Post by MaLd0n » 08 Nov 2019, 13:13
Tazorro, use fresh install if need
telepati
CPU: i9 9900K
Motherboard: GigaByte Z390 M Gaming
GPU: Asus ROG RX 560
Post by telepati » 08 Nov 2019, 16:33
MaLd0n, I am using 32GB USB and when I burn your image with etcher USB disk is full. Why this happening?
Post by MaLd0n » 08 Nov 2019, 16:57
telepati, if u need use ur 32gb, create a manual usb stick
domluu
CPU: AMD Ryzen 7 2700X
Motherboard: Asus Prime X570-Pro
GPU: Sapphire Radeon RX 5700
Post by domluu » 08 Nov 2019, 21:07
Hello Beautiful People,
I got to the install portion for Catalina and got this message:
AMF: Only 175/256 slide values are usable!
Valid Slides: 81-255
Might anyone know what the problem is and what to do?
Thank you kindly!
System:
AMD Ryzen 7 2700X
Asus Prime X570-Pro
Sapphire Radeon 5700
Corsair DDR4 3200 - 8GB x 2
Post by MaLd0n » 08 Nov 2019, 21:10
domluu, check this new folder
v18amagdy
CPU: Core I3 8100
Motherboard: GB H310M S2h
GPU: UHD 360
Post by v18amagdy » 09 Nov 2019, 02:58
Hello Guys ,
Today i downloaded the Catalina raw & will tried to install i facing my PC stoped on this step
VoodooPS2Mouse: Version 1.9.2 Starting on os x Darwin 19.0.
What should i do ?
My Pc
Processor : Core i3 8100
Motherboard : GB H310M S2H
Ram : DDR4 2400
Post by MaLd0n » 09 Nov 2019, 04:44
v18amagdy, update ur signature with correct hardware spec
frozenade
CPU: i7
Motherboard: Intel
GPU: Intel
Post by frozenade » 09 Nov 2019, 06:38
Hi, MaLd0n
I installed Cataline 10.15.1 successfully. But I got this while running RunMe.app
Please help.
Post by MaLd0n » 09 Nov 2019, 06:40
frozenade,
--Run_Me
nithinxjohnson
CPU: Intel
Motherboard: G31
GPU: Nvidia GT 710
Post by nithinxjohnson » 09 Nov 2019, 13:55
@MaLd0n
Is Old Nvidia Gt 9500 1GB DDR2 supported in macos high sierra? Does it requires any additional kext or continue with Inject Nvidia in config.plist file?
Thanks in advance!!!
Post by MaLd0n » 09 Nov 2019, 16:53
nithinxjohnson, Just InjectNvidia
vaguinho
CPU: intel core 2 duo 3.00ghz
Motherboard: gigabyte GA-G41MT-S2
GPU: NIVIDIA 9800 GT 256 BITS 1 GB
Post by vaguinho » 09 Nov 2019, 17:46
maldon fiz a tecla f4 na tela de boot antes de instalar e fiz depois mas nada de aparecer o hd com nome que instalei so falta isso instala tudo mas o hd nao aparece na tela de bot
:poke
Post by MaLd0n » 09 Nov 2019, 18:32
vaguinho, o f4 vai gerar as tabelas na pasta clover/acpi/origin, tem de editar elas
lorenzolamasse
CPU: Intel Core i7 8700K
Motherboard: Gigabyte Z390 UD (BIOS F7)
GPU: Nvidia Geforce GT730 2GB
Post by lorenzolamasse » 09 Nov 2019, 18:43
Dear Maldon,
I have downloaded a fresh copy of the image (Mojave), I'm stuck when booting installer on ACPICPU being stalled, no matter what config.plist I choose, here is the config I'm trying to install:
Laptop DELL XPS 13 9350 / CPU Skylake-U 6560U / Iris 540 / NVME Toshiba 512GB
Any clue ?
Thanks !
Post by MaLd0n » 09 Nov 2019, 19:46
lorenzolamasse, try update clover bootloader to last version/revision
vaguinho
Post by vaguinho » 09 Nov 2019, 20:27
09 Nov 2019, 18:32
Mensagem por MaLd0n » 09 Nov 2019, 15:32
poderia me ajudar como editar essa pasta se existe algum progama ou como fazer pq uso windows 10 e a pasta efi nao abre no windows
Post by MaLd0n » 09 Nov 2019, 20:30
vaguinho, primeiro, qual o sistema que vc está tentando instalar?
pra esse tipo de hardware é melhor usar a ferramenta do dosdude
hardware sem suporte total nos novos sistemas
vaguinho
Post by vaguinho » 09 Nov 2019, 20:42
09 Nov 2019, 20:30
Olarila Mavericks 10.9.5
Post by MaLd0n » 09 Nov 2019, 22:49
vaguinho, mavericks não precisa de nada extra, só setar ahci no bios, se o chipset não suporta ahci deve funcionar em ide mode, não sei o que está causando isso
garviniciu
CPU: Intel Core i5 - 2500
Motherboard: Asus P8H67-M Pro
GPU: Gigabyte GT640
Post by garviniciu » 09 Nov 2019, 23:05
Boa noite! Por favor alguém sabe me dizer se a NVIDIA GT 640 está funcionando no mac OS Catalina? Tem webdrivers? Grato!
