Post by MaLd0n » 04 Sep 2019, 18:25
lucashps, sim
-Donated? Send me one PM-
abhi3534
CPU: core i3 7100
Motherboard: gigabyte h110 ds2
GPU: gtx 1070
Post by abhi3534 » 07 Sep 2019, 13:42
MaLd0n, hello there plz help me with this its stuck at apfs module as given in the screenshot plz help me with this
confi:-
core i5-2410m
4gb ddr3
nvidia geforce 410m
sony viao vpceg18fg
Added in 4 minutes 55 seconds:
Guys plz help me with this its stuck at apfs module as given in the screenshot plz help me with this
confi:-
core i5-2410m
4gb ddr3
nvidia geforce 410m
sony viao vpceg18fg
Post by MaLd0n » 07 Sep 2019, 17:07
abhi3534, u need check what cause it, idk
lucassantos349
CPU: i5 8400
Motherboard: GIGABYTE B360M D3H
GPU: POWERCOLOR RX 570 4GB
Post by lucassantos349 » 08 Sep 2019, 16:07
Olá, segui as instruções de instalação do Clover, Substitui a pasta pela do Chipset 300, e instalei novamente o bootloader, mas após reiniciar o hack, o clover carrega, mas não aparece o disco com o mac, somente aparece as opções: Clover Option, Option.......Consigo entrar ver o disco somente se eu utilizar um pen drive bootavel que tinha utilizado para a formatação. Se puder me ajudar com isto e também com a DSDT fico feliz.
Post by MaLd0n » 08 Sep 2019, 16:38
lucassantos349, vc não precisa instalar o clover, é só colar a pasta EFI chipset serie 300 na partição EFI
caberg2000
CPU: i3 4170
Motherboard: Asrock H81M-VG4 R2.0
GPU: GTX 1050ti
Post by caberg2000 » 10 Sep 2019, 05:12
Hi im new here and it's my first time using hackintosh and my plan is High Sierra, is this guide works for my rig specs? here my rig:
i3 4170
8Gb Memory
120Gb SSD
GTX 1050ti
thx before
mac_poweruser
CPU: i5
Motherboard: ibm
GPU: nvidiA
Post by mac_poweruser » 10 Sep 2019, 09:27
28 Jan 2019, 13:03
*Hardware E
MANO02
CPU: AMD RYZEN 5-2400 G
Motherboard: Gigabite B450 I AORUS PRO WIFI
GPU: Gigabite
Post by MANO02 » 10 Sep 2019, 12:24
Hallo, please give advice,
When the installation is required, Ethernet setup, you do not know why.
And then restart and shutdown does not work
Thank you
Post by MaLd0n » 10 Sep 2019, 14:13
caberg2000, work fine
MANO02, amd processor?
ACP91
CPU: INTELL DUAL CORE
Motherboard: ASUSROCK 775
GPU: NVIDEA GEFORCE 730
Post by ACP91 » 10 Sep 2019, 14:55
Hola MaldOn!
Finalmente he podido instalar high sierra, pero tuve que retirar la grafica(GIGABYTE NVIDIA GT 730 2 GB). Si la vuelvo a conectar, la pantalla siempre se queda negra, aunque no conecte el vga a la tarjeta.
Hay alguna manera de instalarla?
Gracias
MANO02
GPU: Gigabite
Post by MANO02 » 10 Sep 2019, 16:16
Yes, the Amd Ryzen 5-2400G processor,Gigabyte b450-i-aorus-pro-wifi.
Post by MaLd0n » 10 Sep 2019, 17:22
ACP91, need check if 730 have support or need extra procedure
Added in 50 seconds:
MANO02, try with clover shutdown patch, acpi tab
Harshkumar07
CPU: Intel Core i5 4690
Motherboard: Gigabyte B85M Gaming 3
GPU: Nvidia GT 730 2GB GDDR5
Post by Harshkumar07 » 13 Sep 2019, 13:14
Does anyone know how to enable performance mode in mac mojave? Like in windows we have Performance Mode which keeps the cpu frequency fixed to its highest. Anything like this on mac os?
Post by MaLd0n » 13 Sep 2019, 14:20
Harshkumar07, why u need it? power management is for it, if u need cpu work on high perfomance
OlgunB
CPU: I7 5500U
Motherboard: Toshiba P50-C-11V
GPU: Intel hd5500U / Nvdia gtx950m
Post by OlgunB » 13 Sep 2019, 17:49
Hi,
I need your hep pls.
My Notebook is Toshiba p50-C-11V
Intel i7 5500 / hd5500 gpu /nvidia gfx 950m / 1TB SSD / 16 GB Ram
My problem is :if resolution on standard is setting , on the internal display I have blurred picture. But about hdmi on external display everything ok. but if setting 1920x900 works fine , then I can again set 1920x1080 resolution.
I have clover from olarila.
Any idea ?? thx
Harshkumar07
Post by Harshkumar07 » 13 Sep 2019, 18:08
What is Power management? Is it an app?
Post by MaLd0n » 13 Sep 2019, 22:57
OlgunB, check hackintool
Added in 48 seconds:
Harshkumar07, [External Link Removed for Guests]
Harshkumar07
Post by Harshkumar07 » 14 Sep 2019, 08:11
Hi Maldon. The link you have given, there I cannot find anything. Its just the discription of what Intel Speed Step is. And 1 more thing also. On Windows, my processor's iGPU idle frequency is. 0.6Ghz. But in mac os Mojave, it's frequency is. 0.2Ghz. 3 times less. Any method to increase iGPU idle frequency? And also the Processors frequency?
Post by MaLd0n » 14 Sep 2019, 14:44
Harshkumar07, u can disable speedstep in bios and ur processor run at full ever
mauimade71
CPU: AMD Phenom X2
Motherboard: foxconn
GPU: AMD Radeon HD4200
Post by mauimade71 » 14 Sep 2019, 17:47
I am having trouble with my keyboard and track pad on my laptop. I have an ACER nitro 5
i5 cpu
16 ram
Nvidia gtx
any idea where I went wrong?
