airton souza
CPU: Intel i5 2410 2.30Ghz
Motherboard: Sony Vaio Notebook VPCSB
GPU: AMD RADEON 7400
Post by airton souza » 08 Aug 2019, 22:41
Boa noite !
Obrigado por me aceitarem no Forum.
Tenho um notebook Sony Vaio VPCSB
Intel i5 , 12GB RAM, ATI RADEON 7400M , HD 750
Baixei o Mojave 10.14.5 instalei no Pendrive usando o Etcher.
Nao consigo sair da tela inicial desse erro.
Sou leigo em Unix/Linux.
Alguma dica ? Precisa configurar algo no Clover inicial ? Segui os passos do tutorial mas não consegui instalar.
Good night !
Thank you for accepting me on the Forum.
I have a Sony Vaio VPCSB notebook
Intel i5, 12GB RAM, ATI RADEON 7400M, HD 750
I downloaded Mojave 10.14.5 installed on Pendrive using Etcher.
I can't leave the initial screen of this error.
I'm a layman on Unix / Linux.
Any tips? Need to set something up on initial Clover? I followed the tutorial steps but could not install
[url][External Link Removed for Guests]
[img][External Link Removed for Guests][/[External Link Removed for Guests]][[External Link Removed for Guests]]
TvojaStara
CPU: R5 1600x
Motherboard: MSI B350
GPU: GTX 1060 6GB
Post by TvojaStara » 09 Aug 2019, 01:23
AMD Patches are included to High Sierra image?
Post by MaLd0n » 09 Aug 2019, 03:47
airton souza, se vc está usando em legacy, tem de aguardar nessa tela, demora mais de 1 minuto em alguns casos
Added in 13 seconds:
TvojaStara, what patches?
-Donated? Send me one PM-
TvojaStara
CPU: R5 1600x
GPU: GTX 1060 6GB
Post by TvojaStara » 09 Aug 2019, 07:55
These patches: [External Link Removed for Guests]
Post by MaLd0n » 09 Aug 2019, 19:13
TvojaStara, Olarila AMD Image yes
kansukee
Donator
Donator
CPU: E5-2690
Motherboard: Dell Precision T7610
GPU: NVidia K5000
Post by kansukee » 09 Aug 2019, 23:33
Hi MaLd0n, it's been a few days since my original Quadro K5000 card went dead (bad fan) and I had to get another. I was able to download the clover.X79 folder and all I did is made the rename changes you suggested to EH01 and EH02 (I saw 4 devices that could be changed to those names under ACPI tab) and chose the MacPro6,1 SMBIOS. I booted, the first time without injecting my video card which showed under GPU at Clover boot options and got this screen. I could move up and down the languages list using the keyboard but not click on the continue button after choosing the language.
Then I booted one more time, using the injection option for my video card and got this screen:
Looks different but I still can't get past the language screen. I'm attaching my EFI folder, if you can look at it and tell what's going on I would appreciate it. I'll definitely donate beer for you my friend!
Dell T7610 with dual E5-2690 cpu, NVIDIA Quadro K5000 video card, A17 BIOS, X79 chipset.
Post by MaLd0n » 09 Aug 2019, 23:55
kansukee, try with nv_disable=1, u can use a -x too for disable some drivers at install
magloi
CPU: intel
Motherboard: intel
GPU: ATI
Post by magloi » 10 Aug 2019, 00:31
Hello. I have message " macOS could not be installed on your computer" tried 2 configs and change smbios name. Strange because i installed before in this computer Catalina, high sierra, sierra and maybe others. What could go wrong?
Post by MaLd0n » 10 Aug 2019, 01:31
magloi, what ur hardware? update ur signature
poplavok
CPU: 9900k
Motherboard: Asus Z390-E
GPU: Radeon RX 580
Post by poplavok » 10 Aug 2019, 02:21
Am i able to use this EFI for a direct update from high sierra?
Post by MaLd0n » 10 Aug 2019, 11:34
poplavok, yes, this efi and full dsdt patch = good hack
djuby
Donator
Donator
CPU: Intel Core i7 – 5600U @ 2.6 GH
Motherboard: Dell Latitude E5450
GPU: Intel HD5500
Post by djuby » 10 Aug 2019, 13:01
Hi MaLd0n,
I am unable to sign into iMessage and FaceTime. Can you help?
Best regards,
Djuby
Post by MaLd0n » 10 Aug 2019, 13:07
djuby, u need a good serial, check google, have many tutos about it
Clawric
CPU: Intel Core i3-3110M 2.4 GHz
Motherboard: OEM Motherboard
GPU: Intel HD 4000
Post by Clawric » 10 Aug 2019, 15:44
how do i find volumes/efi/efi
I tried my best to find it but I can't!
Post by MaLd0n » 10 Aug 2019, 16:13
Clawric, [Local Link Removed for Guests]
Clawric
GPU: Intel HD 4000
Post by Clawric » 10 Aug 2019, 17:01
MaLd0n, then what do I do?
hachipud
CPU: intel core i3 - 7100
Motherboard: msi b150 night elf
GPU: zotac nvidia Gtx 950
Post by hachipud » 10 Aug 2019, 17:22
Hi sir,
i use mac os high sierra with the latest build, but when i use the nVidia web driver the screen only displays blank. Can you help me?
Post by MaLd0n » 10 Aug 2019, 17:54
Clawric, just use app to mount efi
Added in 1 minute 54 seconds:
hachipud, [Local Link Removed for Guests]
kansukee
Donator
Donator
CPU: E5-2690
GPU: NVidia K5000
Post by kansukee » 10 Aug 2019, 20:36
Hi MaLd0n, I was able to get to the installer using disable_vram-1 a couple of times (for some reason sometimes the progress bar gets stuck before it gets to the language screen) but now it doesn't see my drives except for a NVMe drive connected to a pcie card. No SATA drives are seen under disk utility or under Terminal, diskutil list. Is there a missing kext or clover patch?
I connected an external usb drive and it showed up and I was able to install Mojave... I am so close now!
Post by MaLd0n » 10 Aug 2019, 21:34
kansukee, if u can boot into system, extract one dump
--Run_Me
