🎉 NEW Discord server!
luizorlandi
CPU: Samsung Ultrabook S5
Motherboard: Samsung NP530U3C-K2BR
GPU: Intel HD 3000
Post by luizorlandi »
Super obrigado MaLd0n, !!
i5 6400 / Mobo Gigabyte GA-H110M-H DDR3 / 16GB DDR3 Corsair Vegeance @ 1600mhz / HD Graphics 530 / SSD 240GB / HDD 2TB
asapreta
Post by asapreta »
Pessoal.
Boa noite
Baixei a imagem aqui do Olarila do Mojave e não consigo formatar o drive SSD para o apfs e com isso instalar o sistema bem como poder atualiza-lo depois.
Alguma dica?
Obrigado
mozbius
CPU: i7
Motherboard: P6T Deluxe v2
GPU: GTX 260 SLI
Post by mozbius »
02 Oct 2019, 18:47
hackintool
Hi MaLd0n,
whenever I try to run Olaria High Sierra USB stick installer I end up on a black screen after selecting "Boot macOS Install from Olarila High Sierra 10.13.6" then nothing happens. I don't get the macOS installer screen.
I have a P6T Deluxe v2 Legacy motherboard with GTX 260 Nvidia SLI cards and installing on a SSD drive...
Do I need to follow the hackintool guide to get through? If so should I copy the generated config.plist file onto the Olarila High Sierra Installer USB key (if so where)?
I am running High Sierra 10.13 at the moment so I still have access to a Hackintosh to tinker around to get the USB key installer setup to work properly with my computer.
Post by MaLd0n »
mozbius, try with InjectNvidia, if don't work try disable some driver with -x
mozbius
CPU: i7
GPU: GTX 260 SLI
Post by mozbius »
Hmmm i tried several things but nothing that really makes matters better... Any suggestions?
Added in 36 minutes 23 seconds:
Notice that booting to simply get clover’s “Welcome to Clover 5078 **** scan entries ****” screen takes an extraordinary 1m45s (after PC initial Bios booting sequence) while it takes seconds with enoch on the 10.13 distro that I am currently running. Perhaps that could give a hint of what may be my problem when I try to install 13.13.6 as new.
Post by MaLd0n »
mozbius, u try inject only one, just in first card?
asapreta
Post by asapreta »
Pessoal.
Boa noite
Baixei a imagem aqui do Olarila do Mojave e durante o install, não consigo formatar o drive SSD para o apfs e com isso instalar o sistema. Tentei já entrar no installer com ele previamente instalado mas não é reconhecido.
Dando boot com verbose vejo que o disk0 dá I/O error.
Sei que pode ser alguma dúvida antiga mas dei uma procurada e não achei uma solução.
Alguma dica?
Obrigado
Post by MaLd0n »
asapreta, deve ser problema que tem no chipset ICH10 entre outros, tem um patch pra isso, tem de ver a versão certa pro seu sistema
asapreta
Post by asapreta »
08 Oct 2019, 23:30
Obrigado pela resposta.
Sabe onde posso encontrar o patch?
Post by MaLd0n »
asapreta, [External Link Removed for Guests]
asapreta
Post by asapreta »
Obrigado, havia achado esse mas é pro high sierra.
mozbius
CPU: i7
GPU: GTX 260 SLI
Post by mozbius »
08 Oct 2019, 16:08
I will give your suggestion a try.
When selecting InjectNvidia should I also select other options (Generic, No EFI, Single, Web drivers, Load Video Bios) for the GTX 260 video card ([External Link Removed for Guests])?
Do you suggest I do both -X and Inject at the same time on one card?
Post by MaLd0n »
mozbius, if u inject -x some drivers don't load
mozbius
CPU: i7
GPU: GTX 260 SLI
Post by mozbius »
09 Oct 2019, 19:55
Ok that is what I thought but I wanted to double check to see if -x would disable all drivers except those specified manually.
I will try the Inject + each of the other options on card a time, hopefully I will eventually get to to the macOS setup screen that way.
viciusvcs
CPU: i5 7600k
Motherboard: B250m-Plus
GPU: RX580 8GB
Post by viciusvcs »
:crazy: :crazy: :crazy:
smeakol
CPU: 3570k
Motherboard: sabertooth z77
GPU: rx 580
Post by smeakol »
28 Jan 2019, 13:03
Replace Clover folder with Olarila Clover folder
mozbius
CPU: i7
GPU: GTX 260 SLI
Post by mozbius »
08 Oct 2019, 16:08
Ok I have figured out... It looks like NVDAStartup.kext in /System/Library/Extensions on Olarila MacOS 10.13.6 USB has dropped support for GTX 260 based videocards. Replacing it with elCapitan's kext (found on tonycrapx86) resolves my black screen issue. I don't need to touch any option and can simply go with the default values and the setup screen shows up.
UPDATE:
I also was unable to see my SSD drive when trying to install Olarila macOS High Sierra 10.13.6 (even after enabling ACHI in BIOS). Solution was provided on YouTube ([External Link Removed for Guests]) where a set of KEXTS are provided to be put on the EFI partition of the USB (EFI/CLOVER/KEXT/OTHER).
djuby
Donator
Donator
CPU: Intel Core i7 – 5600U @ 2.6 GH
Motherboard: Dell Latitude E5450
GPU: Intel HD5500
Post by djuby »
Hi MaLd0n,
Hope you are well. Quick question - how should I upgrade to Catalina from Mojave? Install over Mojave or do a clean installation?
Best regards,
Djuby
Post by MaLd0n »
djuby, both options work ;)
Clawric
CPU: Intel Core i7-740QM 2.93 GHz
Motherboard: OEM Motherboard
GPU: Geforce GT 330M
Post by Clawric »
Hi i tried to install 10.13.6 on gt 330 i7 740qm but when i boot into install usb it shows me this
