed for Guests]. I could really use a pointer as to what I might be doing wrong, or what I could do next to move forward with the installation. I've read the guide and it seems pretty clear what to do after the installer begins, it's just the matter of getting there first.
Post by MaLd0n » 11 May 2019, 01:00
Jcrouse55, try with other smbios, imac13,2 or 14,2
Added in 3 minutes 5 seconds:
Neofox, i don't remember if intelhd 4000 have native support in Mojave or if need a patch for it
-Donated? Send me one PM-
Jcrouse55
CPU: xeon E5 1650
Motherboard: HP
GPU: Quadro 4000
Post by Jcrouse55 » 11 May 2019, 18:36
Okay I ended up going with El Capitan and it loaded fine and I got clover efi copied and it boots without usb but boots to the clover Olarila screen and if I just let it boot it boots black screen and doesn't inject nvidia. How do I fix that?
Post by MaLd0n » 11 May 2019, 18:44
Jcrouse55, InjectNvidia and i think work, press O key, Graphics, InjectNvidia
Jcrouse55
CPU: xeon E5 1650
Motherboard: HP
GPU: Quadro 4000
Post by Jcrouse55 » 11 May 2019, 19:03
Yeah I do that to get it to boot. But is there a way to get around that so I don't have to do that everytime I boot up.
Post by MaLd0n » 11 May 2019, 21:05
Jcrouse55, check it in ur config.plist
byronDiuby
CPU: byronDiuby
Motherboard: Intel
GPU: 84379275876
Post by byronDiuby » 13 May 2019, 14:17
another piece of information i collected: mac disk utility says its a non-bootable drive. i dont know how this can be changed. does anyone?
robnav
CPU: i7-8700k
Motherboard: HP OEM
GPU: iGPU 630
Post by robnav » 15 May 2019, 01:29
erroruser,
20 Apr 2019, 16:31
IntelGFX 0x59128086
ig-platform-id 0x59120003
Check InjectIntel
shikigva=60
This did not seem to work. i tried this but I got a kernal panic. I tried to patch with hacking tool but that gave me a black screen.
Alin01
CPU: I7-5500U
Motherboard: Asus
GPU: nVidia 940M
Post by Alin01 » 16 May 2019, 11:41
Intel core i7/5500 CPU@ 2,4GHz
Asus X751LB
Intel HD Graphics 5500
NVIDIA GeForce 940M
RAM 8GB
Hi,
I'm trying to install Olarila Mojave 10.14.5.raw, but I still can not get past from theat (see picture below).
i tried with config2 and the flag (-x for SafeMode) and the same result, does not want to boot. BIOS settings have changed. I have changed the USB ports every time, but the installation was unsuccessful. Once with the same .raw I managed to get to this point (see picture 2). I just do not get through this point. Please help !!!
Post by MaLd0n » 16 May 2019, 13:25
Alin01, try with other uefi driver like aptio v3 or v2
weeraza123
CPU: Core i5-2400
Motherboard: DELL
GPU: NVIDIA GTX1050 2GB
Post by weeraza123 » 17 May 2019, 13:28
28 Jan 2019, 13:03
Alin01
CPU: I7-5500U
Motherboard: Asus
GPU: nVidia 940M
Post by Alin01 » 17 May 2019, 14:16
16 May 2019, 13:25
this is my BIOS, the BIOS is upgraded to the latest version 606 on the ASUS official site. I do not know how to change from Aptio to UEFI, if you can put a link here you are welcome. The problem is I've tried all BIOS settings, I've even activated the CSM (of course I had to unpack my laptop, remove HDD, restart my laptop without HDD to get back into the BIOS). I always block on the boot ++++++++++++++++++. from what I have documented in the forums, I understand that ASUS laptops have the best configurations to put MACOS
vrephyr
CPU: i7 8700
Motherboard: Z370-F Strix
GPU: GTX 1070 ti
Post by vrephyr » 18 May 2019, 10:19
Hi Maldon. How do i dual boot High Sierra with my Windows? I have two different SSD. One for Windows and one for Hackintosh. Please advise. Should I install the bootloader in Hackintosh SSD? and how can I choose to boot windows the next time i restart my PC?
Post by MaLd0n » 18 May 2019, 12:54
vrephyr, just use a hackintosh hdd/ssd with primary in bios/uefi
vrephyr
CPU: i7 8700
GPU: GTX 1070 ti
Post by vrephyr » 18 May 2019, 13:07
Noted with thanks. I have i7 8700 paired with asus rog strix z370. the link you provided for High Sierra for 8th gen is down. Do you have a mirror link for that? Or I can use the installer without the 8th Gen title?
Post by MaLd0n » 18 May 2019, 13:23
vrephyr, use torrent, ill put images in new google drive
vrephyr
CPU: i7 8700
GPU: GTX 1070 ti
Post by vrephyr » 18 May 2019, 13:38
18 May 2019, 13:23
thank you. I need that. much appreciated.
Canela
Donator
Donator
CPU: i7-8700
GPU: RX 590 8GB
Post by Canela » 18 May 2019, 16:04
MaLd0n, I've donated some beer ;)
I have the following configuration: GA Z390 M Gaming, i7-8700, RX 590 8GB Nitro+, 16GB RAM 2666, Samsung EVO NVMe 250GB, and bluetooth Orico BTA-403. F6 Bios with default settings and Internal Graphics Enabled. Mojave 10.14.5 installed with Olarila Image, Olarila Clover folder and SMBIOS iMac 19,2... u think is OK this SMBIOS?? I have 2 monitors, one is FullHD and the other is 4K. 4K monitor only working if the FullHD monitor is connected too. do u know how can I solve this? I want use 4K monitor only. And it's possible to use apple bluetooth keyboard in BIOS and Clover? I give u my send me.
Maybe too much questions, I have more... :lol: :lol: Thanks!!
Post by MaLd0n » 19 May 2019, 00:10
Canela, replace full efi, reboot
EFI.zip
for 4k u need a dp or need some patches
