Post by MaLd0n » 22 Nov 2019, 04:43
nnduong, remove i2c kexts
Will_Impulso
CPU: Intel i7-9700k
Motherboard: ASUS TUF-GAMING z390-plus
GPU: RADEON RX580 8GB
Post by Will_Impulso » 22 Nov 2019, 06:01
28 Jan 2019, 13:03
After installation, boot from USB stick again, use boot key and select your SSD with system installed
ola pode me ajudar?
nao consigo instalar o mojave, da sempre erro (apfs_module_start: 1393)
Post by MaLd0n » 22 Nov 2019, 16:41
Will_Impulso, vc precisa de um dsdt full patched
nnduong
CPU: Intel Core i7-8750H
Motherboard: alienware m15
GPU: Nvidia GeForce RTX 2060
Post by nnduong » 23 Nov 2019, 04:43
22 Nov 2019, 04:43
remove i2c kexts
Where is i2c sir, this is my usb after burn using Etcher.
vaguinho
CPU: intel core 2 duo 3.00ghz
Motherboard: gigabyte GA-G41MT-S2
GPU: NIVIDIA 9800 GT 256 BITS 1 GB
Post by vaguinho » 23 Nov 2019, 16:28
ola boa tarde faz dias que tento instalar ja tentei com el capiton, sierra , high sierra , mojave .Entao a instalaçao termina mas quando renicia para essa tela < *After installation, boot from USB stick again, use boot key and select your SSD with system installed > NAO aparece meu hd alguem pode me ajudar fazendo um grande favor AGRADEÇO DESDE JA :help
enolic
CPU: i7 6700HQ
Motherboard: HP Pavilion 15 / Intel HM170
GPU: HD530 + Nvidia GTX 960M
Post by enolic » 24 Nov 2019, 03:02
Vanilla: The easiest way to install hackintosh! Thank you!
epikingtosh
CPU: core i3 9100f
Motherboard: b365m gigabyte
GPU: rx 580
Post by epikingtosh » 24 Nov 2019, 05:16
Hello,
i have to replace motherboard and i want to know
does asrok 250m pro4 work smoth with 9100f and hankintosh?
thank you!
Farhan
CPU: Intel(R) Core(TM) i3 CPU 540
Motherboard: Intel H55 MS-8410
GPU: Intel® HD Graphics for i3 540
Post by Farhan » 24 Nov 2019, 13:01
hello. i am a noob at hackintoshing. Can i install hackintosh sierra/high sierra/mojave/catalina in the specs given below-
Processor Intel(R) Core(TM) i3 CPU 540 @ 3.07GHz, 3067 Mhz, 2 Core(s), 4 Logical Processor(s)
motherboard Intel H55 MS-8410
ram 6gb
and graphics integrated in the processor
*I know they are ancient*
If i can install mac os on this pc what version will it be And please provide a tutorial. Thanks
Post by MaLd0n » 24 Nov 2019, 15:46
epikingtosh, use gigabyte mobo and processors with IGPU for intel quick sync, processor "F" don't have IGPU
Added in 28 seconds:
Farhan, put one rx560
erroruser
CPU: AMD Ryzen 7 3700X
GPU: Sapphire rx 5700 XT
Post by erroruser » 24 Nov 2019, 15:53
new patches for the AMD
Ryzen3000 Patches.plist.zip
also generate an SSDT-PLUG, and AGPMInjector kext for AGPM
an can remove NULLCPU and MCE Kexts
:superman :superman
ymeri
CPU: I5
Motherboard: Medion
GPU: Intel HD Graphics
Post by ymeri » 24 Nov 2019, 20:42
i have problems with installing
Debugger called :< panic>
Backtrace (Cpu 0) Frame Return Address
What should I do :bye
ymeri
CPU: I5
Motherboard: Medion
Post by ymeri » 24 Nov 2019, 20:49
need your help
Thelion
CPU: Intel i3 3217
Motherboard: Acer Aspire
GPU: Intel HD 4000
Post by Thelion » 25 Nov 2019, 21:39
Sier how i'can fix webcam in my laptop it's not working???
Post by MaLd0n » 26 Nov 2019, 03:55
fix usb i think cam work
misterdray
CPU: Ryzen 3 1300x
Motherboard: GIGABYTE GA-AB350M-Gaming 3
GPU: ASUS ROG-STRIX-RX580-O8G-GAMIN
Post by misterdray » 26 Nov 2019, 08:07
Installed Catalina
Everything worked from the installer and apps folder. Have not tried Ethernet. Messages and FaceTime do not activate ( tried valid serial, tried messagefixer, any ideas?) iCloud connects, appstore works. Did not do dsdt just yet.
I also use 3 monitors, and two work absolutely fine and the other one works with a pink tint, I've tried different stuff, any idea? What else should I check?
Hardware:
Ryzen 3 1300x
GIGABYTE GA-AB350M-Gaming 3 w/ latest bios
ASUS ROG-STRIX-RX580-O8G-GAMINGOC
Ballistix Sport LT 16GB 2400 DDR4
Post by MaLd0n » 26 Nov 2019, 13:35
misterdray, [External Link Removed for Guests]
misterdray
CPU: Ryzen 3 1300x
Post by misterdray » 26 Nov 2019, 18:58
26 Nov 2019, 13:35
I already tried to force the RGB, it doesn't work. No matter what monitor is plugged in with that HDMI it goes pink. I use a Display Port , HDMI, and DVI. Display Port is connected to a HP 32" 1440p in landscape, and 2 Acer S241HL 1080p monitors in portrait. All monitors will go pink if plugged into that port on my card.
Added in 3 minutes 14 seconds:
26 Nov 2019, 13:35
Post by MaLd0n » 26 Nov 2019, 19:30
misterdray, no idea what happens
misterdray
CPU: Ryzen 3 1300x
Post by misterdray » 27 Nov 2019, 01:19
26 Nov 2019, 19:30
Thanks for the help. I think its just a software issue, Id have to install Mojave to see if I get the same issue as I do not have this issue with Windows running triple monitor or Eyefinity.
Pabloramos
CPU: I3 6100
Motherboard: Gb z170m
GPU: Es 560
Post by Pabloramos » 27 Nov 2019, 05:44
28 Jan 2019, 13:03
My suggestion, Install Clover bootloader again after replace Clover folder
*Reboot
