[Guide] Sierra / High Sierra / Mojave / Catalina on Sky/Kaby/CoffeeLake Notebooks
origindevx
CPU: core duo e8200
Motherboard: ga-ep35-ds3
GPU: 9600gso
[Guide] Sierra/High Sierra/Mojave on Sky/Kaby/CoffeeLake Notebooks
Post by origindevx » 14 Feb 2019, 12:44
MaLd0n, Hello mald0n, I found the reason for my ThinkPad x270 stop “end Randrom seed” (no “+” string).
As long as the Drivers64uefi in the Clover folder exists Fsinject-64.efi it will occur.
But without Fsinject-64.efi, then the kext in the other can not be loaded.
How do I solve this problem, or do I have to load the kext in the other without Fsinject-64.efi? Thank you!
dmsdmsdms
CPU: i7 7700
Motherboard: asus
GPU: gforce 1050
Post by dmsdmsdms » 14 Feb 2019, 13:28
and i cant mount the efi i install ths macos 3 times only the first the disk i can mountit :(
Post by MaLd0n » 14 Feb 2019, 15:09
origindevx, use kexts in library/extensions
Added in 11 seconds:
dmsdmsdms, [Local Link Removed for Guests]
dmsdmsdms
CPU: i7 7700
Motherboard: asus
GPU: gforce 1050
Post by dmsdmsdms » 14 Feb 2019, 20:07
I have try this a lot of times and nothing . Also today I installe the Mojave and still I cant mount the efi... and I cant do anything for the sound ... just I tell for inform... I have 2 hdd in the laptop one ssd ... and one hdd in ssd have windows and in . Hdd macos ... you have any idea...;
Post by MaLd0n » 14 Feb 2019, 22:07
dmsdmsdms, no idea, for efi is just install clover
origindevx
CPU: core duo e8200
GPU: 9600gso
Post by origindevx » 15 Feb 2019, 11:09
MaLd0n, How do I run on a machine that cannot be started, or get information on the machine that does not start properly.
Post by MaLd0n » 15 Feb 2019, 11:40
origindevx, hard
dmsdmsdms
CPU: i7 7700
Motherboard: asus
GPU: gforce 1050
Post by dmsdmsdms » 15 Feb 2019, 14:07
my friend ... i try something else ... i leave only one hdd in my laptop nothing else ... and i instal clear tha high sierra from the start again and finally ... the sound works alone i dont do anything and just work :D ... this is enough for me i use it only for davinci resolve .... with internal graphic card is fine for me ...
gilgamet
CPU: i5-7200u
Motherboard: LNVNB161216
GPU: 110Mx
Post by gilgamet » 15 Feb 2019, 18:55
WHAOUUuuu Amazing ! thank you
:D
bloodstream
CPU: i3 4004u
Motherboard: Dell
GPU: Intel
Post by bloodstream » 24 Feb 2019, 13:59
My laptop is the HP 14 with core i3 6006u and AMD 520 DDR3. I need your help.
Post by MaLd0n » 24 Feb 2019, 17:48
bloodstream,
bloodstream
CPU: i3 4004u
Motherboard: Dell
GPU: Intel
Post by bloodstream » 25 Feb 2019, 05:31
I WILL DONATE. Thank you. Can I extract this DSDT.aml to DSDT.dsl and patch?
Post by MaLd0n » 26 Feb 2019, 13:10
bloodstream, u can patch .aml or .dsl
yurieke
CPU: Kabylake i5 8250
Motherboard: ACER
GPU: MX150
Re: [Guide] Sierra/High Sierra/Mojave on Sky/Kaby/CoffeeLake Notebooks
Post by yurieke » 05 Mar 2019, 02:54
my laptop is acer e5 476g
i5 8250U
12gb ram
i succeed installed mojave 10.14.3
after instaalation.. restart
and i got bootloop panic
i tried config and config2
please help
what i should do?
btw no problem with high sierra and mojave beta
thanks
Post by MaLd0n » 05 Mar 2019, 12:02
05 Mar 2019, 02:54
Acer e5 476g
try with -x
blazewater
CPU: i5-8400
Motherboard: HP-Lincs(H370)
GPU: NVIDIA GeForce GTX 1060
Post by blazewater » 06 Mar 2019, 11:31
@MaLd0n,
I want to install High Sierra to my Desktop PC
HP Pavilion 690-056ccn Gaming
mother board spec(H370): [External Link Removed for Guests]
HP disabled BIOS Advance setting
and when GTX 1060 on board, UHD auto disabled, I must use Nvidia GTX 1060 as my video card.
First I use Clover.100.200.300 to install, but cannot boot into install interface.
So I find this clover(in Send me ...zip file) similar to my machine's configuration, it can boot into install, but install freeze at "2 minutes..."
Then I installed macOS through TimeMachine recovery, it can be booted.
But :
1. cannot power off except click machine's Power Button;
2. cannot sleep to wake.
3. System Information cannot get PCI information
4. cannot control light of screen.
Please Help me, thank you!
Send me iMac-HP.zip
Post by MaLd0n » 06 Mar 2019, 12:01
06 Mar 2019, 11:31
blazewater
CPU: i5-8400
Post by blazewater » 06 Mar 2019, 12:08
06 Mar 2019, 12:01
thank you very much.
I will replace clover using 100.200.300 to try it.
Post by MaLd0n » 06 Mar 2019, 12:10
06 Mar 2019, 12:08
u can use ur clover folder, just add patches too
change GFX0 to IGPU
47465830
49475055
change HDAS to HDEF
48444153
48444546
change HECI to IMEI
48454349
494d4549
change SAT0 to SATA
53415430
53415441
change GLAN to GIGE
474c414e
47494745
blazewater
CPU: i5-8400
Post by blazewater » 06 Mar 2019, 12:24
using current clover(not replace with 100.200.300)
replace DSDT.aml with sending to me
and patched ACPI in clover configurator
but it cannot boot up.
