hakimilamina
CPU: intel core i3 8100
Motherboard: gygabyte z370p d3
GPU: intel hd 630
Post by hakimilamina » 30 Aug 2019, 19:32
30 Aug 2019, 18:46
Thank you for this file, but I do not know what to do with this file! :oops: Can you guide me please? Sorry, I'm a real novice with regard to Mac and especially hackintosh. Thank you in advance ! 8-)
Post by MaLd0n » 30 Aug 2019, 19:39
hakimilamina, dsdt.aml into clover/acpi/patched
-Donated? Send me one PM-
hakimilamina
GPU: intel hd 630
Post by hakimilamina » 30 Aug 2019, 20:37
30 Aug 2019, 19:39
yessss !!! Thank you so much ! I finished the interview. I also finished the steps: disablehibernate.command and master-disable.command
I am currently on the part "7- Install Clover Bootloader in SSD".
- Do I do this manipulation while still being booted from the hackintosh partition?
- So I have to put the folder Clover_v2.5k_r5058 in another usb key?
- After I run just Clover_v2.5k_r5058?
Sorry for all these questions, I'm afraid to make mistakes and have to redo everything!
Post by MaLd0n » 30 Aug 2019, 21:24
hakimilamina, if u use olarila clover folder for ur chipset, just put efi folder inside efi partition, don't need install clover
hakimilamina
GPU: intel hd 630
Post by hakimilamina » 31 Aug 2019, 04:54
30 Aug 2019, 21:24
EFI partition on the USB drive on which I currently boot? After placing the EFI folder in the EFI partition, I always restart on the boot key or on the hackintosh partition. Note that I have win 10 install on another hard disc.
What should I do now please?
How to access the efi partition on the hard drive of the high sierra installation?
hakimilamina
GPU: intel hd 630
Post by hakimilamina » 31 Aug 2019, 08:41
30 Aug 2019, 21:24
Can I use this method? [Local Link Removed for Guests] :roll:
So for my case, all I need to do is copy the EFI from the folder CLOVER.SERIES.100.200.300 into the EFI of the installation partition?
After that, can I boot live through the partition? Or should I always use the usb key? Until which stage?
I have a Realtek 8188Gu wireless LAN.11n USB NIC. Do you have a solution to make it work on hackintosh?
ITS GOOD ! EVERYTHING IS OK ! WHAT SHOULD I DO TO FIND AND INSTALL DRIVERS FOR MY KEY Realtek 8188Gu wireless LAN.11n USB NIC FOR EXAMPLE?
Tazorro
CPU: I3 2130
Motherboard: P8H61-M LE/USB3
GPU: GT 8800
Post by Tazorro » 31 Aug 2019, 08:53
Hi Madlon, I'm trying and trying again to change the configuration parameters but nothing to do. I am stuck in this situation, to access I have to wait for the PC to go into standby. I hope you can help me. Thank you
Post by MaLd0n » 31 Aug 2019, 19:01
hakimilamina, u need use efi into ur hdd/ssd for boot from hdd/sdd, fforget usb stick
Added in 38 seconds:
Tazorro, if u have other gpu, try it
hakimilamina
GPU: intel hd 630
Post by hakimilamina » 31 Aug 2019, 20:08
31 Aug 2019, 19:01
Thx !!! That's what I did;) Thank you very much! Everything is ok except that there is a problem with the display that jerks when I browse the internet or if I watch youtube videos or videos on VLC. What should I do? I have a Realtek 8188Gu wireless LAN.11n USB NIC. Do you have a solution to make it work on hackintosh?
Post by MaLd0n » 31 Aug 2019, 20:20
hakimilamina, check if realtek provide driver
ananda27530
CPU: Sandy Bridge i7 2630QM
Motherboard: Hp 3388
GPU: Intel Hd 3000
Post by ananda27530 » 03 Sep 2019, 15:11
Laptop Model: HP DV6 6121 Tx
Processor: Core i7 2630QM 2nd gen (Sandy Bridge)
Ram: 8GB
Graphics: Intel HD 3000 + 2GB Radeon 6770M
Chipset: H67M Express
HDD: 640gb Sata
Boot mode: Legacy
Thanks in advance...
Please suggest supported os..... already tried olarila Mohave image..but stuck on broken screen on boot.
Post by MaLd0n » 03 Sep 2019, 15:15
ananda27530, ur hardware is old, loose support in mojave+
check dosdude app for create one perrsonal usb stick
ananda27530
GPU: Intel Hd 3000
Post by ananda27530 » 03 Sep 2019, 15:46
Please help me about steps...I am new on hackintosh...
Post by MaLd0n » 03 Sep 2019, 16:08
ananda27530, check dosdude site or use high sierra
ACP91
CPU: INTELL DUAL CORE
Motherboard: ASUSROCK 775
GPU: NVIDEA GEFORCE 730
Post by ACP91 » 03 Sep 2019, 19:16
HOLA,
no puedo instalar macOS Sierra, se queda parado.
Mi Pc es:
AsusRock LGA 775
Intel Core Duo 3,00Ghz
Gigabite Nvidia GT 730 2GB
Que puedo hacer? Adjunto imágenes.
Un saludo y gracias.
Post by MaLd0n » 03 Sep 2019, 19:23
ACP91, block voodootscsync
ACP91
Post by ACP91 » 04 Sep 2019, 07:45
03 Sep 2019, 19:23
Hola @MaLdOn!
El problema sigue, se queda parado en este punto:
qué puedo hacer?
lucashps
CPU: Intel Core I7 7700K
Motherboard: Z170A
GPU: GTX 1070 TI
Post by lucashps » 04 Sep 2019, 12:28
Bom dia, @MaLd0n, eu e meu amigo estamos interessados em instalar o hackintosh, porém estamos em dúvida se será compatível com nosso hardware, poderia nos dar essa resposta, segue abaixo os nossos setups:
Setup 1
GPU: GTX 1070 TI
MB: MSI Z170A
Setup 2
CPU: Intel Core I7 3770K
GPU: GTX 1070
MB: Asus
Post by MaLd0n » 04 Sep 2019, 14:53
lucashps, high sierra
lucashps
Motherboard: Z170A
GPU: GTX 1070 TI
Post by lucashps » 04 Sep 2019, 17:58
Eu tenho um notebook, sabe me dizer se ele é compativel?
Especs:
CPU: Intel Core I7 7700HQ
GPU: GTX 1050 TI
Mainboard: Intel HM175
