Post by MaLd0n » 13 Aug 2019, 13:04
djuby, not work in some cases, just try
-Donated? Send me one PM-
neverday
CPU: I5 6600K
Motherboard: Asus Maximus VIII Ranger
GPU: RX 580 8GB
Post by neverday » 14 Aug 2019, 17:04
MaLd0n, Segui o tutorial passo a passo, mas quando reinicio o pc, não tenho tela de bootloader! fica travado em tela preta.
Added in 2 minutes 32 seconds:
Lenovo IdeaPad 320 15IKB
pavosage
CPU: Intel Xeon E5-2630 v4
Motherboard: Asrockrack EP2C612 WS
GPU: Radeon Vega Frontier Edition
Post by pavosage » 15 Aug 2019, 19:14
Hello MaLd0n & Co.:
I'm failing to get past the boot initialisation stage. KP ain't my friend!
Components:
Asrockrack EP2C612 - I've read you directing people away from ASRock but this MB is very similar to Supermicro's X10DAI
2x Xeon E5-2630 (Broadwell-EP) I tried adding boot arg= -xcpm_ipi (read it was a mandatory arg for dual CPU configs)
Crucial 2133MHz 4x8GB
2x Vega Frontier Edition (removed 1 GPU)
Here's what I've done
Setup UEFI/BIOS based upon Asrock EP2C602
Downloaded Olaria 10.14.6.raw.bz
Etched onto clean 16gb SanDisk
Inserted it into USB 2.0
Turned machine on, POST is ok
Press F11 > Boot Olaria USB > Olaria loads nicely
Press Install and KP stops me every time.
I used the F2 command to try to log these issues, and have attached the preboot.log
Not being skilful, I spent a week on TonyMacX and another week on Insanelymac. This is my third week and likely last attempt, at least for now. I hope you or your staff might provide some additional guidance or even tell me to forget it with these components.
Thanks,
Post by MaLd0n » 15 Aug 2019, 21:39
pavosage, extract tables with F4 key in Clover boot screen, files generated in Clover/Acpi/origin, post here!
MarlonJCsg
CPU: i5-6400
Motherboard: Gigabyte H110 Gaming3
GPU: NVIDIA GTX 1060 3GB
Post by MarlonJCsg » 16 Aug 2019, 05:11
Opa! Beleza? Consegui instalar o Mojave em um Acer 5742 que tenho aqui, a instalação foi um sucesso, mas ficaram faltando algumas coisinhas:
A Placa de rede Wifi não está funcionando, também não consegui fazer funcionar via cabo, porém aparentemente o bluetooth sim! Também queria saber como eu desativo o menu do Clover/boot (não sei se é o nome certo) mas quero que ele acesse o HD com o sistema instalado automaticamente, sem precisar selecionar!
Clawric
CPU: Intel Core i3-3110M 2.4 GHz
Motherboard: OEM Motherboard
GPU: Intel HD 4000
Post by Clawric » 16 Aug 2019, 11:14
MaLd0n, I have a problem with my battery. mac os detects that my battery has max charge capacity of 1267 mAh. but in reality my battery has a max charge capacity of 4080 mAh. So this is a huge downside for me because it lasts for like 20 minutes and then dies. what do i do?
Post by MaLd0n » 16 Aug 2019, 12:42
MarlonJCsg,
--Run_Me
Added in 17 seconds:
Clawric, [Local Link Removed for Guests]
pavosage
Post by pavosage » 16 Aug 2019, 14:20
15 Aug 2019, 21:39
[/quote
Thanks for responding!
MarlonJCsg
CPU: i5-6400
Post by MarlonJCsg » 16 Aug 2019, 14:38
16 Aug 2019, 12:42
MarlonJCsg,
--Run_Me
Não deu certo :/
Enfim, a placa de rede que estava no notebook não era dele, mas coloquei a original (Atheros AR5B97)
Encontrei algumas soluções pela internet onde precisava mexer em alguns arquivos Kext, mais especificamente em "IO80211Family" dentro dele deveria ter um arquivo "AirPortAtheros40" o qual não encontrei também, rodei um app que estava no pendrive bootavel do Olarila Mojave com o nome "Atheros Installer" mas também não funcionou... Tem mais alguma sugestão?
hpn217tx
CPU: i5-4200U
Motherboard: HP
GPU: GT 740M & HD4400
Post by hpn217tx » 17 Aug 2019, 02:24
hi good day. i want to install mojave on my laptop
quick specs
HP Pavilion 14 Energy Star
i5 4200u
kingston uv500 240gb ssd
hd 4400
gt 740m
alps touchpad
and i wondering that. is it really recommended to use afps rather than hfs+?
i just thinking that afps is designed for apple hardware, that is why i think hfs is better for hackintosh hardware.
what do you think?
thanks.
Post by MaLd0n » 17 Aug 2019, 02:42
hpn217tx, use apfs, is very stable now, no problems
Jockero
CPU: i7-8700T
Motherboard: Gigabyte Aorus gaming 3
GPU: RX 560 4GB
Post by Jockero » 17 Aug 2019, 07:15
Hi MaLd0n.
I ran runme app. Everything work fine, but sleep, shutdown not working, just reboot. Could you help me?
Ghalii
CPU: intel
Motherboard: dell
GPU: intel
Post by Ghalii » 17 Aug 2019, 14:27
hello dears, I need dsdt patch
Clawric
GPU: Intel HD 4000
Post by Clawric » 17 Aug 2019, 16:22
is there any way I can use and alfa net w113 USB adapter on Catalina???
Post by MaLd0n » 17 Aug 2019, 16:58
Jockero,
Added in 4 minutes 15 seconds:
Ghalii,
Added in 20 seconds:
Clawric, no idea
Jockero
CPU: i7-8700T
GPU: RX 560 4GB
Post by Jockero » 17 Aug 2019, 18:05
17 Aug 2019, 17:02
Jockero,
(36.89 KiB) Downloaded 2 times
Thanks. Patched .aml helped me.
buskilagil@gmail.com
CPU: I7-9850H
Motherboard: Z730
GPU: RTX 2060 6G
Post by buskilagil@gmail.com » 17 Aug 2019, 19:32
hey
im trying to install catalina and it getting stuck at 80 percent approximately i dont know why ..
my hardware is
msi gl73 95sk
i7-9850h
intel uhd 630
rtx 2060
jhonwick
CPU: Core i3 2100
Motherboard: Intel D61WW
GPU: Geforce 210
Post by jhonwick » 17 Aug 2019, 19:41
mic not working...audio, boot etc working fine. There is just background noise in audio...but this isn't a big issue...anyway to mic work?
Post by MaLd0n » 17 Aug 2019, 20:18
buskilagil@gmail.com, need fix dsdt and nvram
Added in 6 minutes 31 seconds:
jhonwick, with voodoohda u can edit all
MarlonJCsg
CPU: i5-6400
Post by MarlonJCsg » 17 Aug 2019, 21:07
MaLd0n,
Refiz a instalação do Mojave, o Wifi funcionou em uma inicialização, mas depois que eu fiz a instalação/configuração do clover, tive que reiniciar o notebook
Agora aparece o ícone, porém aparece uma mensagem que nenhum hardware está instalado!
