[Guide] Sierra / High Sierra / Mojave / Catalina on Sky/Kaby/CoffeeLake Notebooks
[Guide] Sierra/High Sierra/Mojave on Sky/Kaby/CoffeeLake Notebooks
Post by MaLd0n » 22 Apr 2019, 15:48
ajimunir, replace dsdt in clover/acpi/patched
replace kext in clover/kexts/other
VoodooPS2Controller.kext.zip
extract new send_me after reboot
-Donated? Send me one PM-
ajimunir
CPU: Intel i3 7002U
Motherboard: KBL
GPU: Nvidia MX150
Post by ajimunir » 22 Apr 2019, 21:24
MaLd0n, sry for waiting too long, when i use -v bootflag my mouse is worked
Post by MaLd0n » 22 Apr 2019, 23:00
ajimunir, put it in ur desktop and run .command inside folder
fefortunato
CPU: Intel® Core™ i5-6200U
Motherboard: Acer E5-574-592S
GPU: Intel® HD 520
Post by fefortunato » 11 May 2019, 22:01
MaLd0n, Help ME, Acer E5-574-592S, High Sierra, 10.13.6
Send me Felipes-MacBook-Pro.zip
Post by MaLd0n » 12 May 2019, 13:08
fefortunato,
fefortunato
GPU: Intel® HD 520
Post by fefortunato » 12 May 2019, 23:44
12 May 2019, 13:08
fefortunato,
(27.37 KiB) Baixado 2 vezes
Thank you, High sierra worked correctly, but there is a problem that persists in Mojave when activating the graphics, the mouse cursor is locked to the semovimenter, it is impossible to use the system, it knows some solution.
sorry for my bad english
Post by MaLd0n » 13 May 2019, 02:51
fefortunato, no idea about it
fefortunato
GPU: Intel® HD 520
Post by fefortunato » 16 May 2019, 15:18
MaLd0n, thanks for the patch, there is only one more problem in the high sierra, after logging in to macOS, a few moments later the keyboard stops working, any solution to this? is it possible to remove the patch from the keyboard and touchpad? because when I start the system without dsdt.aml the keyboard does not turn off and the touchpad works normally.
Post by MaLd0n » 16 May 2019, 17:48
fefortunato, test without patches about keyboard and touchpad
fefortunato
GPU: Intel® HD 520
Post by fefortunato » 16 May 2019, 19:08
MaLd0n, without the DSDT.aml the keyboard and touchpad works normally, can you do a DSDT.aml only without the keyboard and touchpad patches? can you help me? :)
Post by MaLd0n » 16 May 2019, 20:31
fefortunato, extract new send_me with my files load, i need check
fefortunato
GPU: Intel® HD 520
Post by fefortunato » 16 May 2019, 22:28
MaLd0n,
Post by MaLd0n » 16 May 2019, 22:40
fefortunato, use a dsdt too and voodooi2c kexts
fefortunato
GPU: Intel® HD 520
Post by fefortunato » 16 May 2019, 22:51
MaLd0n,
I'm still new to the subject, do I still use the DSDT.aml you sent me? I'm also using Olarila's CLOVER, does it already contain the kexts? right?
tusamal
CPU: i5 7200u
Motherboard: Acer
GPU: Geforce 940MX
Post by tusamal » 27 May 2019, 01:29
i have an laptop acer F5-573G-50KS wifi/bluetooth/940mx are not working i did something wrong? iam new to this hackintosh thing maybe I doesn't get all the steps to get it working tks, using mojave 10.14.5
Post by MaLd0n » 27 May 2019, 02:27
tusamal, if u have a wifi intel, forget it, don't work
optimus don't work, forget nvidia
tusamal
CPU: i5 7200u
Motherboard: Acer
GPU: Geforce 940MX
Post by tusamal » 01 Jun 2019, 18:54
hi just wanted to share, found this repo, matching hardware of my laptop:
tks!
Post by MaLd0n » 01 Jun 2019, 20:19
tusamal, not good, only cosmetic and little good patches
pchin
Donator
Donator
CPU: i7-6820HQ Skylake
Motherboard: Dell Precision
GPU: HD530
Post by pchin » 05 Aug 2019, 21:54
10 Mar 2018, 20:43
config.plist
--Links
hanafi
CPU: Ryzen 3
Motherboard: hP
GPU: VEGA GRAPHICS
Post by hanafi » 04 Sep 2019, 07:38
i tried everything but mac os setup is not detecting internal hdd of my laptop, and i don't think that it will detect an ssd if i put that in laptop because i think problem is caused by that sata mode which is set to RAID. thats not possible to change. so i tried to install on a usb 3.0 pen drive(64 gb) and it worked but main problem is that i can't permanently use that on a 64 gb usb drive.
