radek@dresowka.pl
CPU: i9 9900k
Motherboard: Gigabyte Z390 AORUS ULTRA
GPU: AMD RX VEGA 64 8GB
Post by radek@dresowka.pl » 26 Aug 2019, 15:59
Hello, I need some help.
Firstly I done (hope so :D) everything step-by-step from this tutorial. I think that most things are working just fine but I have problem with sleep, shutdown function and like in lets say 30% of times I'm booting Mojave I'm randomly getting stuck (reboot and it works) - Look at the screenshoot. There also a runme.app file included. Please help me make this shitt work :)
My setup:
Latest version of Mojave (olarila image)
Intel Core i9 9900k
GB Aorus Z390 Pro mobo.
64GB of Crucial B. ddr4, 3000 MHz ram
Sapphire RX VEGA 64 wc edition
1TB Samsung EVO NVME SSD
Native BCM wi-fi+bt card aka AirPort Extreme
Bios setup:
• Save & Exit → Load Optimized Defaults​
• M.I.T. → Advanced Frequency Settings → Enhanced Multi Core Performance : Disabled​
• Peripherals → Trusted Computing → Security Device Support : Disable​
• Peripherals → USB Configuration → Legacy USB Support : Auto​
• Peripherals → USB Configuration → XHCI Hand-off : Enabled​
• Chipset → Vt-d : Disabled​
• Chipset → Internal Graphics : Enabled​
• Chipset → Above 4G Decoding : Enabled​
• Chipset → Wake on LAN Enable : Disabled​
Also I would like to ask, how is it with the OC. If I setup sub 5 Ghz on my processor, the system show only basic 3,6 Ghz - is this just normal, because the system does not recognise higher clock speed (but it still works as 5 Ghz) or its bullshit and my OC works only inside the bios setting ? Im getting 39-40k score in multi core-score Geekbench on this setup, also all video hardware encoding works correctly.
Post by MaLd0n » 26 Aug 2019, 16:16
radek@dresowka.pl, use it instead aptiomemoryfix and one full dsdt patch
OsxAptioFix2Drv-free2000.efi.zip
-Donated? Send me one PM-
luizorlandi
CPU: Samsung Ultrabook S5
Motherboard: Samsung NP530U3C-K2BR
GPU: Intel HD 3000
Post by luizorlandi » 27 Aug 2019, 14:51
@MaLd0n, bom dia !!
Estou sofrendo para colocar a minha bateria para rodar, vc clica para aparecer o ícone, ele aparece e some em seguida, alguma dica ??? Já apliquei a DSDT, mas ainda não consegui resolver, 2 dias disso e nada ainda... help !!!
i5 6400 / Mobo Gigabyte GA-H110M-H DDR3 / 16GB DDR3 Corsair Vegeance @ 1600mhz / HD Graphics 530 / SSD 240GB / HDD 2TB
aatmik
CPU: i5 4570 / i7 8700k
Motherboard: h97m-d3h / z370m-d3h
GPU: gt 1030 / gtx 970 OC
Post by aatmik » 28 Aug 2019, 01:06
I want to update my system from High Sierra to mojave but couldn't find Nvidia Drivers :cry: :wallbash
aria92
CPU: i5-6400
Motherboard: Dell
GPU: Nvidia GT-730
Post by aria92 » 28 Aug 2019, 01:42
[in the install guide, at the step 8, it say to replace efi folder from olarilla, but it dont work with me, so i am copying efi from bootable instead, is it okay? or i have to follow the step 8?
note my cpu is : I5 6400, Socket 1151 LGA, when i googling it says 100/200/300 series but i cant see it in olarilla clover
Post by MaLd0n » 28 Aug 2019, 14:29
aatmik, forget nvidia
Added in 46 seconds:
aria92, efii folder from usb stick olarila is generic, work for 90%, the best is use efi for chipset, apply video patch if need and full dsdt patch
visitante708
CPU: i3-6100U 2.3 Ghz
Motherboard: Acer
GPU: Não sei
Post by visitante708 » 29 Aug 2019, 14:11
Using a 32GB USB drive works?
Post by MaLd0n » 29 Aug 2019, 14:16
visitante708, yes
hakimilamina
CPU: intel core i3 8100
Motherboard: gygabyte z370p d3
GPU: intel hd 630
Post by hakimilamina » 29 Aug 2019, 18:45
Hello,
Here are my components:
- Gygabyte Z370P D3
- Core i3 8100
- Corsair VS650 Power Supply
- Corsair Vengeance LPX 16GB (2x8GB) DDR4 2666MHz C16 XMP 2.0
- HDD 150 GB
I do not have a graphics card and SSD for now.
I would like to know if it is possible to install hackintosh on this PC?
What tutorial should I follow on this forum to be able to do it?
Thank you in advance for your help and your answers!
Post by MaLd0n » 29 Aug 2019, 20:17
hakimilamina, just follow first post
hakimilamina
GPU: intel hd 630
Post by hakimilamina » 29 Aug 2019, 20:28
29 Aug 2019, 20:17
This post ? [Local Link Removed for Guests] I want to install High Sierra !
Post by MaLd0n » 30 Aug 2019, 01:58
hakimilamina, yes, work for all systems with Olarila images
hakimilamina
GPU: intel hd 630
Post by hakimilamina » 30 Aug 2019, 08:05
Hello everyone !
I'm very good at booting via usb, but I block here when I run.
I have a Gigabyte z370p d3. Would someone show me correctly how to configure the BIOS for this motherboard?
Note that I do not have a graphics card.
I used the .raw High Sierra
Thank you in advance !
Tazorro
CPU: I3 2130
Motherboard: P8H61-M LE/USB3
GPU: GT 8800
Post by Tazorro » 30 Aug 2019, 12:21
I managed to install Mojave as a guide and I have "everything" working, audio, ethernet, etc. The problem is this, part the verbose ends and then black screen. I have to wait for it to go into standby, disconnect and reconnect HDMI cable
here it appears and everything works magically. If the same thing I do before I go into standbay always black screen.
What's wrong'? Thank you so much.
I attach config (modified graphics with loadVbios, inject Ati eRadeonDelnit) and screen desktop.
Post by MaLd0n » 30 Aug 2019, 12:32
hakimilamina, try it
EFI.zip
Added in 58 seconds:
Tazorro, enable csm in bios/uefi setup
hakimilamina
GPU: intel hd 630
Post by hakimilamina » 30 Aug 2019, 14:45
30 Aug 2019, 12:33
thx ! always a problem somewhere :(
Post by MaLd0n » 30 Aug 2019, 14:54
hakimilamina, extract tables with F4 key in Clover boot screen, files generated in Clover/Acpi/origin, post here!
hakimilamina
GPU: intel hd 630
Post by hakimilamina » 30 Aug 2019, 17:02
30 Aug 2019, 14:54
here are the files !
Tazorro
CPU: I3 2130
GPU: GT 8800
Post by Tazorro » 30 Aug 2019, 17:32
30 Aug 2019, 12:33
mine is a legacy bios
Little update, I installed a rx 570 4gb and I didn't find this problem. Everything starts normally. Tips? I forgot the motherboard is an Asus P6X58D-E with a I7 930 CPU.
Post by MaLd0n » 30 Aug 2019, 18:46
hakimilamina,
