🎉 NEW Discord server!
luky53
CPU: Intel Core i5 Duo
Motherboard: Intel
GPU: NVidia 310
Post by luky53 »
My Computer:
ThihinkCentre M900z
Motherboard Skylake,
Chipset Intel Q170 ( Skylake PCH-H )
CPU: Intel Core i5-6500 Codename Skylake5 Socket H4 (LGA 1151)
GPU: Intel HD Graphic 530
Network Intel Ethernet Connection I219-LM
Intel Dual band Wireless-AC 8260 AC 2x2 Wifi Adapter
Audio Realtec ALC286, Intel SKYLAKE PCH-H High Definition
Memory 16 GB PC4 DDR4-2400 /PC4-19200
SSD 256 GB |
LENOVO-ThinkCentre M90p: CPU: 3,19 GHz, Intel Core i5, RAM: 8,0GiB, HDD: 500 GiB, SSD: 60 GiB, GPU: NVidia 310, 512 MB, Audio: Realtec ALC 662, Network Intel 82578
DM Gigabit
- OS X Yosemite 10.10. 1
Ndpac
CPU: Intel Core i5 5300U
Motherboard: hp elitebook 840 g2
GPU: HD 5500,Radeon R7 M260X
Post by Ndpac »
great!
Post by MaLd0n »
luky53, just use USB 2 port on installer
Douglas Dreer
CPU: Intel i5
Motherboard: DELL
GPU: nVidia 630m
Post by Douglas Dreer »
28 Jan 2019, 13:03
*Mobos UEFI
CLOVER UEFI.png (139.2 KiB) Viewed 1064 times
Hi Man! The file is broken, you can re-up the image ?
Post by MaLd0n »
Douglas Dreer, image is fine. No problem!
Ndpac
Post by Ndpac »
i created usb install by Olarila Mojave 10.14.1 ([Local Link Removed for Guests]),
it's always stuck right after selecting disk to install (freeze mouse,graphic)
before reach this, overcome some errors:
* end ramdomseed
-> change ram slot
*please go to https //panic.apple.com to report this panic...
-> remove kexts ,just leave FakeSMS, Lilu, USBinjectAll, VoodooPS2Controller, WhateverGreen
a question: if my laptop can't change to boot UEFI, can boot legacy after install, if so, should format MRB?
I tried format APFS but the same
Post by MaLd0n »
Ndpac, GUID and APFS
electroqobra
CPU: i5 7500
Motherboard: Asus Prime H270 Plus
GPU: Asus Strix GTX 1070
Post by electroqobra »
I'm having the same problem as luky53. When my computer gets to the stage that the first picture is in, it freezes and then what I show in the second picture happens. Are these parts incompatible? I also did not format the SSD that I plan to install Mojave on to APFS because I don't have an existing mac. Is there any way to format APFS on Windows 10? Do I need to change any BIOS settings for the install to work?
Here is my hardware configuration:
CPU: Intel i5 7500 @ 3.40 GHz
MOBO: Asus Prime H270-Plus
GPU: Asus strix 1070
Thank you for your help!
Post by MaLd0n »
electroqobra, format entire SSD in disk utility on installer
cm0270
CPU: i7-8700
Motherboard: Asrock Killer SLI AC Z270
GPU: GF 710
Post by cm0270 »
I run into the same issue as Luky53. I was trying this with the Olarila Mojave 10.14.3 image.
My only boot options in the BIOS is Legacy, UEFI, or UEFI with CSM
Hardware:
MSI GP70 Leopard Pro-486 17.3" Intel Core i7 4th Gen 4720HQ (2.60 GHz) NVIDIA GeForce GTX 950M 8 GB Memory 1 TB HDD Windows 8.1 64-Bit Gaming Laptop
Chipset: Intel HM86
i7-4720HQ 3.6ghz (Haswell)
16gb DDR3 Ripjawz
250gb SATA HDD
Intel HD Graphics 4600
NVIDIA Geforce GTX 950M 2gb DDR3 (built in)
Is there anyway to get MacOS on this one?
Post by MaLd0n »
cm0270, try with emuvariable driver
use -x too
Yasser Homsi
CPU: Core i5 2400m
Motherboard: Asus
GPU: intel 3000
Re: [Guide] Install MacOS with Olarila Image, Step by Step, Install and Post Install, Windows or Mac
Post by Yasser Homsi »
which of those graphic card is compatible with hacknitosh?
1 . amd radeon r5 m530 2g ddr5
2. amd radeon r5 m520 2g ddr5
3. nividia mx110 2g ddr5
Post by MaLd0n »
03 Feb 2019, 20:28
RX 560
edukonzen
CPU: u0uuuuuiiiuytre56789
Motherboard: 4567890904637
GPU: 6567ygyfv7676
Post by edukonzen »
boa noite amigo. Fiz conforme o post mas depois que seleciono o instalador fica assim a tela. help
Post by MaLd0n »
04 Feb 2019, 03:45
sem as especificações do seu hardware fica difícil
edukonzen
GPU: 6567ygyfv7676
Post by edukonzen »
04 Feb 2019, 09:48
Bom dia. É um Dell N4050. Ele possui um processador Intel i5 de 5ºgeracao e 4 de memória RAM
Post by MaLd0n »
04 Feb 2019, 12:29
vc tentou com o config2.plist?
huu
CPU: Intel i5-7400
Motherboard: PRIME B250M-PLUS
GPU: NVIDIA GeForce GTX 1050 Ti
Post by huu »
volume folder is empty for me where can I find clover in the post installation?
Post by MaLd0n »
04 Feb 2019, 17:12
retrokid803
CPU: Dell Optiplex 990
Motherboard: Intel
GPU: Nvidia
Post by retrokid803 »
i have 10.4.1 and would like to update if possible. If its best to stay then i just will.
