kansukee
Donator
Donator
CPU: E5-2690
Motherboard: Dell Precision T7610
GPU: NVidia K5000
Post by kansukee » 11 Aug 2019, 17:47
Here you go MaLd0n, thanks for checking it.
Clawric
CPU: Intel Core i3-3110M 2.4 GHz
Motherboard: OEM Motherboard
GPU: Intel HD 4000
Post by Clawric » 11 Aug 2019, 17:52
I'm seeing 2 other options in the clover boot screen. some prebooter things which I dont think will come in hand so how can I get rid of em?
Post by MaLd0n » 11 Aug 2019, 19:42
kansukee, use folder from here, ur config.plist is clean dont have nothing, need a basic
Added in 55 seconds:
Clawric, just hide in ur config.plist, GUI tab
-Donated? Send me one PM-
kansukee
Donator
Donator
CPU: E5-2690
GPU: NVidia K5000
Post by kansukee » 11 Aug 2019, 22:16
MaLd0n, so should I use the stock X79 folder without changing the plist?
kansukee
Donator
Donator
CPU: E5-2690
GPU: NVidia K5000
Post by kansukee » 11 Aug 2019, 23:49
MaLd0n I used the stock folder and just set the video card to vga mode. I can get to the language screen but can’t get past it: [External Link Removed for Guests]
If I apply the rename fix for ehc1 and ehc2 I get another stop at fakesmc. Here's my origin folder below
Post by MaLd0n » 12 Aug 2019, 01:43
kansukee, use it with stock folder
kansukee
Donator
Donator
CPU: E5-2690
GPU: NVidia K5000
Post by kansukee » 12 Aug 2019, 02:46
Same result. I also tried in safe mode, no video. Injecting efi gets stuck at apple logo, same with webdrivers and generic nvidia. :wallbash
Post by MaLd0n » 12 Aug 2019, 03:26
kansukee, try with other gpu, check if work
Clawric
GPU: Intel HD 4000
Post by Clawric » 12 Aug 2019, 05:14
MaLd0n, um I need some help I can't find the hide thingy in config.plist
aryaone
CPU: Intel core i3-8100
Motherboard: gigabyte B360M
GPU: RX 570
Post by aryaone » 12 Aug 2019, 07:53
hi,
i tried to install mac os with olarila image, my PC use gigabyte b360m ds3h and core i3-8100
i already follow the tutorial, buy when i tried to run installer, it's always stuck on grey screen without any curaor or apple logo
where it is wrong
NieChmielu
CPU: R5 1600x
Motherboard: MSI B350
GPU: GTX 1060 6GB
Post by NieChmielu » 12 Aug 2019, 10:33
Any AMD High Sierra olarila image?
I need High Sierra because i have Nvidia GPU. :C
Post by MaLd0n » 12 Aug 2019, 13:07
Clawric, Image
Added in 39 seconds:
NieChmielu, use same folder and create ur usb stick
Clawric
GPU: Intel HD 4000
Post by Clawric » 12 Aug 2019, 14:28
MaLd0n, already did that mounted the efi partition then I opened up the config in clover configurator and I added both to the remove section.
edit: ok so That's finnaly fixed but now I see a third one named Filevault prebootee from prebooter
NieChmielu
CPU: R5 1600x
GPU: GTX 1060 6GB
Post by NieChmielu » 12 Aug 2019, 16:31
12 Aug 2019, 13:07
I don't understand, I should record to USB High Sierra Olarila image and then add files from AMD OSX Vanilla to it? I just don't know how to add files from the AMD OSX folder on the HighSierra installer on windows system
Post by MaLd0n » 12 Aug 2019, 16:36
NieChmielu, Use same folder from olarila mojave amd in high sierra, work good
Added in 14 seconds:
Clawric, ;)
Clawric
GPU: Intel HD 4000
Post by Clawric » 12 Aug 2019, 16:42
it's not even showing after I type diskutil list in terminal all the partitions show up but this doesnt
NieChmielu
CPU: R5 1600x
GPU: GTX 1060 6GB
Post by NieChmielu » 12 Aug 2019, 16:43
12 Aug 2019, 16:36
where can i find him (sorry but i'm new in macos on a different computer than those from apple) :)
Added in 29 minutes :
Ok i found it :)
Added in 13 minutes 37 seconds:
Ok, maybe last question :P EFI folder or EFI system partition.img?
Post by MaLd0n » 12 Aug 2019, 17:50
NieChmielu, [Local Link Removed for Guests]
NieChmielu
CPU: R5 1600x
GPU: GTX 1060 6GB
Post by NieChmielu » 12 Aug 2019, 18:03
But i dont have any mac os machine :(
djuby
Donator
Donator
CPU: Intel Core i7 – 5600U @ 2.6 GH
Motherboard: Dell Latitude E5450
GPU: Intel HD5500
Post by djuby » 13 Aug 2019, 11:57
10 Aug 2019, 13:07
djuby, u need a good serial, check google, have many tutos about it
So will generating a new serial number with Clover Configurator do the trick?
Best regards.
