sayerX12
CPU: CORE i7 Sandy Bridge
Motherboard: Fujitsu AH77/G
GPU: INTEL HD 3000
Post by sayerX12 »
My bios settings-------
Bios > advanced tab > Internal device configuration
Serial ATA controller--->enabled
AHCI configuration--->enabled
Bios>advanced tab> Cpu features
Multi-core-->enabled
HT technology--->disabled
SpeedStep technology--->disabled
Virtualization technology-->disabled
Bios >Advanced tab>USB features
Legacy usb support --> enabled
SCSI SubClass support -->enabled.....
These are the settings of my bios......any thing wrong with this settings..
Cant boot High Sierra with this bios setting....
End randomseed +++++ thn auto reboot.......
Nexxusone
CPU: i5 9400f
Motherboard: Asus B360 G Gaming
GPU: sapphire rx480 4GB Nitro+
Post by Nexxusone »
system specs please, cpu + graphics card + motherboard name, model, revision etc, (i.e mines a Asus B360G Gaming / i5-9400f / RX5700) as certain chipsets requires different clover folders added/merged into the usb installer. Mine required the 300 chipset.zip merged a custom DSDT.aml file and correctly configured Config.plist - Maldon (forum owner / mod) will help with dsdt.aml file.
VT-d should be off, and VTT should be on if these setting available to you.
Rhoqr
CPU: E5-2690 v4
Motherboard: Z10PA-U8
GPU: Quadro
Post by Rhoqr »
i didn't read all 89 pages of this thread so apologies if that's been asked before.
anyway is there another way of writing these images? maybe dd or something else?
because Etcher only seems to write to flash drives/cards. but i'd like to use a partition of a real hard drive.
Post by MaLd0n »
Rhoqr, just restore
Rhoqr
CPU: E5-2690 v4
GPU: Quadro
Post by Rhoqr »
you mean with disk utility or the terminal "restore" program?
Edit: never mind, it worked with dd. thanks!
the3rdknuckles
CPU: i7
Motherboard: sli
GPU: 1060
Post by the3rdknuckles »
Ok so after doing everything up to the replacing EFI then install clover again when I reboot my trackpad doesn’t respond normally.
Post by MaLd0n »
the3rdknuckles, u ned check what trackpad u have
plop
CPU: intel
Motherboard: asus
GPU: asus
Post by plop »
28 Jan 2019, 13:03
Start a Post Installation
the3rdknuckles
CPU: i7
Motherboard: sli
GPU: 1060
09 Dec 2019, 15:47
Admin
Report Quick quote
Unread post 09 Dec 2019, 07:47
the3rdknuckles, u
this will work for the internal trackpad?
wanderson campos
CPU: wanderson
Motherboard: windows 10
GPU: ws
Post by wanderson campos »
28 Jan 2019, 13:03
4- Boot from USB
*Use a boot key(Gigabyte is F12, Asus is F8, etc)
*Select Boot MacOS Install from Olarila Image
Post by MaLd0n »
the3rdknuckles, check if device is i2c
allan968
CPU: i5 9400f
Motherboard: Gigabyte B360M Gaming
GPU: Gigabyte Rx 570 8gb
Post by allan968 »
Fala galera, tranquilos?
Alguém teve problema com essas ultimas atualizações do Catalina? Aqui estava funcionando fino, porém, fui deixar rodar uma atualização de uns dias atrás, eis que perdi o vídeo após a inicialização, rodei em modo verbose e não apareceu erro...
the3rdknuckles
CPU: i7
Motherboard: sli
GPU: 1060
09 Dec 2019, 19:56
I switched voodoo another and my trackpad works fine, but I switch the 2 Realtek and my WiFi still doesn’t work.
Post by MaLd0n »
use a última versão das kexts, allan968
azhakeid
CPU: Ryzen 3 2200G
Motherboard: Maxsun A320M
GPU: Saphire Pulse RX 560 4GB
Post by azhakeid »
how to fix at installer welcome mac os mojave keyboard and mouse stuck, im use mouse usb, and keyboard ps 2
6satyan
CPU: xeon e5 2650 v3
Motherboard: asus x99 e
GPU: gt 710
Post by 6satyan »
hello i have successfully installed Olarila catalina on machine but when i check geekbench it shows only 665 score for single core. Is there any problem with this.
I have Asus X99E with Xeon E5 2650v3, DDR4 8GB 2400 ram & Nvidia GT 710 2GB
Please help anybody...
the3rdknuckles
CPU: i7
Motherboard: sli
GPU: 1060
I need help with a few things. I have a probook 450 G5 on 10.13.6 but my WiFi doesn’t work. I have BCM94350ZAE for the WiFi card. I installed 2 things into library extension but after that I couldn’t boot so I redid everything before I got to that part. Also I haven’t done anything to the DSDT. I have a untouched one sitting in my usb installer for safe keeping. Also sometimes I noticed after I close a YouTube page I’m watching it will repeat the sound it made before I closed it. Also I get a bit of glitchy graphics. Please help!
Post by MaLd0n »
6satyan, need solve a pm
the3rdknuckles, need a full dsdt patches
azhakeid, try with one usb injector
aye1v5
CPU: g4560
Motherboard: msi b150 m
GPU: gtx1050ti
Post by aye1v5 »
pls help me my pc cant load to apple screen, here this video!
some one help me fix this, tks so much!
p/s im newbie and sry for my bad english :(
the3rdknuckles
CPU: i7
Motherboard: sli
GPU: 1060
I have no idea what to do with the DSDT.
