Abang81
CPU: HexaCore Intel Core i7-8750H,
Motherboard: Intel Cannon Point HM370, Inte
GPU: NVIDIA GeForce GTX 1070 With M
Post by Abang81 »
Hi Mald0n
Can you please check my files i cannot make nvidia working.I have to partition on ssd High Sierra where i try to make nvidia working and other partition with Catalina.
this is . output from run me app.
Gigabyte aero 15xv8
intel i7-8750 2.1-4.1
nvidia 1070 max-q
ups cannot attached runmeapp output file to large ?
6.8MB?
0x00001111
CPU: intel gold 6278
Motherboard: epc6212d8a
GPU: rx590
Post by 0x00001111 »
I am sorry to bother u again.
I have tried ssdt ec and every usb port with no lucky.
It get "AppleNVME assert failed", and stuck at "still wating for root device" with nvme=-1 or auto reboot without nvme=-1.
Because I have one intel DC P4500 (not support) and one C2000 pro (support).
An IONVMEFamily error will cause reboot without nvme=-1, and I found that the error relate to P4500. The address in error message is the same to P4500 in windows.
I image that can I disable P4500 in ssdt?
Post by MaLd0n »
Abang81, is a optimus notebook?
Added in 31 seconds:
0x00001111, no idea what happens
0x00001111
GPU: rx590
Thx anyway.
kylebro99
CPU: Intel i5-5200u
Motherboard: Lenovo* yoga 500
GPU: Intel HD 5500
Post by kylebro99 »
Installer won't boot for some reason, I tried both configs, and I'm unable to find efi partition to throw a custom plist.
the3rdknuckles
CPU: i7
Motherboard: sli
GPU: 1060
Post by the3rdknuckles »
Hi Maldon I was wondering... I’m just going to go with High Sierra since it’ll be more stable with the hardware that I have. The DSDT you gave me was when I was trying to install Mojave. Does it make a difference? Can I still use that DSDT in High Sierra?
0x00001111
GPU: rx590
I get error when compile ssdt.
syntax error, unexpected PARSEOP_ARG1
dsdt&ssdt.zip
Thx.
Post by MaLd0n »
kylebro99, mount efi partition
the3rdknuckles, use same
Added in 35 minutes 35 seconds:
0x00001111, very bug dsdt
azhakeid
CPU: Ryzen 3 2200G
Motherboard: Maxsun A320M
GPU: Saphire Pulse RX 560 4GB
Post by azhakeid »
pls help me to fix audio and my wifi driver (tenda w311ma) on my catalina amd :(
puna27_99
CPU: i7
Motherboard: intel
GPU: Nvidia 1050ti
Post by puna27_99 »
MaLd0n, Thank you so much for the guide. In the beginning I could not get to install my Nvidia GPU Geforce 1050ti so i changed my GPU to RX 580 and installed Mac OS Mojave and everything is working like a charm. Thank you so much.
Cejrie
CPU: i7-7700HQ
Motherboard: ASUS VX5-591G
GPU: GTX 1550Ti
Post by Cejrie »
Anyone can help me please?
I installed High Sierra 10.13.6 (17G9016). Which is working smoothly, I've got two problems tho.
One is the WIFI, but from what read in others forums I can't use my native WIFI board and will need a Broadcom M.2. Already brought it so no problem.
Second is the video. I have a 1050 Ti. I installed Nvidia Webdriver (387.1.10.10.40.132), which is recognized but for some reason it's only showing Intel Graphics card. I set config.plist to true in NvidiaWeb. I don't know what am I missing. If anyone can help I'll be thankful.
Notebook Config:
ACER VX5-591
Intel i7-7700HQ
16GB RAM
1TB SATA
Nvidia GTX 1050Ti 4GB
Post by MaLd0n »
azhakeid, audio
wifi check what chipset
Added in 35 seconds:
puna27_99, ;)
Cejrie, is a optimus, forget nvidia, u need use only intelhd
Enciomini
CPU: i7 6700k
Motherboard: Asus VIII Ranger
GPU: Shappire nitro+ 8gb special ed
Post by Enciomini »
28 Jan 2019, 13:03
L'immagine di Olarila è pulita, senza alcuna mod con bootloader Clover, kexts e patch essenziali , TUTTO all'interno della cartella Clove
Scrivo dall'Italia..volevo solo ringraziare..ho provato di tutto solo con la vostra immagine ho potuto installare Catalina. Grazie ancora :-)
Added in 42 minutes 43 seconds:
Fantastico... le ho provate tutte .... solo con Olarila ci sono riuscito!! Grazie ancora
sayerX12
CPU: CORE i7 Sandy Bridge
Motherboard: Fujitsu AH77/G
GPU: INTEL HD 3000
Post by sayerX12 »
My bios settings-------
Bios > advanced tab > Internal device configuration
Serial ATA controller--->enabled
AHCI configuration--->enabled
Bios>advanced tab> Cpu features
Multi-core-->enabled
HT technology--->disabled
SpeedStep technology--->disabled
Virtualization technology-->disabled
Bios >Advanced tab>USB features
Legacy usb support --> enabled
SCSI SubClass support -->enabled.....
These are the settings of my bios......any thing wrong with this settings..
Added in 1 minute 20 seconds:
Added in 1 minute :
Post by MaLd0n »
sayerX12, first shot just put sata mode to ahci, nothing more, just change things if need
0x00001111
GPU: rx590
It stuck at "still waiting for root device".
I use usb2.0 disk installer, but there are no usb2.0 on my motherboard.
cpu: intel Gold 6278(cascade lake)
motherboard: asrock epc621d8a
CLOVER.zip
Thanks you.
mero1212
CPU: intel
Motherboard: asus
GPU: intel
Post by mero1212 »
Hello,
-in my hackintosh in the section of acpi, I appear (Gaussian Mixture) eh tried to activate it by hackintool but there was no way!
Would you know how to activate it?
-otherwise the trackpad of my laptop, does not work the function of pulsation with 2 fingers (update vodoops2Controller.kext to the latest version, but my keyboard and trackpad stop working)
use another kext called Applesmart..but they were not detected either ..
thanks!! [External Link Removed for Guests]
Post by MaLd0n »
mero1212, Gaussian Mixture), is common, device stay not load
trackpad, u need check what device u have, ps2, i2c, synaptics, etc
mero1212
CPU: intel
Motherboard: asus
GPU: intel
Post by mero1212 »
05 Dec 2019, 20:12
How can I know which model is my laptop's trackpad?
but can you load gaussian mixture with some kext? or it doesn't matter if I leave it like that ..
Post by MaLd0n »
mero1212, just ignore this device
