[Guide] High Sierra / Mojave / Catalina on X299 / DSDT
Blast
CPU: Skylake-X 9920X
Motherboard: Asus Prime Deluxe II X299
GPU: AMD Radeon Vega RX 56
[Guide] High Sierra / Mojave on X299 / DSDT
Post by Blast » 03 Dec 2018, 15:36
03 Dec 2018, 15:11
Blast, ye, thunderbolt is now
check if work
(28.54 KiB) Downloaded 1 time
last SEND_ME after reboot if work
seems ok to me, but I will left that up to you. thanks.
Send me Ostons-iMac-Pro.zip
Post by MaLd0n » 03 Dec 2018, 15:44
Blast, looks good, use for some days and let me know
Blast
Post by Blast » 03 Dec 2018, 15:56
03 Dec 2018, 15:44
Will do. Many Thanks again. You are a very diligent and helpful person and I will definitely buy you a beer again and I do hope that the many people who you help out do so as well.Thank you.
Post by MaLd0n » 03 Dec 2018, 16:04
Blast, :guitar :guitar :meeting
daovanhoi
CPU: i5 6500T
Motherboard: Hp
GPU: Hd530
Post by daovanhoi » 13 Dec 2018, 00:15
02 Dec 2018, 20:02
daovanhoi,
(22.85 KiB) Downloaded 3 times
check here a x99 preset folder
but all x99 need a extra patches to kernel
Thanks bro! love
HP Elitedesk 800 G3 6500T
Bavari
CPU: i9-7940x
Motherboard: Asus Prime x299 Deluxe
GPU: Asus Strix Vega 64
Post by Bavari » 14 Dec 2018, 19:33
Hi @MaldOn
I've successfully built my new Hackintosh and now im stuck with only two issues,
1) Apple High Definition Audio controller and optical connection
2) Native wifi/bluetooth on MB
My PC specs
1) Asus prime x299 deluxe
2) i9-7940x
3) Asus vega 64 strix
Is there any patches for this motherboard dear?
Post by MaLd0n » 14 Dec 2018, 19:49
post ur files here
Bavari
CPU: i9-7940x
Post by Bavari » 14 Dec 2018, 21:40
This is my generated file. Thanks man
Added in 40 minutes 51 seconds:
This is the DSDT file
Added in 41 seconds:
this is DSDt
Post by MaLd0n » 14 Dec 2018, 22:30
Bavari, use my clover folder, reboot and extract again
CLOVER.zip
Bavari
CPU: i9-7940x
Post by Bavari » 14 Dec 2018, 23:00
Whatttttttttt, man you are my hero
The main board audio and bluetooth worked.
But USB now not within limit and sleep/wake doesn't work, plus didn't have time to check everything
but the folder contains the Örigin + new "Runme file"
Post by MaLd0n » 15 Dec 2018, 01:28
Bavari,
use only DSDT, remove all SSDT and rebooy
delete all previous SEND_ME files in desktop and run app again
Bavari
CPU: i9-7940x
Post by Bavari » 15 Dec 2018, 09:54
Ok This should be it :)
By the way the installation approach which initially started with is KGP Guide, which didn't include patches for the mainboard Audio nor for the mainboard Wifi/Bluetooth. The system seems to work perfectly except for these two issues.
Post by MaLd0n » 15 Dec 2018, 13:20
Bavari, ur old way have many errors, ur log appears many, we need a clear
tell me what now work, wake use power button
Bavari
CPU: i9-7940x
Post by Bavari » 15 Dec 2018, 14:48
Ok, I'm willing to start from the beginning. First of all thank you for giving me your time, can't express my gratitude enough.
What works:
1) MB Audio :)
2) Bluetooth Only from the MB
3) Wake/Sleep seems fine for the time being ( Waking it up from the power Botton )
4) iMessage seems working along with FaceTime
What I don't know how to confirm is if the OSX is properly utilizing the CPU & RAM...
What doesn't work:
1) MB Wifi (I'm using Tp-link AC1900 which works Oob)
2) Some of the USB's doesn't work with usb3 instead only as a usb2
3) Audio from the Display port can't be adjusted from the keyboard nor the Manu bar
So far this is what I can get. Once I install FCX and Davinci Resolve then I can confirm if these 2 apps works flawlessly or not, because they are my main apps to work with.
How can I control my GPU fans (Asus Strix Vega 64), is there a way to control it, I want it even on idle to spin
Post by MaLd0n » 15 Dec 2018, 15:37
Bavari, 1- MB wifi, forget, don't work
2- USB, now we need a other way, u can check here, is a personal patch
3-HDMI audio don't have volume control in Mac
Vega, is a vega 64?
use it and remove whatevergreen kext
VEGA 64.zip
Extract new SEND_ME after reboot
Bavari
CPU: i9-7940x
Post by Bavari » 15 Dec 2018, 15:41
yes Vega 64
Post by MaLd0n » 15 Dec 2018, 15:44
Bavari, K
Bavari
CPU: i9-7940x
Post by Bavari » 15 Dec 2018, 17:58
Admin, I'm making a fresh install with your clove folder to make sure everything clean and clear. Once I finish I will share with you run me and MB dsdt
Bavari
CPU: i9-7940x
Post by Bavari » 15 Dec 2018, 19:11
Ok, finished installing OS and now doesn't boot properly and I get a pink screen, I was able to boot properly when I booted into the new installation via clover of the previous clover settings from the second drive.
So will run me app will collect different info or not?
Post by MaLd0n » 15 Dec 2018, 22:49
Bavari, u remove whatevergreen.kext?
if u use a vegafix.kext, dont use WEG
