erroruser
CPU: i9 9900k
Motherboard: asus z390-a
GPU: rx 590
Re: [Guide] Install MacOS with Olarila Image, Step by Step, Install and Post Install, Windows or Mac
Post by erroruser » 04 Feb 2019, 19:54
update your kext boot loader make a backup with carbon copy cloner an then you can update
Asus z390-A, i9 9900k, Corsair Vengeance RGB PRO 16GB DDR4 3200MHz, sapphire rx 590, fractal celcius s36
:superman :superman
Bal-lek
CPU: I3-8100
Motherboard: Gigabyte b360m d3p
GPU: Intel uhd630
Post by Bal-lek » 05 Feb 2019, 11:18
Hi guys! Try to install high sierra on my PC (i3-8100, gigabyte b360m d3p, intel uhd 630, 8gb DDR4, SSD, 4k display via displayport).
I made all steps from this guide (downladed image of High Sierra for 8th generation processors) and stuck in instalation process.
When I select "Boot MacOS Install from Olarila Image" I have this issue:
Error allocating 0x11944 pages at...
Couldn`t allocate runtime area
Any minds how to solve it?
BIOS settings I try only "load optimized" and try these:
Save & Exit → Load Optimized Defaults
M.I.T. → Advanced Memory Settings Extreme Memory Profile(X.M.P.) : Profile1
BIOS → Fast Boot : Disabled
BIOS → LAN PXE Boot Option ROM : Disabled
BIOS → Storage Boot Option Control : UEFI
Peripherals → Trusted Computing → Security Device Support : Disabled
Peripherals → Network Stack Configuration → Network Stack : Disabled
Peripherals → USB Configuration → Legacy USB Support : Auto
Peripherals → USB Configuration → XHCI Hand-off : Enabled
Chipset → Vt-d : Disabled
Chipset → Wake on LAN Enable : Disabled
Chipset → IOAPIC 24-119 Entries : Enabled
Thanks for answers and sorry for bad english.
Post by MaLd0n » 05 Feb 2019, 12:26
05 Feb 2019, 11:18
bios in default, first try, if don't work u change options
-Donated? Send me one PM-
SUUB3
CPU: 8750H
Motherboard: MSI Intel® HM370
GPU: nvidia 1070
Post by SUUB3 » 05 Feb 2019, 12:32
i have a MSI GE73 RAIDER RGB 8RE LAPTOP. dual ssd nvme and a sata 3 hdd, intel core i7 8700k, nvidia 1070, 32 gb ram. would it be possible to instal a dual boot MOJAVE with windows 10 on a distinct ssd? thamk you very much! ( my motherboard i think it is a msi not gigabyte. appologies for my mistake)
Post by MaLd0n » 05 Feb 2019, 13:09
05 Feb 2019, 12:32
use high sierra, nvidia web driver don't work in mojave
Bal-lek
CPU: I3-8100
GPU: Intel uhd630
Post by Bal-lek » 05 Feb 2019, 13:20
05 Feb 2019, 12:26
I wrote incorrectly at the first time. Yes, I tried in default settings after the first issue, but no changes
DrDoker
CPU: i3
Motherboard: hp4540s
GPU: Intel 3000
Post by DrDoker » 05 Feb 2019, 22:11
Hp 4540s
i3 2370, 8 gb RAM
Please, help!
Post by MaLd0n » 06 Feb 2019, 13:07
05 Feb 2019, 22:11
Hp 4540s
i3 2370, 8 gb RAM
Please, help!
stevehack81
CPU: Intel Core i5 3470 3.20Ghz
Motherboard: AsRock H61M-DGS rev 2.0
GPU: Intel HD Graphics 2500
Post by stevehack81 » 06 Feb 2019, 23:21
Hi MaLd0n , i tried to install Mojave and high sierra but i have problems during the first intallation ( black screen and text in white), i used Etcher to flash my Usb pen drive and it was ok.
my Hardware is:
AsRock H61M - DGS rev.2 mainboard
Intel i5 3470 with HD Graphics 2500
Hard disk Maxtor Sata 3 120Gb (it's just for a test)
ironclock14
CPU: G4560
Motherboard: ASUS H170M
GPU: 1050
Post by ironclock14 » 07 Feb 2019, 08:16
I've been trying to install Mojave for 2 days and I got an error
It says "Please go to [External Link Removed for Guests] to report this panic"
Can someone help me?
Post by MaLd0n » 07 Feb 2019, 11:24
07 Feb 2019, 08:16
ur processor don't have a native support, u need a fakecpuid
ironclock14
CPU: G4560
GPU: 1050
Post by ironclock14 » 07 Feb 2019, 11:41
07 Feb 2019, 11:24
I really appreciate for your reply :o :D I've been trying to install the Mojave for 2 days
how I will do the fakecpuid?
Post by MaLd0n » 08 Feb 2019, 14:55
07 Feb 2019, 11:41
HossMedoGad
CPU: Intel Core i5 4200M
Motherboard: Toshiba PT10S
GPU: Intel(R) HD Graphics 4600
Post by HossMedoGad » 09 Feb 2019, 16:20
Post by MaLd0n » 09 Feb 2019, 19:06
09 Feb 2019, 16:20
:shock:
TheInternal
CPU: i7-6850k
Motherboard: Gigabyte X-99 Pheonix SLI
GPU: NVIDIA Geforce 970
Post by TheInternal » 09 Feb 2019, 20:53
first time trying to do the whole hackintosh thing using high sierra.
followed your guide as well as I could without having accerss to a Mac. Also tried adding -v nv_disable#1 to options, neither of which got OSX loaded.
Getting either kernel panics or Error loading kernel cache messages.
I7-6850k, Gigabyte Phoenix SLI x99, 32GB RAM, SAMSUNG 850 EVO 512GB, Gigabyte Windforce 970 OC
Tried following a BIOS setup guide, as well as tried loading optimized default. No dice.
Does the target install drive have to be formatted before starting install?
Post by MaLd0n » 09 Feb 2019, 21:03
09 Feb 2019, 20:53
x99 is very specific hardware, try with OsxAptioFix2Drv-free2000.efi driver instead aptiomemoryfix
TheInternal
CPU: i7-6850k
Post by TheInternal » 09 Feb 2019, 21:20
edit: been trying to figure out how to add that file to the image for around half an hour now since I don't have access to a mac... still working on it, but open to suggestions.
artnr28
CPU: i7 7800k
Motherboard: gigibyte 370n
GPU: AMD pro 7100
Post by artnr28 » 10 Feb 2019, 00:28
i have the same problem :( with the one from the photo as luki53, can you help? in english please :(
i had majave on my system before, but i had some pronlems , so i give up , 3 months ego, but now im trying to come back, and have tis error
TheInternal
CPU: i7-6850k
Post by TheInternal » 10 Feb 2019, 03:20
Managed to extract EFI System Partition.img and disk image.hfsx then edit EFI System Partition.img to include OsxAptioFix2Drv-free2000.efi... but can't figure out how to get them back in a file or files in Windows 10 that will result in a working OSX USB install drive. Tried 7zip, Power ISO, transmac, Explorer++... any tips or tricks to getting the modified files in a usable form using only a Windows 10 computer?
