Post by MaLd0n » 12 Nov 2019, 16:35
nithinxjohnson, after install send_me files, i'll check
dswariors11
CPU: Inter Core i3-2100
Motherboard: GA H61m-ds2
GPU: GT-1030
Post by dswariors11 » 12 Nov 2019, 23:45
Thanks for this thread. I am finally able to use Hackintosh.
Now I want to same as have a fast boot and disable the boot options something like this on video
I tried to search, but I haven't found it for this thread please help someone.
@Maldon
lmgentil
CPU: i7 8700
Motherboard: Z390 M Gigabyte Gaming
GPU: RX 580 8GB
Post by lmgentil » 13 Nov 2019, 03:42
Maldon,
Estou problema na instalação Inicial.
Segue o erro acima, fica nesta tela
As configurações são compatíveis ao high Sierra
I7 8700
16gb ram
Z390 Gigabyte gaming
Nvidia 1060 6gb
O que posso fazer?
Post by MaLd0n » 13 Nov 2019, 13:01
lmgentil, use nv_disable=1
Chemotion
CPU: AMD A6-5200
Motherboard: idk
GPU: AMD Radeon HD 8400
Post by Chemotion » 14 Nov 2019, 08:22
Hey im attempting my first install on my hp laptop . I keep getting stuck on boot. All it does is show **********************************. I have made sure to use the correct configs but no hope. any help would be appreciated
Added in 11 minutes 58 seconds:
Hey im trying to install catalina on my laptop using this guide . However whenever i go to boot into macos from my usb it displays ***************************. It gets stuck on boot and freezes. Any ideas?
Post by MaLd0n » 14 Nov 2019, 13:54
Chemotion, U need post ur hardware spec
kbelludoo2019
CPU: fx 8120
Motherboard: ga 990 fxa
GPU: gt 750 ti
Post by kbelludoo2019 » 14 Nov 2019, 14:00
28 Jan 2019, 13:03
Image is clean, without any mod with Clover bootloader, essentials kexts and patches, ALL inside Clover folder
Post by MaLd0n » 14 Nov 2019, 14:01
kbelludoo2019, yes, is vanilla
debakid
CPU: i7 8700
Motherboard: lenovo
GPU: intel
Post by debakid » 14 Nov 2019, 15:05
Hi, after 2 weeks of trying, I got Catalina working on HP 800 G3 SFF, I7 7700, Intel HD630, 16GB RAM, Samsung 256GB SSD drive. I had to swap the Sata SSD drive with a SATA drive to get it going. How do I get it working with the built in SSD drive ? I am getting "An error occured while preparing the installation. Try running this application again."
Post by MaLd0n » 14 Nov 2019, 15:38
debakid, [External Link Removed for Guests]
debakid
CPU: i7 8700
Motherboard: lenovo
GPU: intel
Post by debakid » 14 Nov 2019, 18:29
Thank you for the prompt reply Mald0n. I will use that link in the future. For some strange reason, I left it for a few minutes with the error. It rebooted the computer and procceded with the booting on the MAC HD. It is now saying about 5 minutes remaining in the second part. It's been going for over 2 hours. I will let you know what happens.
lmgentil
CPU: i7 8700
GPU: RX 580 8GB
Post by lmgentil » 15 Nov 2019, 02:17
13 Nov 2019, 13:01
Posso efetuar essa instalacao com cabo de video conectado ao nvidia ? dvi? utilizando desta bootflag
debakid
CPU: i7 8700
Motherboard: lenovo
GPU: intel
Post by debakid » 15 Nov 2019, 02:36
Mald0n, it did work. It took over 5 hours, but i got to install. How do I add EFI to the HD so that I do not need the USB to boot? The instructions you have does not work with catalina and new clover. I tried it with clover r4922 it told me that it was not compatible.
Thanks,
****** PLEASE DISREGARD or remove post******
I copied boot files from USB. I am able to boot from HD now.
Many Thanks, for this great guide and tools
Post by MaLd0n » 15 Nov 2019, 02:46
lmgentil, se for o high sierra sim
lmgentil
CPU: i7 8700
GPU: RX 580 8GB
Post by lmgentil » 15 Nov 2019, 22:24
13 Nov 2019, 13:01
Coloquei mas permanence a mesma coisa no high Sierra .
Por curiosidade no catalina ele entrou ao instalador, mas nele não há suporte para o nvidia...
O que pode ser? :( :(
dswariors11
GPU: GT-1030
Post by dswariors11 » 15 Nov 2019, 23:46
Waiting for your reply @Maldon
Thank you so much btw, please help me to achieve this like on the video fast boot.
I wanted to disable boot option on Olarila and I don't know how to do it I just want to fast boot.
I tried to search, but I haven't found it.
rocky_mtn
CPU: I7-7700K
Motherboard: ASRock Z270 Gaming K6
GPU: MSI RX 580
Post by rocky_mtn » 16 Nov 2019, 04:15
I keep getting stuck on this part. Photo attached. Vanilla Mojave image stuck at installkextd “appleacpicpu” over and over. I’ve check bios settings and tried nv_disable=1 and they don’t seem to help. ASRock Z270 gaming k6 board, I7-7700K CPU, Intel HD 630 iGPU and Radeon RX 580. Any question please let me know. I’ve verified this machine will run macOS with other installation methods, but I don’t like where they store non-oem kexts so I really want to use olarila. Please help @MaLd0n Image
rocky_mtn
CPU: I7-7700K
GPU: MSI RX 580
Post by rocky_mtn » 16 Nov 2019, 15:55
Does anyone have an idea? I kinda wanted to get rolling on this over the weekend...TIA
Post by MaLd0n » 16 Nov 2019, 16:54
dswariors11, maverick have a fast boot, today we have 3 sec more
Added in 29 seconds:
rocky_mtn, inject kexts problem, update clover
ulfsjar
CPU: 6700K
Motherboard: GA-Z170-HD3P
GPU: HD 7750
Post by ulfsjar » 17 Nov 2019, 12:35
Hi, I just installed Catalina however when I try to boot it from the USB, it gets stuck after loading the OS and leaves me on black screen, sometimes reboots by itself after loading everything. I cannot get into the system. It's probably a GPU related issue but I can't really tell since it's my first time. How can I fix this? :work:
My hardware;
CPU: 6700K
GPU: AMD RADEON HD 7750 1GB
MOBO: GIGABYTE GA-Z170-HD3P
[EDIT]
I fixed my issue by adding radpg=15 to the boot options.
