azhakeid
CPU: Ryzen 3 2200G
Motherboard: Maxsun A320M
GPU: Saphire Pulse RX 560 4GB
Post by azhakeid »
anyone can help me ? stuck at logo apple after select boot high sierra from usb
Post by MaLd0n »
azhakeid, [Local Link Removed for Guests]
azhakeid
CPU: Ryzen 3 2200G
Post by azhakeid »
29 Nov 2019, 15:15
azhakeid, viewtopic.php?f=50&t=14783
i
After using the EFI folder for AMD, now it's only stuck on the Apple logo, what should I do with your guide?
ikbalyasid
CPU: Intel Core I7 2760QM
Motherboard: Acer E1-471
GPU: Intel HD 3000
Post by ikbalyasid »
29 Nov 2019, 15:09
use nullcpupm kext
Can you tell me how to do it? :D
Post by MaLd0n »
ikbalyasid,
NullCPUPowerManagement.kext.zip
ikbalyasid
GPU: Intel HD 3000
MaLd0n, how to use it? sorry but i'm very don't understand it. i search whole forum but i dont know how to do it :cry: :cry:
Post by MaLd0n »
ikbalyasid, clover/kexts/other
ikbalyasid
GPU: Intel HD 3000
MaLd0n, it still doesn't work :cry:
Post by MaLd0n »
ikbalyasid, no idea what happens, u need check it
ikbalyasid
GPU: Intel HD 3000
MaLd0n, i was replaced the kext that you give to me and move it to my installer drive with explore++. After that changed the config to notebook mode and add -x boot argument. It's anything wrong?
rocky_mtn
CPU: Intel Core i9-9900K
Motherboard: ASRock Z390 Phantom Gaming 9
GPU: MSI RX 580
Post by rocky_mtn »
@MaLd0n I need your help please? My motherboard had 2 gigabit NIC’s One is the Intel I219V and the other is the Intel I211AT and from what I read, I need mausiethernet and smalltree in order to make gigabit work. Can you confirm this and which files exactly? You patched my dsdt and everything is working great, other than I only have 100Mbps Ethernet and I should have gigabit. Thank you again in advance! You’re awesome!
New build ASRock Z390 Phantom Gaming 9 i9-9900K MSI RX580 8GB Catalina 10.15.2 32GB DDR4
First build ASRock Z270 Gaming K6 i7-7700K MSI RX580 8GB Mojave 10.14.6 32GB DDR4
Post by MaLd0n »
ikbalyasid, correct
rocky_mtn,
Arquivo Comprimido.zip
rocky_mtn
GPU: MSI RX 580
Post by rocky_mtn »
Just tried the above kexts installing to efi>clover>kexts>other and replacing my existing mausiethernet with the one you provided and I don’t have any connectivity now. Is there something else I need to do also?
Added in 48 minutes 15 seconds:
Do I need my dsdt patched again? I guess I don’t understand why I wouldn’t get gigabit speeds from my NIC’s? Now they aren’t working at all so I have to revert back to previous kext to get Ethernet back.
Post by MaLd0n »
rocky_mtn, compile kext in catalina
rocky_mtn
GPU: MSI RX 580
Post by rocky_mtn »
I’m on Mojave
Post by MaLd0n »
rocky_mtn, [External Link Removed for Guests]
rocky_mtn
GPU: MSI RX 580
Post by rocky_mtn »
This was a bad cable issue for anyone wondering. Thanks MaLd0n,
Spookd
CPU: i9-9900KS
Motherboard: Gigabyte Z390 Designare
GPU: Radeon 7 (AMD direct)
Post by Spookd »
Okay, I have followed directions up to the point of Flashing Olarila Image to the USB using balenaEtcher. Am I also supposed to do the Windows part too or is it that you can choose Mac OS or Windows burn but don't need to do both?
rocky_mtn
GPU: MSI RX 580
Post by rocky_mtn »
Spookd, You don’t need to burn both. Now load the Olarila boot loader onto the usb and fire it up and install.
Edit: the boot loader is already integrated into the image. All that’s left to do it insert the USB and run the installer. Just pickup from step 4 and you’ll be good to go.
Spookd
CPU: i9-9900KS
Post by Spookd »
rocky_mtn, Awesome! Thanks for the help. Crossing my fingers this can work. Nothing has up to this point and its starting to make me wonder if I did something wrong with the BIOS or hardware install someway somehow. I doubt I did its pretty easy straight forward but lately thats how things been going for me.
