sayerX12
CPU: CORE i7 Sandy Bridge
Motherboard: Fujitsu AH77/G
GPU: INTEL HD 3000
Post by sayerX12 »
Bios settings----
Advanced >Internal Device configuration----
Serial ATA controller--enabled
AHCI Configuration---enabled
Lan controller--enabled
Wireless lan--enabled
Advanced>CPU Features
Multi-core--Enabled
HT-Technology--Disabled
SpeedStep(R) Technology--Disabled
Virtualization Technology--Disabled
Advanced>USB Features
Legacy USB Support---enabled
SCSI subclass Support--- enabled
These are my bios config used to boot mac os...but stuck & auto rebooted end randomseed+++++++++
I can't attach jpeg files......so i detailed bios settings.....
Post by MaLd0n »
sayerX12, what system u try?
u can try a other uefi driver
kernel pm is checked?
mausandre
CPU: Intel Pentium G4560 Kaby Lake
Motherboard: BIOSTAR H110MHC
GPU: Nvidia GTX1050TI 4GB
Post by mausandre »
Does this guide requires a separate HDD or SSD drive?
If not, If I can install macOS on the same drive as Windows using Windows, what should I do differently?
Righ now I'm able to boot into Clover and run the option to install Olarila macOS, the verbose boot initiates but after that my computer just reboots and I'm back to Clover with the same option to install Olarila macOS.
Maybe I'm dumb but I'm not being able to acces the archives on the USB Stick due to the way it is formated, so I couldn't provide any log information from Clover.
Also, is there any known problem with my setup that may be causing any trouble?
I'm very grateful for any possible help, I'm trying to setup a Hackintosh for almost a week with no success.
Post by MaLd0n »
mausandre, ur processor need a fakecpuid
puna27_99
CPU: i7
Motherboard: intel
GPU: Nvidia 1050ti
Post by puna27_99 »
MaLd0n,
Hi...
I am getting a little confused at the post installation stage when you advise to run the disablehibernate.command. When I try to do so it asks for password at the terminal window. What is the password if I may ask or how to bypass it?
bibo2200
CPU: dual Processor XEON E5620 . 2.
Motherboard: Dell Precision WorkStation T75
GPU: Nvidia Quadro K4000
Post by bibo2200 »
01 Dec 2019, 21:00
bibo2200, try with other fakesmc version or virtualsmc
i try with nv_disabler=1 and boot successful But I faced a problem the disk utility doesn't see any HDD
Any help for this problem
Thank you
0x00001111
CPU: intel gold 6278
Motherboard: epc6212d8a
GPU: rx590
Post by 0x00001111 »
origin.zip
Components:
Asrockrack EPC621D8A
Xeon 6278 (LGA3647)
RECC 32G x 1
RX590
C2000pro 512G
intel DC P4500 2T (use for windows)
I hava tried install catalina by usb boot, but not lucky. I get still waiting for root devices.
Attach is ⁨EFI⁩ ▸ ⁨CLOVER⁩ ▸ ⁨ACPI⁩ ▸ ⁨origin⁩/ files.
Thx
Post by MaLd0n »
bibo2200, need edit dsdt with realocate
Added in 54 seconds:
0x00001111, try with other usb port
0x00001111
GPU: rx590
My motherboard have no usb2.0, I try others, not work. It get "applenvme assert failed" with boot argument nvme=-1, and auto reboot without nvme=-1.
mausandre
Post by mausandre »
03 Dec 2019, 03:46
Thanks for the reply Mald0n!
Can you give me any tips on how to access the EFI partition to make those changes? I actually know how to make the changes.
The problem is I've tried to mount the EFI on Windows with various methods but none of them gave me access to the folder, always saying I don't have permission to access it after is mounted.
Is there any way to modify the config.plist before formatting the USB Stick to the mac format?
Post by MaLd0n »
0x00001111, use ssdt ec
Added in 29 seconds:
mausandre, u can use O key in clover boot screen
WindowsMac
CPU: Intel Core i3-4005U
Motherboard: Lenovo B50 Laptop Motherboard
GPU: Intel HD 4400
Post by WindowsMac »
Will this method work with the Olarila Catalina Image?
Added in 45 seconds:
Post by MaLd0n »
WindowsMac, yes
azhakeid
CPU: Ryzen 3 2200G
Motherboard: Maxsun A320M
GPU: Saphire Pulse RX 560 4GB
Post by azhakeid »
how can i fix keyboard ps2 not work at catilna
Post by MaLd0n »
azhakeid, u can try it
bibo2200
Post by bibo2200 »
03 Dec 2019, 14:43
I'm sorry. How to edit dsdt
mausandre
Post by mausandre »
03 Dec 2019, 15:57
Wow, sorry for not noticing how to do that. Thanks for the help.
Now I was able to input the fakecpuid 0x0306A0 that worked for the guy in this post [Local Link Removed for Guests]
The post also suggests to use NullCPUPowerManagement.kext can I add this kext through Clover options, since I can't edit the files on Windows?
Using that fakecpuid is giving this panic message in verbose [External Link Removed for Guests].
Post by MaLd0n »
mausandre, edit ur config.plist with fakecpuid
mausandre
Post by mausandre »
03 Dec 2019, 19:27
Thanks again Mald0n!
I was finally able to edit the config.plist through windows and added the fakecpuid value to the file itself. I wasnt able to attach my config.plist file here, so this is a link to the file: [External Link Removed for Guests]
Here is the specific part I have inserted the fakecpuid:
<key>AppleIntelCPUPM</key>
		<true/>
		<key>AppleRTC</key>
		<true/>
		<key>Debug</key>
		<false/>
		<key>DellSMBIOSPatch</key>
		<true/>
		<key>FakeCPUID</key>
		<string>0x0306A0</string>
		<key>KernelCpu</key>
		<true/>
		<key>KernelLapic</key>
		<true/>
		<key>KernelPm</key>
		<true/>
		<key>KernelXCPM</key>
		<false/>
		<key>KextsToPatch</key>
		<array>
Now I'm getting a different error in verbose, one of the lines that caught my attention was: kernel[0]: WARNING: IOPlatformPluginUtil : getCPUIDInfo: this is an unknown CPU model 0x3c
Here's a link to the verbose screen I'm talking about: [External Link Removed for Guests]
Post by MaLd0n »
mausandre, try update kexts and clover
