tominhthanh2308
CPU: i5-7300HQ
Motherboard: Asus GL553VD Series Notebook
GPU: Intel(R) HD Graphics 630
Post by tominhthanh2308 » 15 Oct 2019, 15:54
When boot complete, my disk unity can't detect my HDD. In BIOS, sata config is AHCI, please help me. Sorry my english is bad :(
underdrive
CPU: 8700k
Motherboard: z370 aorus gaming 5
GPU: 1080ti
Post by underdrive » 15 Oct 2019, 16:54
Thanks!
Send me nichs-iMac.zip
Post by MaLd0n » 15 Oct 2019, 20:18
tominhthanh2308, use boot key for load usb stick with apfs/hfs drivers
Added in 46 seconds:
underdrive, i edited ur files, is same files, don't need edit again, just update clover and kexts
NOTORIOUS VR
CPU: 2600K
Motherboard: GA-Z77N-WIFI
GPU: GTX 670 2GB
Post by NOTORIOUS VR » 16 Oct 2019, 00:43
So I did a fresh install of Catalina with your image... at first I couldn't install because no SMBIOS was set at all (empty/blank) - Set to iMac 13,2 and I was able to continue the installation.
After this I followed the instructions on the first page, Clover 2.5 r5096 warns that it is not compatible with this OS version, and then fails to install at all.
I don't know what to do now. I haven't deviated at all from your instructions except change/edit config.plist fir SMBIOS setting.
Any ideas?
Post by MaLd0n » 16 Oct 2019, 01:01
NOTORIOUS VR,
run it
and it
and try install clover again
if u use a uefi mode don't need install clover, just put efi folder inside efi partition
NOTORIOUS VR
CPU: 2600K
GPU: GTX 670 2GB
Post by NOTORIOUS VR » 16 Oct 2019, 01:38
Hi, thanks for your quick reply but I believe the issue was a mistake of my own when I formatted/partitioned the drive on the previous installation. I reinstalled (and erased the disk again) and now Clover installation is ok. Also I did run the scripts just as you advised in your main post.
I am following the steps now to install the EFI folder and the files you made for me. I will report back soon.
Thank you again. 8-)
EDIT: Spoke too soon.
I was able to install Clover the first time, then I copied your EFI folder and now I cannot install it again over it as you suggest - it fails at the same point as before. I will copy the files manually as I am booting UEFI only.
luizteck
CPU: Intel Core i3-2350M @ 2.30GHz
Motherboard: Sony VPC-EH30EB
GPU: Intel Graphics 3000
Post by luizteck » 17 Oct 2019, 02:57
Problemas ao tentar instalar no Sony VPC-EH30EB está dando o erro "ehci controller unable to take control from bios"
Alguém já conseguiu instalar num desses? Gostaria de um auxilio para poder instalar nesta máquina. Estou tentando o El Capitan.
Post by MaLd0n » 17 Oct 2019, 13:12
luizteck, veja se funciona
EFI.zip
noiiz
CPU: i7 6700HQ
Motherboard: Dell
GPU: GForce GTX 960M
Post by noiiz » 18 Oct 2019, 13:35
Na instalação do Catalina em um Dell Inspirion altero o config para config2 e começo a instalação só que só aparece uma pequena barra cinza e fica nisso por uns 10-15 minutos até o note reiniciar, não mostra nenhuma mensagem nem nada, tem algo que possa fazer para mostrar logs ou algo do tipo ?
Post by MaLd0n » 18 Oct 2019, 14:30
noiiz, não precisa do config2, use o default
bobenia
CPU: intel i7 5930K
Motherboard: Asus x99a
GPU: Nvidia GTX970
Post by bobenia » 18 Oct 2019, 15:27
installation finished succesfully on my ASUS Notebook.
After restarting it loads until Welcome Screen them it restarts.
Notebook specifiactions [External Link Removed for Guests]
any ideas how to fix this?
noiiz
CPU: i7 6700HQ
Motherboard: Dell
Post by noiiz » 18 Oct 2019, 15:40
18 Oct 2019, 14:30
Mesmo com o config default fica da mesma forma, apenas uma "barrinha" cinza e depois de 15 minutos +o- a tela a barrinha some e o note reinicia:
Já usei o Olarila Catalina.raw e o Olarila Catalina Intel.AMD.raw , com o mesmo resultado nos 2
noiiz
CPU: i7 6700HQ
Motherboard: Dell
Post by noiiz » 18 Oct 2019, 17:28
Tentei o Mojave tambem, e fica na mensagem Start Initdevicetree e não tem mais nenhuma ação após
Post by MaLd0n » 18 Oct 2019, 17:29
noiiz, primeiramente atualiza a sua assinatura pra gente saber qual é o hardware
noiiz
CPU: i7 6700HQ
Motherboard: Dell
Post by noiiz » 18 Oct 2019, 17:57
Atualizei com os dados que possuo;
é um Note Dell Inspiron 7559 i7 6770HQ , NVIDIA 960M, 16gb ddr3, SSD Corsair 512Gb
Post by MaLd0n » 18 Oct 2019, 18:59
noiiz, tenta com -x pra desativar alguns drivers, safe mode
noiiz
CPU: i7 6700HQ
Motherboard: Dell
Post by noiiz » 18 Oct 2019, 19:57
Tentei com o -x (barra de espaco no menu e marquei o checkbox) tanto no Mojave quanto no Catalina, os 2 ficam da mesma forma (Mojave para no Start Initdevicetree e o Catalina na barrinha cinza e depois reinicia )
Criei o pendrive no windows com o Win32DiskImager tem algum problema ?
Post by MaLd0n » 18 Oct 2019, 20:08
noiiz, eu usei esse programa há muito tempo atrás, não sei como está hj em dia, mas deve funcionar, só extrair a imagem antes de queimar
nithinxjohnson
CPU: Intel
Motherboard: G31
GPU: Nvidia GT 710
Post by nithinxjohnson » 19 Oct 2019, 05:06
@MaLd0n
I am having a nvidia gtx 1050 on my high sierra . I can't find a good guide to get full acceleration for my gpu
..can you plz help me..
Thankz in advance...
Post by MaLd0n » 19 Oct 2019, 14:59
nithinxjohnson, use it
check NvidiaWeb in System Parameters tab
and clear nvram with F11 in Clover boot screen
