Post by MaLd0n » 14 Sep 2019, 17:53
mauimade71, check my signature, useful links
-Donated? Send me one PM-
Harshkumar07
CPU: Intel Core i5 4690
Motherboard: Gigabyte B85M Gaming 3
GPU: Nvidia GT 730 2GB GDDR5
Post by Harshkumar07 » 14 Sep 2019, 20:55
Hi Maldon. As you said, I disabled the SpeedStep in bios but it didn't worked. Cpu still idle at 0.8GHz. I googled and found an app "Volta". It's basically an app for undervolting Macbooks. It also has a Performance mode which locks the Cpu to its highest frequency. But sadly, not the iGPU which still idles at 0.2GHz. Is there any method in Mac os to change the frequency configuration of both Cpu & iGPU? Please help me.
Post by MaLd0n » 15 Sep 2019, 01:40
Harshkumar07, No idea
its_shark
CPU: i7 920
Motherboard: GA X58-UD7
GPU: ATI RADEON HD 5750
Post by its_shark » 17 Sep 2019, 03:52
Hi, can anyone help me out, this is the hardware i'm planning to use:
1) GA X58A-UD7 Rev1.0
2) i7-920
3) ATI Radeon HD 5750 1gb GDDR5
4) 8GB RAM
which version should i boot and any guide or important thing i should look out for?
capitanbelico
CPU: Core i5 9400F
Motherboard: Z390-UD
GPU: XFX RX 580 + GTX 1050 Ti
Post by capitanbelico » 17 Sep 2019, 13:32
Using raw image of Catalina fron here and etcher RH process was fast, bit during instalación whem remains 2 minutes installer stuck hanging and dont works.
I tried repeat installation proccess 4 times and aleways stuck remaininng 2 minutes. :hammer
Post by MaLd0n » 17 Sep 2019, 13:49
its_shark, i think sierra only, ur gpu i think loose support ion high sierra+, check it
bazsound
CPU: i7-3632QM
Motherboard: Sony VAIO Intel HM76
GPU: AMD Radeon HD 7550M/7650M
Post by bazsound » 19 Sep 2019, 11:13
Finally getting somewhere with my install. after many days wifi issues (ar9485) can move onto the next stage of the install guide.. BTW is it a known bug that installing a kext can break the system in Catalina? When I installed the kext that got my wifi working, it broke the system. On boot with just stop with kext cache error. I reinstalled over my install to get it working again.
anyway, I'm really struggling with the chipset part of the install. I installed using the Catalina image, everything went easy didn't have to change any configs to get the install working. it installed it booted up created my account all great. I've installed clover and copied over the clover folder from the USB stick and great boots from HD!!!
So now I download clover for my chipset. I have a Sony Vaaio SVE laptop with qudcore i7 and and 7650m graphics. I download series 7 chipset , copy over the folder but it freezes at ps2synaptics (I'm guessing this is just before it loads guy) and no messages after that. I tried notebook series 7 same thing but it gives a few more errors suggesting this is wrong chipset.
So back to normal series 7, I notice it complaining about virtualsmc refi broken, so I re move it and replace with fakesmc, now it looks normals yet still freezes in same place....
Tried copying over the working plist from clover, still same...
:/ anyone help getting correct chipset so I can continue onto next step of building a a better system???
Post by MaLd0n » 19 Sep 2019, 15:52
bazsound, post ur efi here
bazsound
CPU: i7-3632QM
Post by bazsound » 19 Sep 2019, 17:44
EFI copy.zip
here is my refi folder from the internal SSD
Post by MaLd0n » 19 Sep 2019, 21:00
bazsound, use it
bcombs1
CPU: 8700K
Motherboard: Gigabyte 370 Auros gaming wifi
GPU: Radeon 580 Sapphire
Post by bcombs1 » 20 Sep 2019, 00:21
Greetings everyone,
I am unable to get any Catalina image to create a bootable.
I get this error with the file downloaded "Olarila Catalina B8.raw"
I also tried using terminal with what downloads from the Apple beta utility
It would not boot. Only returns to the bios screen after selecting the USB to boot.
I can create a bootable with unishit, but not working with anything here so far.
B
Post by MaLd0n » 20 Sep 2019, 01:08
bcombs1, if have problem with our server, use google drive link
bcombs1
CPU: 8700K
Post by bcombs1 » 20 Sep 2019, 02:08
There is not issue with pulling down the files from either of your locations. After opening the RAR The file that unarcives is a .raw file.
It just throws a corruption error when attempting to use it with Etcher.
I looked for something to do to this .raw file google can't make sense of it either.
Post by MaLd0n » 20 Sep 2019, 03:36
bcombs1, u use a last version? 1.5.57
bazsound
CPU: i7-3632QM
Post by bazsound » 20 Sep 2019, 10:00
Thanks for clover file. Unfortunately my system freezes during boot... Tried to attach photo but forum says invalid file extension.
It freezes at
Apfs_moduke_start:1603: load: com.apple.filesystem's.apfs v1412.11.4, apfs-1412.11.4
Clawric
CPU: Intel Core i7-740QM 2.93 GHz
Motherboard: OEM Motherboard
GPU: Geforce GT 330M
Post by Clawric » 20 Sep 2019, 14:12
hi I got a new wireless keyboard but it's PS/2 so I had to buy an adapter it does recognize it but it does not work the light is blinking as it should but it does not work. I tried using it on Windows and it works fine. don't no why it doesn't work here.
bcombs1
CPU: 8700K
Post by bcombs1 » 20 Sep 2019, 21:48
unable to work with downloaded Olaria Catalina installer. Olarila Catalina B8.raw.bz2
Downloaded Unarchived with "unarchiver"
Changes file extension from .raw to .dmg
Opened Etcher Version 1.5.57 (1.5.57)
Error after authorization
I have successfully used createmedi in Terminal and have the image from apple on USB
Is there another way to do this starting with the USB Catalina bootable I have from create media / terminal?
B
Post by MaLd0n » 21 Sep 2019, 02:42
bcombs1, u need burn with .raw
bcombs1
CPU: 8700K
Post by bcombs1 » 21 Sep 2019, 14:17
I change the extension back and tried again. Same error message.
Post by MaLd0n » 21 Sep 2019, 15:00
bcombs1, idk what happens
