kansukee
Donator
Donator
CPU: E5-2690
Motherboard: Dell Precision T7610
GPU: NVidia K5000
Post by kansukee » 10 Aug 2019, 22:01
It won’t boot anymore from the usb drive 🙁
Post by MaLd0n » 10 Aug 2019, 22:26
kansukee, extract tables with f4 key in clover boot screen, send me files inside clover/acpi/origin
-Donated? Send me one PM-
kansukee
Donator
Donator
CPU: E5-2690
GPU: NVidia K5000
Post by kansukee » 10 Aug 2019, 23:44
MaLd0n I gave up on 10.14.5, burned the 10.14.6 image but now it gets stuck at fakesmc. I replaced it first with the version from 14.5, same result. I then tried this version from Rehabman and get this, one is using safe mode and the other just with vga: [External Link Removed for Guests]
Post by MaLd0n » 11 Aug 2019, 00:09
kansukee, send me efi folder, i'll check
NieChmielu
CPU: R5 1600x
Motherboard: MSI B350
GPU: GTX 1060 6GB
Post by NieChmielu » 11 Aug 2019, 08:19
09 Aug 2019, 19:13
TvojaStara, Olarila AMD Image yes
Where I can get AMD High Sierra Olarila image?
I need High Sierra image because i have Nvidia GPU
Clawric
CPU: Intel Core i3-3110M 2.4 GHz
Motherboard: OEM Motherboard
GPU: Intel HD 4000
Post by Clawric » 11 Aug 2019, 09:30
alright so I've got everything working battery works mouse is fine all I need is to know if my laptop's wifi card is soldered on or is it replaceable because I looked for hours and I can't find out (my laptop is dell inspiron 14 3420)
Post by MaLd0n » 11 Aug 2019, 13:09
Clawric, i have one with same problem, i need use one usb wifi
AvijitDuttaSlg
CPU: I5 8400
Motherboard: MSi MAG Z390 TOMAHAWK
GPU: Nvidia GForce 1050 TI
Post by AvijitDuttaSlg » 11 Aug 2019, 13:41
My Spec is :
Intel 8th Gen 8400
MSI Z390 TOMAHAWK
16 Gb DDR4 @ 3000MZ
Nvidia 1050TI
250GB SSD
My Problem is installer hangs after 100 Percent loading
I am very new in this. I have updated MB Bios to to latest version. If u are having UFI and plist matching with my config please share.Image
Post by MaLd0n » 11 Aug 2019, 14:03
AvijitDuttaSlg, extract tables with F4 key in Clover boot screen, files generated in Clover/Acpi/origin, post here!
Clawric
GPU: Intel HD 4000
Post by Clawric » 11 Aug 2019, 14:14
MaLd0n, j ok so never mind that i found a solution for that. but something's wrong with my usb ports. sometimes when I put a usb into it it says "USB Accessory needs power" and then I have to put it out and then turn it off then put it in the boot again. please help. it's really annoying restarting my pc just to plug in a usb port.
Post by MaLd0n » 11 Aug 2019, 15:17
Clawric, extract one send_me, i need check
Clawric
GPU: Intel HD 4000
Post by Clawric » 11 Aug 2019, 15:33
MaLd0n, here you go
Post by MaLd0n » 11 Aug 2019, 15:54
Clawric,
catalina have a diff way, we need wait next releases for check about EC
try without usbinjectall
Clawric
GPU: Intel HD 4000
Post by Clawric » 11 Aug 2019, 15:56
MaLd0n, so do i still use the dsdt file or nah?
Post by MaLd0n » 11 Aug 2019, 16:09
Clawric, yes, use dsdt and remove usbinjectall, check if work
Clawric
GPU: Intel HD 4000
Post by Clawric » 11 Aug 2019, 16:44
MaLd0n, would you mind telling me how? Sorry I'm not really an expert in the kext things
Post by MaLd0n » 11 Aug 2019, 17:26
Clawric, clover/kexts/other, USBInjectall.kext, try without
for test the best is block kext in boot, check here
Clawric
GPU: Intel HD 4000
Post by Clawric » 11 Aug 2019, 17:38
so you're saying I should remove usbinjectall.kext and then try?
Post by MaLd0n » 11 Aug 2019, 17:39
Clawric, yes, the best is block usbinjectall at boot and check if work
Clawric
GPU: Intel HD 4000
Post by Clawric » 11 Aug 2019, 17:44
MaLd0n, yup it worked thanks a lot
