[Guide] Sierra / High Sierra / Mojave / Catalina on Sky/Kaby/CoffeeLake Notebooks
[Guide] Sierra/High Sierra/Mojave on Sky/Kaby/CoffeeLake Notebooks
Post by MaLd0n » 04 Apr 2019, 12:04
jcrcarmo,
--Run_Me
-Donated? Send me one PM-
jcrcarmo
CPU: Intel Core i5 6200U @ 2,40GHZ
Motherboard: Lenovo Ideapad 300 15isk
GPU: Intel HD 520
Post by jcrcarmo » 05 Apr 2019, 00:46
Hi MaLdOn I followed your instructions and here are the saved files from the RunMe.app (please refer to attachment). Thanks!!
Post by MaLd0n » 05 Apr 2019, 02:17
jcrcarmo,
enable EC0 to EC patch in config.plist
jcrcarmo
GPU: Intel HD 520
Post by jcrcarmo » 05 Apr 2019, 04:08
EC0 to EC patch was already enabled in my config.plist. I installed your DSDT.aml to EFI... ACPI/Patched and I notice that now I have battery management and the brightness slider under system preferences works - this is a great improvement. Now, is there a way to make the brightness keys - and + work? Thanks a lot. I owe you a beer! ;)
Post by MaLd0n » 05 Apr 2019, 13:05
jcrcarmo, extract new send_me
jcrcarmo
GPU: Intel HD 520
Post by jcrcarmo » 06 Apr 2019, 02:14
Hi MaLd0n, success!!! I saved the tutorial codes in Notepad in Windows and for some strange reason MaciASL doesn't read it when I copy and paste it in the patch window. I had to save the codes in rich text format first and then enter tem in MaciASL. Tricky... So I followed the tutorial again and voilá! My brightness control keys are working perfectly! Thanks for your time and help! :)
Post by MaLd0n » 06 Apr 2019, 11:42
jcrcarmo, enjoy
murimoney
CPU: Core i7 4720 HQ
Motherboard: Razer blade 14 2015 4k display
GPU: intel hd 4600 gtx 970
Post by murimoney » 08 Apr 2019, 01:44
I know I should run the runme.app, but i can't boot into mac osx no matter what I do. I have tried yosemite, el capitan, sierra, high sierra and mojave. Nothing works. Pls help me patch to disable nvidia graphics so I'll be able to boot high sierra installer and help me with other important patches.
Here is my specs
core i 7 4720HQ
Intel hd 4600 and Nvidia 970m
16gb ram
I hope you help me pls, I beg you. MaLd0n
Post by MaLd0n » 08 Apr 2019, 13:20
murimoney, u need check what device we need disable
murimoney
Post by murimoney » 08 Apr 2019, 14:54
MaLd0n, Thank you for the DSDT patch. I was able to boot into high sierra install I downloaded from your site. I also used your clover for Notebookseries. After booting, graphics does not work as expected, but display was very laggy dragging and unusable to the point it got stuck. I was able to get the send me file, and I also included my clover folder.
My laptop has a 4k screen with intel HD 4600 which I heard is very difficult to get a working graphics. I've set my DVMT to 96mb. I'll like to fix graphics before I move to other patches. Thanks for the help, and I'm sure to make a donation for the wonderful job you are doing here.
Post by MaLd0n » 08 Apr 2019, 18:22
murimoney, Video [Local Link Removed for Guests]
use it
and it
change EC0 to EC
4543305f
45435f5f
murimoney
Post by murimoney » 14 Apr 2019, 19:41
MaLd0n, Thank you for the help. Ive been reading for exams so I havent had time. I've finally figured out the graphics. The dsdt you se4nt me4 wouldn't boot my mackintosh anymore, maybe its because I made changes to my bios and my battery drains like crazy and my laptop gets very hot. Ive made another sendme file, and this time around, I would love it if you help me with the necessary dsdt patches (battery, display brightness, audio and the rest that are important. Thanks man, I love you!!!
Post by MaLd0n » 14 Apr 2019, 19:57
murimoney,
change EC0 to EC
4543305f
45435f5f
murimoney
Post by murimoney » 17 Apr 2019, 08:02
MaLd0n, Thank you for the DSDT patch. Sorry for the late reply, I've been having a terrible internet for 2 days now so I haven't done much, hackintosh-wise. Just to knote, I got mojave working on thesame laptop. Appstore doesn't work because I have no Ethernet hardware for this laptop (thanks to razer), and rehabman's fix doesn't work. Sleep is another thing for a cause of concern for me. After wake from sleep, keyboard stops working.
Other than that, all other stuffs work. Including sound, brightness and the rest.
thank you for all the help man.
Post by MaLd0n » 17 Apr 2019, 13:02
murimoney, ;)
ajimunir
CPU: Intel i3 7002U
Motherboard: KBL
GPU: Nvidia MX150
Post by ajimunir » 22 Apr 2019, 12:26
hey MaLd0n, can you help me to fix my dsdt. thanks
Post by MaLd0n » 22 Apr 2019, 12:41
ajimunir, 1- Replace/Put DSDT in Clover/Acpi/Patched
2- Install Clover again with correct options
3- Reboot
4- Extract new Send_me
USE VOODOOI2C KEXTS
ajimunir
CPU: Intel i3 7002U
Motherboard: KBL
GPU: Nvidia MX150
Post by ajimunir » 22 Apr 2019, 13:25
MaLd0n, i cant use my keyboard and mouse, but birghtness is worked, thanks
so,i put that kext in clover or S/L/E?
Post by MaLd0n » 22 Apr 2019, 13:57
ajimunir, 1- Replace Full Clover Folder
CLOVER.zip
3- Reboot
ajimunir
CPU: Intel i3 7002U
Motherboard: KBL
GPU: Nvidia MX150
Post by ajimunir » 22 Apr 2019, 14:33
MaLd0n, still same
